Zoombak Advanced GPS Car and Family Locator
#338
2.9
based on 14 reviews
Ratings Distribution
5 star
6
4 star
0
3 star
2
2 star
1
1 star
6
Category Average
4.1
Low Price:
$127.43 at eAngler.com
$127.43 at BoatersWorld.com
Find it at Amazon
$127.43 - $200.20
from 6 stores
More Images
Pros
  • Compact (1)
See less See more
Cons
  • Buggy software (1)
  • Inaccurate (1)
  • Poor battery life (1)
  • Poor quality (1)
  • Unreliable (1)
Best Uses
Provided by BoatersWorld.com
Advanced A-GPS Car & Family Locator
Zoombak's Advanced GPS Car & Family Locator will help you locate your car, and your loved ones in it, and help bring them home safely. Great for monitoring teen drivers or other family members you worry about behind the wheel. In addition, the Zoombak locator will assist you in locating your car if it is stolen. Using Assisted Global Position System (A-GPS), which utilizes both satellite and cellular technologies, Zoombak can help to more precisely and reliably determine the location of your Zoombak Locator.
Install the Zoombak car locator permanently in your car or keep it portable for use in other vehicles such as motorcycles, ATVs, boats and bicycles. Locate your car's whereabouts ondemand using Zoombak.com, your mobile phone or live customer care. You can track your car's locations in real time using our continuous tracking option. Simply log on to Zoombak.com to view a map of your car's current location as well as your car's location history. Additionally, you can create your own customized safety zones. When activated, you can be promptly notified via text message and/or email (your choice) when your car has left the zone.
Unlimited on-demand location requests, an easy-to-use website, and a 24/7 toll-free phone number for live customer care and location support, will provide you with the peace of mind you are looking for in car safety.
Product Features:
  • Install or keep portable
  • Personalized safety zones
  • Prompt location alerts and location history
  • Small and lightweight (2.5 oz.)
  • Water resistant
  • Long-life battery (up to 5 days on standby or up to 150 location requests before recharging)
Service Features
Unlimited On-Demand Locates
An on-demand locate helps you to find the current location of your car containing the Zoombak Advanced GPS Car & Family Locator.
There are 3 easy ways to conduct an on-demand location request of your Zoombak Advanced GPS Car & Family Locator.
1. Log on to Zoombak.com
2. Send a text message via mobile phone
3. Contact customer care for live location support
Package Contains
  • Zoombak Locator
  • AC wall charger
  • Portable car charger
  • Installation kit
    • 12v charger
    • Installation bracket
  • User Guide
Zoombak Advanced GPS Car and Family Locator Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 31, 2009
Zoombak Advanced GPS Car and Family Locator Reviews
Most helpful positive review
Most helpful negative review
[3 of 3 customers found this review helpful]
5.0
Exceeded Expectations
"I was somewhat sceptical about purchasing this product after reading some of the reviews, but I have been using it for a couple of months now and have been absolutely amazed by the reliability and accuracy of the Zoombak. I purchased the vehicle installation kit, which was a quick and easy install. I installed on the interior of the vehicle to avoid damage to the unit. It provides real-time tracking of my vehicl..." Read Full Review »
Aug 26, 2009 by Jasmine105
See more positive Zoombak Advanced GPS Car and Family Locator reviews
1.0
Waste Of Money
"Save your money, Zero Customer Service, If you do by Devine Intervention happen to get customer service be prepared to speak at least two languages. They ain't from around here folks. Corporate office is as useless as customer service. Unreliable, the battery has a 2 day life maximum. I was in Orlando loaded with T-Mobile signal and zilch is what I got. Seriously save your money because if you don't like it or i..." Read Full Review »
Jun 12, 2009 by cop105
See more negative Zoombak Advanced GPS Car and Family Locator reviews
Displaying 1 - 5 of 14 Reviews
Show
Sort by
I bought this product for ...
1.0
"I bought this product for my motorcycle. The price was great and it had a lot of features. It was simple to activate and set up. During activation you must select a monthly plan, I choose to prepay 12 months for $9.99/month. In total this unit cost about $300, much cheaper than the other gps devises …"  Read Full Review »
Was this GPS Accessory review on the Zoombak Advanced GPS Car and Family Locator helpful to you?
Aug 10 2009
MrAbility
Colorado Springs
Reviewed at:
Price: $149.99
Works Great for First 2 Months, then Stops Working
1.0
"I wrote a gleaming review of this product shortly after purchase, and it worked perfectly for the first 2 months. But - as all other users have reported - sure enough, after about two months of use in vehicle with the vehicle installation kit, it simply dropped off of the map. After extensive testin …"  Read Full Review »
Nov 2 2009
Jasmine106
Houston, TX
Reviewed at:
Price: $149.99
5.0
"I was somewhat sceptical about purchasing this product after reading some of the reviews, but I have been using it for a couple of months now and have been absolutely amazed by the reliability and accuracy of the Zoombak. I purchased the vehicle installation kit, which was a quick and easy install. …"  Read Full Review »
Aug 26 2009
Jasmine105
Houston, TX
Reviewed at:
Price: $149.99
[1 of 2 customers found this review helpful]
Best Real-time Tracker
5.0
"I've tried several (very expensive) real-time tracking units and this one is the best bang for the buck. It is cheaper (most units cost $400+ with 25+/month service plans), more reliable (other units had poor reporting behavior and coverage), and easier to use (simple setup, simple web interface, et …"  Read Full Review »
 Report Abuse  (1)  (1)  0 comments
Feb 23 2008
electronicsmonkey
Northern Virginia
Reviewed at:
Price: $149.99
SUCKS!!!
1.0
"The product worked perfect for the first 4 months. After that, it would not communicate and I must have called their customer service center at least 5 times. They would tell me that they would call me back, never did. I would call them back with the same issue, they say they would have their engine …"  Read Full Review »
Sep 9 2009
pp2003
los angeles ca
Reviewed at:
Price: $149.99
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
