Zenith DTT901 Digital TV Tuner Converter Box
4.1
based on 263 reviews
Ratings Distribution
5 star
123
4 star
86
3 star
28
2 star
4
1 star
22
Category Average
3.8
More Images
Pros
  • Fast setup (109)
  • Simple controls (97)
  • Attractive design (81)
  • Improved audio/video (64)
  • Easy to use (54)
  • Improves performance (45)
  • Highly compatible (36)
  • Easy to install (35)
  • Fast connection (33)
  • Crisp picture (32)
See less See more
Cons
  • Does not improve audio/video (15)
  • Lacks functionality (6)
  • Poor design (6)
  • Poor performance (5)
  • Poor remote (4)
  • Poor sound quality (4)
  • Setup complicated (4)
  • Flimsy remote (2)
  • Limited compatibility (2)
Best Uses
  • Home (135)
  • Movies (7)
  • Home movies (4)
  • Office (4)
  • Television shows (4)
  • Independent films (2)
  • Living room (2)
  • Motorhome (2)
  • Professional (2)
  • Sports (2)
Provided by OneCall
Clear Digital Picture
Say goodbye to fuzzy analog channels... your old TV has never looked better!
On Screen Program Information
Find out what`s on TV at the touch of a button.
More Programs
See new and different TV programs on “sub-channels“ available from many digital TV stations.
Easy Remote Control
For command of the LG Digital TV Tuner and many other brands of TVs.
Simple Connection to TV
Using the supplied RF cable for easy hookup.
Parental Control
Manage access to TV programs with V-Chip technology.
Advanced Closed Captioning
Access closed captions using the CC button on the remote control or through the simple menu, choose fonts, sizes, colors and more for digital closed captions.
Energy Efficient
EnergyStar rated.
Specification Description
Model DTT900, DTT901
UPC 719192172593
Analog Audio (1) Rear Output
Composite Video (1) Rear Output
Depth (Inches) 6.4
Dolby(R) Digital/AC3 Yes
Height (Inches) 1.8
On Screen Display Yes
Remote Control Included
Resolution Standard Definition
RF (1) Rear Input
RF (1) Rear Output
Tuner ATSC
Weight (Pounds) 1.65
Width (Inches) 8.5
Zenith DTT901 Digital TV Tuner Converter Box Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: DTT901 Digital TV Tuner Converter Box
See all eBay results
  at eBay.com
Product Reviews
Last update: Sep 22, 2009
Zenith DTT901 Digital TV Tuner Converter Box Reviews
Most helpful positive review
[4 of 4 customers found this review helpful]
Most helpful negative review
[7 of 7 customers found this review helpful]
5.0
Simple setup, nice results
"Using this on a large Sony flat CRT, with a classic 7ft antenna on a 30ft aerial without a rotor. Setup is simple as long as you have good signal, just hit enter a few times. The remote control seems sturdy so far, but is not intuitive to use. It'll take a bit of practice to use all the functions on the remote in the dark. Easy to program the power button to operate the TV, but the volume buttons don't operate ..." Read Full Review »
Mar 23, 2008 by bdk
See more positive Zenith DTT901 Digital TV Tuner Converter Box reviews
3.0
Wait! Buy the DTT901 Instead!
"Be advised the DTT900 is the old model. The audio on the DTT900 unit is flat; really disappointing. LG rushed the product to market to fill the demand before it was ready. The new model DTT901, which was released only months after, has Dolby Digital 2ch Downmix, which is said to improve TV audio significantly. Great picture quality negated by poor audio does not make the DTT900 the model of choice. Most likely R..." Read Full Review »
Aug 16, 2008 by Minx
See more negative Zenith DTT901 Digital TV Tuner Converter Box reviews
Displaying 1 - 5 of 263 Reviews
Show
Sort by
5.0
    Pros
  • Fast Setup
  • Improved Audio/Video
    Cons
  • Wimpy Remote
    Best Uses
  • Home
The remote control seems sturdy so far, but is not intuitive to use. It'll take a bit of practice to use all the functions …"  Read Full Review »
antenna
antenna
Was this HDTV Tuner review on the Zenith DTT901 Digital TV Tuner Converter Box helpful to you?
 Report Abuse  (4)  (0)  0 comments
Mar 23 2008
bdk
chicago
I am:
  • Couch Potato
  • Gearhead
  • Nerd
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
[9 of 9 customers found this review helpful]
Install and setup hints
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Simple Controls
    Cons
  • GUIDE button works oddly
  • Needs a good antenna
  • One AAA battery in remote
  • Volume low on stereo
  • ZOOM button hard to use
    Best Uses
  • Home
"Some install and setup hints (I assume you also want to continue to get analog TV until it's cut off, or even after, if you get Canadian/Mexican channels or low-power analog):
1) Digital TV requires a better antenna than analog TV, or you can expect those fuzzy, but watchable, analog TV programs …"  Read Full Review »
 Report Abuse  (9)  (0)  0 comments
Apr 28 2008
StuRat
Detroit, MI
I am:
  • Tech Savvy
Reviewed at:
[12 of 13 customers found this review helpful]
Seems ok for now
4.0
    Pros
  • Fast Setup
  • Simple Controls
    Cons
  • Can't say for now
    Best Uses
  • Home
"I got improved reception after connecting the box. I have a roof antenna which isn't so hot so I wasn't getting all the channels but after connecting this box, I picked up better reception on the weak channels and picked up a few more channels. For instance, ABC has 7-1 (which is the regular chann …"  Read Full Review »
 Report Abuse  (12)  (1)  0 comments
May 11 2008
intanet
Bronx, N.Y.
I am:
  • Tech Savvy
Reviewed at:
Works great with cheap
4.0
    Pros
  • Fast Setup
  • Works with my indoor ant
    Cons
  • Remote tv volume
    Best Uses
  • None
"I was very happy that the unit works flawlessly from the middle of a city with a fair amount of ground clutter and broadcast shadows. Did I am using my old, cheaper than turds, bunny ear antenna? My analog reception wasn't exactly stellar, but I pull in all the available DTV channels (only 12) fla …"  Read Full Review »
  • Picture of Product
  • Using Product
Mar 24 2008
Hurdy Gurdy Man
Madison, WI
I am:
  • Professional
Reviewed at:
[8 of 8 customers found this review helpful]
Very Good Converter
5.0
    Pros
  • Attractive Design
  • Fast Setup
    Cons
  • None
    Best Uses
  • Home
  • Professional
"First impressions of Zenith DTT900 DTV converter
Cool front panel display - red LED off - blue LED on
Lame feature: You must have the remote to complete any functions beyond on/off and channel changing. You must have the remote to perform an initial set-up. No remote - no working converter box …"  Read Full Review »
 Report Abuse  (8)  (0)  0 comments
Feb 29 2008
Karl Zuk
New York
I am:
  • Professional
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
