zBoost Wi-Ex zP Cell Phone Signal Booster
#166
1.6
based on 18 reviews
Ratings Distribution
5 star
1
4 star
1
3 star
0
2 star
4
1 star
12
Category Average
3.6
$114.99 - $179.99
from 13 stores
More Images
Pros
  • Easy setup (5)
  • Does not work at all (1)
  • Very basic (1)
See less See more
Cons
  • Poor reception / weak antenna (5)
  • Flimsy (2)
  • Bulky design (1)
  • Does not do anything (1)
  • Doesn't add much 2 signal (1)
  • I have repositioned it ma (1)
  • Useless (1)
Best Uses
  • Does not work anywhere (1)
  • Home office (1)
  • Limited within small area (1)
  • No where (1)
  • Small rooms (1)
Provided by photoalley.com
The award winning zBoost zP extends a Cell ZoneTM for a single user in dorms, hotels, homes or offices. Its compact size and no set-up make it ideal for travelling. Whether you're at a hotel, meeting room, or dorm, the zP is guaranteed to boost your bars by creating your very own "Cell Zone".
  • Increases Signal and Creates a Personal Cell ZoneTM covers your workspace (4 - 6 ft.)
  • Dual Band - works with all phones and carriers, increasing signal strength for voice and/or data (except Nextel, iDEN
  • Great for Travel - Compact size, zero installation - take your cell zone with you
  • Maintains network integrity using innovative patent-pending technology
  • Specification Description
    Model 00027, WEXYX300PCS, YX 300-PCS/CEL, YX300
    UPC 186639000274
    Benefits Increases your signal and creats a personal wireless zoneCovers a space of 4 to 6 space to provide you with personalized wireless sig
    Capacity UOM mAh
    Country Of Origin India
    Description Header Rev up your wireless reception.
    Display Catalog Number 55032387
    Enclosure Color 2-Color
    End Product Indicator Yes
    Included in the Box zBoost Cell Zone booster
    Manufacturer Labor Warranty 12
    Manufacturer Part Number YX 300-PCS/CEL
    Manufacturer Parts Warranty 12
    MAP Price 0.0
    Model YX 300-PCS/CEL
    Operating Temperature UOM ° F
    Product Type Signal boosters
    Supported Languages English
    zBoost Wi-Ex zP Cell Phone Signal Booster Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Sep 25, 2009
    zBoost Wi-Ex zP Cell Phone Signal Booster Reviews
    Most helpful positive review
    Most helpful negative review
    [1 of 1 customers found this review helpful]
    4.0
    It works.
    "I needed a "boost" for my cell phone in my home office, pun intended. This unit seems to work but it does not cover the 4' to 6' area as advertised. It is most effective when it is VERY close to the cell phone. The user manual consists of instructions on the back of the box. It is not a WOW but it works...." Read Full Review »
    Aug 19, 2009 by Road runner
    See more positive zBoost Wi-Ex zP Cell Phone Signal Booster reviews
    1.0
    YX300 is useless
    "Do not waste your time or money on this product. I purchased the YX-300, hoping that it would boost the 1-2 bars that I received with my Verizon phone and Sprint 3G card a few bars. After installing it according to the instructions and getting a green light on the unit, I brought the phone within range. Nothing. Absolutely no increase in signal. I unplugged the power to see if there was any movement on my s..." Read Full Review »
    Aug 09, 2008 by Very dissapointed
    See more negative zBoost Wi-Ex zP Cell Phone Signal Booster reviews
    Displaying 1 - 5 of 18 Reviews
    Show
    Sort by
    YX300 is useless
    1.0
      Pros
    • None
      Cons
    • Flimsy
      Best Uses
    • None
    I purchased the YX-300, hoping that it would boost the 1-2 bars that I received with my Verizon phone and Sprint 3G card a few bars. After installing it according to the instructions and getting a green light on the unit, I brought the phone withi …"  Read Full Review »
    Was this Antenna review on the zBoost Wi-Ex zP Cell Phone Signal Booster helpful to you?
     Report Abuse  (1)  (0)  0 comments
    Aug 9 2008
    Very dissapointed
    Calif
    I am:
    • Gearhead
    Reviewed at:
    [2 of 2 customers found this review helpful]
    zBoost signal repeater?
    2.0
      Pros
    • Easy To Set Up
    • Very basic
      Cons
      Best Uses
    • Small Rooms
    "I had nothing and at least now I can get a bar on the cell phone which allows me to have a conversation within the designated area. I think I will invest in one that will allow me to have the signal throughout the house though because otherwise it is like being attached to a land line since you are …"  Read Full Review »
     Report Abuse  (2)  (0)  0 comments
    Sep 12 2009
    Mrs SM
    Millingon, TN
    I am:
    • Power User
    Do not buy this its junk
    1.0
      Pros
    • None
      Cons
    • Poor Reception
      Best Uses
    • does not work anywhere
    "This devise only seemed to provide gained signal when a phone was placed ONTO the antenna. 2 inches away and the signal that was gained was lost again.
    We have 2 bars where we live and 6 inches away from the supplied antenna I was back to 2 bars. "
    May 28 2008
    R wight
    tulsa oklahoma
    I am:
    • Professional
    It works.
    4.0
      Pros
    • Easy To Set Up
      Cons
    • None
      Best Uses
    • Home office
    "I needed a "boost" for my cell phone in my home office, pun intended. This unit seems to work but it does not cover the 4' to 6' area as advertised. It is most effective when it is VERY close to the cell phone. The user manual consists of instructions on the back of the box. It is not a WOW but …"  Read Full Review »
    Aug 19 2009
    Road runner
    Alabama
    I am:
    • Enthusiast
    DID NOT WORK at all.
    1.0
    "Although I very carefully set the booster up according to instructions, I found no noticeable change in my cell phone signal strength. I am using a Verizon VX6900 pda/phone and have fringe receiption where I am located. The mfg instructions called for at least a bar & one-half for boosting. I had …"  Read Full Review »
    Sep 9 2008
    msg
    Abilene, Texas
    I am:
    • Business Professional
    Reviewed at:
    pages: 1 2 3 4 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
