Yorkville LS800p 18-inch powered subwoofer 1500w *
5.0
based on 1 review
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
Pros
  • Attractive design (1)
  • Crisp sound (1)
  • Easy to connect (1)
  • Great sound quality (1)
  • Powerful (1)
See less See more
Best Uses
  • Basic systems (1)
  • Live sound (1)
  • Outdoors (1)
Provided by PSSL.com - ProSound and Stage Lighting
Yorkville LS800p 18-inch powered subwoofer 1500w First choice in active subwoofers, the LS800P combines a cast-frame, neodymium-based 18-inch bass driver with a rear-loaded bass horn enclosure made from 15mm birch ply covered in rugged black carpeting (black ultrathane-painted version – LS800PB – is also available). Now add 1,500 continuous Watts of onboard power featuring full-time “invisible” limiting. Result - a rugged, high-powered “earth mover”. Balanced XLR inputs are included along with 1/4-inch TRS inputs which, at the push of a button, can handle either line-level or speaker-level signals (you can simply connect it to any full-range speaker for quick and easy setups).. Connections also include both XLRM and 1/4” Output Link jacks for interconnecting up to 10 LS800Ps in larger concert systems. An additional XLR 'Mono Blend Input' allows the LS800P to function in a stereo system by blending the balanced L & R signals from a stereo mixer and creating a single in-phase mono signal. The control panel features a +/- 12dB Level pot for matching the LS800P’s output with the rest of the system, a tunable 90 to 150Hz HF Roll off pot to let you match the LS800P to any full-range enclosure without an electronic crossover, a unique Shape control that modifies the bass response, a Line/Speaker Input Level button and LEDs to indicate Power, Limit and Clip. Hardware includes four steel inset handles, a steel top-mounted pole-stand adapter, a heavy-gauge curved steel grill and tilt-back wheels. Features: System Type: Rear Horn Loaded Subwoofer Active or Passive: Active Program Power (Watts): 1500 Max SPL (dB): 134 Frequency Response (Hz +/- 3db): 45 - 150 LF Driver(s): Single 18 inch w/ 4 inch voicecoil LF Program Power(Watts): 1500 LF Protection: Thermal / Overcurrent / Clip Power Consumption (typ/max): 792/960VA (8A@60hz, 4A@50hz) Inputs - 1/4" Jacks: 2 line/speaker level inputs, 2 link (in/out) Inputs - XLR: 2 line inputs, 2 link (in/out) Level Controls: Master Other Controls / Features: Active Controls, Level, Low Pass Filter Frequency, Bass Boost Level Corners: Metal Feet: Rubber Bar Handles: 2 (Side), 1 (Rear) Pole Mount Adapter (1 3/8"-3.5cm): 1 (Top) Enclosure Materials: 15mm (5/8inch) 11-ply Russian Birch Grille: Perforated Metal Covering / Finish :Black Ozite (Carpet) Optional Covering / Finishes: Black Ultrathane Paint (LS800PB) Dimensions (DWH xbackW, inches): 23 x 27.5 x 32 Dimensions (DWH xbackW, cm): 58.4 x 70 x 81.3 Weight (lbs/kg): 137.3 / 62.3
Yorkville LS800p 18-inch powered subwoofer 1500w * Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: LS800p 18-inch powered subwoofer 1500w *
See all eBay results
  at eBay.com
Product Reviews
Last update: Jun 11, 2009
Yorkville LS800p 18-inch powered subwoofer 1500w * Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
Best sub on the market
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Great Sound Quality
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Systems
  • Live sound
  • Outdoors
"It doesn't get any better then this hard hitting sub. I use it with my band outside and the volume on the sub was at half way. You will never run out of power. great sound and very clean. "
Was this Speaker & Subwoofer review on the Yorkville LS800p 18-inch powered subwoofer 1500w * helpful to you?
Jun 11 2009
Frank the tank
louisville ky.
I am:
  • Musically Inclined
  • Professional
  • Tech Savvy
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
