Yamaha YHT-390BL 5.1-Channel HDTV Home Theater System
#31
4.3
based on 32 reviews
Ratings Distribution
5 star
15
4 star
13
3 star
3
2 star
1
1 star
0
Category Average
4.1
$3.99 - $349.95
from 6 stores
More Images
Pros
  • Great sound quality (4)
  • Easy setup (2)
  • Attractive design (1)
  • Confusing / difficult controls (1)
  • Interfaces well with tv (1)
See less See more
Cons
  • Heavy / bulky (2)
Best Uses
  • Smaller rooms / apartments (2)
  • Basic use (1)
  • Living room (1)
  • Movies (1)
  • Surround sound solution (1)
  • Television shows (1)
Provided by OneCall
BluetoothM
The Bluetooth (R) logo indicates that the product is equipped to use the optional YBA-10 Bluetooth(R) Wireless Audio Receiver that lets you connect the dock to the receiver and supports A2DP audio streaming. With the optional YBA-10 Bluetooth dock, you can enjoy music wirelessly from Bluetooth enabled mobile phones, portable devices, or personal computes.
(view the Specifications of each product for Bluetooth(R) dock compatibility)
Made for iPod
The Made for iPod logo indicates that the product is equipped to use the optional YDS-10 Universal Dock that lets you connect your iPod to this product. With the optional dock you can listen to your music and operate the iPod via the product`s remote control while at the same time recharging the battery on your iPod. Depending on your product`s specifications, some will allow you to use the On-Screen Display feature on your video monitor to navigate your music. Some products can even allow you to view your photos and movies from your iPod on your video monitor (view the Specifications of each product for iPod playback compatibility)...
YDS-10 Universal Dock works with: iPod nano, iPod mini and iPod (Click Wheel)
– Newly released (2007-09) iPod classic, iPod nano and iPod touch are compatible for music content playback and control only.
Dolby Pro Logic II
Improved version of Dolby Pro-Logic for music and movies. With a more intelligent matrix decoder, it is suitable for both stereo and surround-encoded sources. It offers “bass management as well as the option of incorporating width, “dimension and “panorama controls.
DTS Digital Surround
The basic DTS 5.1 channel sound format. Uses a higher data rate than Dolby Digital.
HDMI
High Definition Multimedia Interface (HDMI) is the first and only digital interface to combine uncompressed high-definition video, multi-channel audio and intelligent format and command data in a single digital interface. HDMI switching, providing the most advanced method of delivering high quality video signals to a home theater system to enable the reproduction of DVD and satellite TV sources with HD quality. HDMI can also send the digital audio signals from sources such as DVD Audio, CD, Dolby Digital and DTS to provide simple components connections.
6 Ch Ext Input
6 additional input jacks for discrete multi-channel input. Front (Left, Center, Right), Rear (Surround Left & Right) and Subwoofer
CINEMA DSP Digital
Conventional multichannel audio reproduction systems base their sound on Dolby Digital and DTS decoding, using matrix and steering technologies to create surround sound effects. Yamaha CINEMA DSP is much more advanced, actually creating richly realized independent sound fields that envelop you in an unmatched surround sound experience. With dialogue, music and effects from ideally located in these separate sound fields, you will hear sound with accurate placement, smooth movement, exceptional clarity and richness, and startlingly realistic presence. It will seem as if the walls of your room have disappeared and you are in the middle of your own immense theater! The decoding circuitry performs Dolby Pro Logic IIx, Dolby Digital, Dolby Digital EX, DTS Digital Surround, DTS-ES (DTS-ES Matrix 6.1 and DTS-ES Discrete 6.1), DTS Neo:6 and DTS 96/24 decoding with extreme accuracy, as well as all digital sound field processing.
SILENT CINEMA and Virtual CINEMA DSP
SILENT CINEMA makes it possible to hear large-scale surround sound through ordinary headphones! This is a variation of CINEMA DSP technology that Yamaha developed to let you listen in private to movies and other multi-channel sources for hours without listening fatigue. Virtual CINEMA DSP lets you enjoy the effects of CINEMA DSP surround sound without using surround speakers (handy for use in custom installations where some rooms don't have surround speakers). It can be used with the front / center / presence speakers or even with just the two front left and right speakers.
Compressed Music Enhancer
Yamaha employs sophisticated digital signal processing with exclusive algorithms to enable playback that improves the performance of compressed music formats, including MP3 and WMA. With the Compressed Music Enhancer, highs and especially lows are richer and smoother, bringing music back to life to be as close to the original as possible.
SCENE – A NEW LEVEL OF OPERATING EASE
Four SCENE buttons make operating the receiver easier than ever. They are initially set to default settings for DVD Viewing, Disc Listening, TV Viewing and Radio Listening. Pressing a SCENE button automatically launches a number of operations that initiate play of the source controlled by that button. Other SCENE settings are also available, such as iPod Listening, XM Listening, TV Sports Viewing and Action Game Playing. Browsing and selecting the settings is quickly accomplished by rotating the Input knob and watching the on-screen display. The settings can be selected for one-time use, or they can replace the original default settings. The SCENE names can be changed also.
Specification Description
Model YHT-390BL, YHT390BL
UPC 027108105253
Analog Audio (1) Rear Output
Analog Audio (3) Rear Input
Analog Audio / Video (1) Rear Output
Analog Audio / Video (3) Rear Input
Antenna AM
Antenna FM
Antenna Rear Input
Coaxial Rear Input
Depth (Inches) 23.4
HDMI (1) Rear Output
HDMI (2) Rear Input
Height (Inches) 21.6
MP3 or iPod Connectivity iPod Dock optional
Optical (2) Rear Input
Play Modes Surround (5.1 Channels)
Speakers 5 Satellites + Subwoofer
Stereo Power Rating 100 Watts x 2
Tuner AM
Tuner FM
Weight (Pounds) 73
Width (Inches) 24.5
Yamaha YHT-390BL 5.1-Channel HDTV Home Theater System Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jul 24, 2009
Yamaha YHT-390BL 5.1-Channel HDTV Home Theater System Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
5.0
Awesome 5.1 system with three HDMI inputs
"I spent months picking a stereo system, reading reviews, listening to different systems at big box stores, and ultimately settled on this one. The reason is simple: this 5.1 system sounded better than any other I tested, even those that cost twice as much! The sound quality of this system is simply amazing at this price. You could drop 3x as much on a Bose system and be less satisfied. Pros: 3 HDMI inputs wit..." Read Full Review »
Nov 07, 2008 by GreatAchilles
See more positive Yamaha YHT-390BL 5.1-Channel HDTV Home Theater System reviews
3.0
Decent product....if not broken
"I had one before this one and loved it.....too bad a bought this one from a company who sells broken/ messed up stuff for the same price as a brand new one...stay away!! But if you buy it from a well known and reputable retailer you will love it..." Read Full Review »
Jul 24, 2009 by Extremly Angry in Ohio!!!!
See more negative Yamaha YHT-390BL 5.1-Channel HDTV Home Theater System reviews
Displaying 1 - 5 of 32 Reviews
Show
Sort by
5.0
The reason is simple: this 5.1 system sounded better than any other I tested, even those that cost twice as much! The sound quality of this system is simply …"  Read Full Review »
Was this Shelf System review on the Yamaha YHT-390BL 5.1-Channel HDTV Home Theater System helpful to you?
 Report Abuse  (1)  (0)  0 comments
Nov 7 2008
GreatAchilles
Undisclosed
Reviewed at:
Great unit for the price
5.0
    Pros
  • Clear Sound
  • Easy To Setup
  • Interfaces Well With TV
  • Intuitive Controls
    Cons
  • None
    Best Uses
  • Living Room
  • Movies
  • Surround Sound Solution
  • Television Shows
"I looked around for a mid level system that was great for a mid level price. This was definatly it. [...] I could not be happier with the system itself. It performs well and has a lot of really good features, great sound, and is not hard to figure out for anyone. The sub is a good solid build and pr …"  Read Full Review »
Dec 28 2008
Kyle
Texas
I am:
  • Musically Inclined
  • Tech Savvy
Reviewed at:
A Solid System for the Patient and Underfunded
5.0
"I'm not a millionaire, and - if you're reading this - you aren't likely one either.
That doesn't mean we aren't entitled to a little condominium quake when the Millenium Falcon passes directly overhead.
I use this system with my XBOX 360 and also run an HD signal through it, and couldn't be happier …"  Read Full Review »
Jul 8 2008
TheBigGameReviewer
Fort Myers, Fl
Reviewed at:
Good value buy
5.0
"This product is a very good buy if you're looking to upgrade from your built-in speakers on your TV. No comparison. GREAT for first-timers who want something simple and don't want to deal with a custom system. Multiple digital inputs finally gave me true 5.1 surround from all my digital devices. The …"  Read Full Review »
Feb 4 2009
MilesFrmOrdnary
Los Angeles, CA
Reviewed at:
Awsome Surround
4.0
"Great sound from this system. We had originally bought the Bose speaker system with the sub and two speakers but when we found out the only way to hook it up was through rca cables, which our new flat plasma didnt have, we took it back and bought this one. The sound that it produces is clean, clear …"  Read Full Review »
Jul 20 2008
Chuck26
San Diego, CA
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
