Yamaha S215V Club Series Speaker Dual 15In 2-Way *
#588
4.7
based on 3 reviews
Ratings Distribution
5 star
2
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.4
$599.99 at PSSL.com - ProSound and Stage Lighting
Find it at Amazon
Find it at Ebay
$599.99
from 1 store
Pros
  • Great sound quality (3)
  • Attractive design (2)
  • Easy to connect (2)
  • Powerful (2)
  • Compact (1)
See less See more
Cons
  • Not durable (1)
Best Uses
  • Large rooms (3)
  • Audiophiles (2)
  • Basic systems (2)
  • Concerts (1)
  • Smaller rooms / apartments (1)
Provided by PSSL.com - ProSound and Stage Lighting
YAMAHA S215V CLUB SERIES V SPEAKER DUAL 15IN 2-WAYBuilt in the United States, the S215V is designed to provide years of service. High power handling and excellent response have made Club Series loudspeakers the perfect choice for more than 16 years. Whether playing in a band, DJing, orupgrading the sound system at your church or school, the S215V has a rugged carpet covering and steel corner protectors to hold up to the rigors of transport. A heavy arced steel grill offers protection for the woofer.Features:Cabinets are constructed of high quality particleboard, chosen for its high strength and elasticity, consistent void free makeup and light weight. Another great benefit of this material is its environmental friendliness. Made from southern yellow pine, this material is both abundant and quickly renewable. Accurate CNC routing machines are used to cut every part, assuring consistency with tolerances of one ten thousandth of an inch. Skilled technicians assemble each cabinet by hand, rejecting any defects. Whether covered in durable carpet or the elastomeric spray coating, heavy steel handles and sturdy pole sockets make moving and positioning easy.The drivers, or speakers in these cabinets, are custom made by Eminence Speaker Corporation? to Yamaha's exacting tolerances. Woofers share design features like high strength curvilinear cones and Dupont Kapton? voice coil formers. Oxygen-free copper voice coils and oversize strontium ferrite magnets are also used to provide high power handling and long life. The 15" and 18" drivers use cast aluminum frames to support the massive magnet structure, eliminate flex and help dissipate heat. The compression driver that generates the high frequency sound uses a pure titanium diaphragm. This 2" dome is one of the largest in its class, allowing for very high output and low distortion, without the aid of cooling fluids. It's mated to a 90? x 40? custom designed CD (constant directivity) horn with excellent dispersion and response.Crossover networks that divide the signal going to the woofer and compression driver are constructed with oversized coils, high voltage capacitors, and power resistors designed to provide the best possible sound quality and minimize loss. Overload protection is also included to protect the components.Connections are dual Neutrik Speakon? ? jacks for the highest possible strength and current capacity. Two of each connector makes it easy to "daisy chain," or add speakers. Dual 15" cast frame woofers1" titanium dome compression driver2000-watt peak power handlingTightly braced cabinet
Yamaha S215V Club Series Speaker Dual 15In 2-Way * Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: May 21, 2008
Yamaha S215V Club Series Speaker Dual 15In 2-Way * Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
these speakers are tight
5.0
    Pros
  • Attractive Design
  • Compact
  • Easy To Connect
  • Great Sound Quality
  • Powerful
    Cons
  • None
    Best Uses
  • concerts
  • Larger Rooms
"i had this speaker for lyke 4 years And i have atleast 30 pairs of em. i do provide sound for concerts and these speakers create sound lyke the jbl's but u have to tune ur system right otherwise u will have problems definatley grab this while u can... DJ TECH - TWISTED ENT "
Was this Speaker & Subwoofer review on the Yamaha S215V Club Series Speaker Dual 15In 2-Way * helpful to you?
Jan 8 2008
DA WILDSTYLE DJ
SACRAMENTO / ELK GROVE
I am:
  • Professional
RICH FULL SOUND!
5.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Audiophiles
  • Basic Systems
  • Larger Rooms
  • Smaller Rooms
"Great deep full sound in any large or small room. I use a pair for smaller rooms four for larger rooms and outdoors. I add a pair of dual 18"subs for very large or outrageous events. "
Jan 10 2008
DJ Lee
Lafayette,LA.
I am:
  • Audiophile
  • Practical
  • Professional
  • Tech Savvy
THESE SPEAKERS B BAGGIN
4.0
    Pros
    Cons
  • Not Durable
    Best Uses
  • Audiophiles
  • Basic Systems
  • Larger Rooms
"I WENT THREW A LOT SPEAKERS BLEW THEM ALL,NOT THESE. MOST SPEAKER YOU ARE PAYING FOR THERE NAME.I WOULD NOT TRADE THESE FOR NOTHING. "
May 21 2008
DJ RONI
CHICAGO, IL
I am:
  • Musically Inclined
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
