Yamaha P5000S P-Series Power Amplifier
#163
5.0
based on 1 review
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.3
$599.99 at PSSL.com - ProSound and Stage Lighting
Find it at Amazon
Find it at Ebay
$599.99
from 1 store
Pros
  • Easy to use (1)
  • Great sound quality (1)
  • Powerful (1)
  • Professional functions (1)
  • Versatile (1)
See less See more
Best Uses
  • Amateur recording (1)
  • Events (1)
  • Performances (1)
  • Professional recording (1)
Provided by PSSL.com - ProSound and Stage Lighting
Rackmount Gooseneck Light with purchase ($39.99 Value) Add item above to cart to receive free gift at checkout Yamaha P5000S Power Amplifier: Providing The "Loud" For Your LoudspeakersThe Yamaha P5000S and the other P-Series amps were designed to be the perfect mate for the popular Yamaha Club Series loudspeakers, but these high-wattage dynamos will bring any system to life. The P5000S offers big power output that matches the power handling capabilities of the Club Series Speakers, plus it's equipped with YS Processing (Yamaha Speaker Processing) to deliver a signal that is tuned to the needs of these loudspeakers. Every P-Series amp is equipped with this specially designed circuit that delivers output tailored to the specific response of the Club Series speakers for superior audio quality and performance. The P5000S features both XLR and 1/4-inch TRS inputs and Neutrik Speakon, phone plug and 5-way binding post outputs to make connections quick and easy. Other features include Yamaha's exclusive EEEngine technology which delivers high performance with exceptional efficiency, sweepable high and low pass filters for optimizing output to any loudspeakers, compact and durable 2U chassis and variable speed cooling fans. In a 4 ohm bridged application, the P5000S cranks out 2600 watts.Those on a budget will find the high power output and affordable prices deliver higher quality without putting a strain on funds. Further savings are realized with extremely efficient operation utilizing Yamaha's exclusive EEEngine technology which keeps operational costs down by significantly reducing AC power consumption and heat generation.The P5000S Power Amplifier can be used with any loudspeaker system, but if you're using our Club Series, they will provide power and performance tailored to deliver maximum performance from your system. In an 8 ohm stereo application power output per channel on the P5000S is 500 watts.Equipped with independent sweepable high and low pass filters on each channel, you can optimize output for subwoofer or full range systems to provide peak audio quality and performance from any speaker system you may be using. The P5000S is surprisingly light in weight, making transport and setup less strenuous. Even more amazing is the comparison in weight per watt when you look at the P5000S. The use of a switching power supply makes this model very lightweight while maintaining superior audio quality.To provide the most flexible connectivity possible, the P5000S is equipped Neutrik Speakon output jacks and 1/4-inch output jacks for each channel in addition to 5-way binding post. Channel inputs consist of both XLR and 1/4-inch TRS jacks.The P5000S' industrial design delivers a refined and impressive look with deep blue faceplates bordered in silver trim, handles, and mounts. The chassis is specially designed to provide added durability and strength. Continuously variable-speed fans mounted internally on either side of the front panel offer quiet, efficient cooling. Comprehensive protection consists of power on/off muting, DC detection, thermal protection, current limiting and a protective cover for the attenuators is also supplied.Features: Stereo mode: 4 ohms, 700 watts RMS x 2Stereo mode: 8 ohms, 500 watts RMS x 2Bridge mono mode: 4 ohms, 2600 watts RMSYS Processing for Club Series compatibilityEEEngineering keeps power consumption and heat generation downXLR and 1/4" inputsSpeakon and 5-way binding post outputsStereo or bridged-mono operationIndependent sweepable high/low pass filtersLightweight designSize: 18-7/8"w x 3-7/16"h x 17-15/16"d. Wt. 26.5 lbs.
Yamaha P5000S P-Series Power Amplifier Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jan 10, 2008
Yamaha P5000S P-Series Power Amplifier Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
BANG FOR YOUR BUCK
5.0
    Pros
  • Clear Sound
  • Easy To Use
  • Powerful
  • Professional Functions
  • Versatile
    Cons
  • None
    Best Uses
  • Amateur Recording
  • Events
  • Performances
  • Professional Recording
"As a professional DJ I work my equipment hard and long on a regular baises. This thing puts out mega power and does it all day and all night. I run 4 Yamaha S215V's with one and the sound is loud and clear with no signs of strain or overload. "
Was this Amplifier, Receiver & Equalizer review on the Yamaha P5000S P-Series Power Amplifier helpful to you?
Jan 10 2008
DJ LEE
Lafayette,LA.
I am:
  • Experienced
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
