Yamaha MCR-E810 Silver CD/DVD Receiver Micro Component System
4.8
based on 5 reviews
Ratings Distribution
5 star
4
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.1
More Images
Pros
  • Attractive design (4)
  • Easy setup (4)
  • Great sound quality (4)
  • Simple / intuitive controls (3)
  • Powerful (2)
See less See more
Cons
  • Cddvd loading time (1)
Best Uses
  • Audiophiles (3)
  • Large rooms (3)
  • Smaller rooms / apartments (3)
  • Office (2)
  • Basic systems (1)
  • Basic use (1)
Provided by OneCall
High Sound and Picture Quality
Superior Design and Parts
The MCR-E810 has a high sound quality design that takes advantage of Yamaha's legendary audio technologies such as 60W x 2 discrete configuration power amps and speakers made of finely tuned cabinets and equipped with carefully selected units. This system also includes a high picture quality progressive compatible CD/DVD player.
It has a discrete construction that precisely places each carefully selected part without dependency on IC chips. The amplifier uses all analog circuits, including the volume section.
While it is compact, it includes high sound quality measures scrupulously designed in every detail: a large power supply transformer, high sound quality parts groups (including new capacitors), a high stiffness body with an octagonal section that is resistant to resonance, and large speaker terminals compatible with banana plugs*.
Speaker Cabinet Has New Design with Innovative Cross-Bracing
The cabinet is built with internal crossbracing having a unique wedge structure. R-beveling reduces diffraction effects. This type of cross-braced structure is used in top class speakers and Yamaha engineers are able to make the most of its advantages. It produces a tighter sound and the increased strength cuts down unwanted vibration.
Linear Damping
Yamaha's Linear Damping maintains a high, stable damping factor even at frequencies from 10Hz to 20kHz, where it generally tends to fall off. The result is superior articulation of all sounds.
Cosmetic Design
Simply, Cosmetic Design Concept
This system provides HiFi component-like design that same dedication to sound and design excellence is behind the creation of the top-class component.
Beautiful Yamaha Piano Finish Speakers
As the world's leading piano manufacturer, Yamaha has a long history of woodworking expertise. The MCR-E810 speakers have the same luxurious and environmentally friendly finish as our grand pianos.
Advanced Features
Easy Operation with GUI (Graphical User Interface)
A user-friendly GUI makes operation extremely simple by displaying clearly understandable menus right on the TV or monitor screen. You can use the remote control to select and adjust any function.
40-Station AM/FM Random Access Preset Tuning
In addition to utilizing a Direct PLL IF Count Synthesizer Tuning system, this model also makes station selection easy. Users can preset as many as 40 stations for instant one-touch tuning, and with each one the tuning mode (auto or manual) is also memorized.
Subwoofer Out
The Subwoofer Out terminal outputs bass frequencies so you can connect a subwoofer. Adding a subwoofer to your system pays big dividends: not only do you get bigger and better bass sound, but the overall sound field has much greater depth and presence.
CD Digital Video
DVD Players equipped with CD Digital Video capabilities will be able to play video and sound media that has been compressed together and recorded onto a CD disc.
DVD Video
DVD is essentially a large capacity optical video storage media that contains movies or other video content for home entertainment. DVD has become the standard for video publishing by most movie and video studios.
Video CD
DVD Players equipped with Video CD capabilities will be able to play video and sound media that has been compressed together using the MPEG 1 standard, and recorded onto a CD disc.
Dolby Digital
The most popular 5.1-channel home theater sound system. An improvement over Dolby Pro-Logic in that it offers: 1) Full frequency response in all channels (3Hz — 20kHz), 2) discrete surround channels, and 3) a separate track for bass only, called the Low Frequency Effects channel.
DivX
DivX is the video compression codec developed by DivX Networks and based on the MPEG-4 compression format. Its balance of high video quality and low bit rate has made it very popular and quickly established it as the best home video format thus far. The ability to play it on newer DVD models continues to add to its popularity as DivX Networks advances its support to many new household products. This compression technology has the potential for expanding the ways we view video media in much the way MP3 has given us many new ways to listen to music.
Specification Description
Model MCR-E810SL, MCRE-810SL
UPC 027108104751
Analog Audio (2) Rear Input
Analog Audio (3) Rear Output
Coaxial Rear Output
Compatible Formats CD
Compatible Formats CD-R
Compatible Formats CD-RW
Compatible Formats DVD
Compatible Formats DiVX
Compatible Formats JPEG
Compatible Formats MP3
Compatible Formats VCD
Compatible Formats WMA
Component Video Rear Output
Composite Video Rear Output
D/A Converter 24-bit/192kHz
Disc Player DVD Player - Single
Headphone Jack Front Output
iPod Dock Connector Rear Input
Magnetic Shielding Yes
Main Features DVD Player / Radio
Optical Rear Output
Play Modes Stereo (2 Channels)
Remote Control Included
S-Video Rear Input
Speaker Terminals Screw Type
Speaker Type 2-Way
Speaker Type Bass Reflex
Speakers 2
Speakers 60W x 2
Stereo Power per channel (Watts) 110
Subwoofer Out Rear Output
Surround Modes Dolby Digital
Tuner (40) Presets
Tuner AM
Tuner FM
Yamaha MCR-E810 Silver CD/DVD Receiver Micro Component System Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: MCR-E810 Silver CD/DVD Receiver Micro Component System
See all eBay results
  at eBay.com
Product Reviews
Last update: Oct 23, 2008
Yamaha MCR-E810 Silver CD/DVD Receiver Micro Component System Reviews
Displaying 1 - 5 of 5 Reviews
Show
Sort by
[4 of 4 customers found this review helpful]
Maybe Best Micro of all
5.0
"Yes, this Yamaha 810 may be the best micro out there. I have tried 2 Onkyo's and a Denin (this Denin is reputed to be the leader among micros). But neither of the Onkyo's or the Denin impressed me enough to buy. The lesser of the two Onkyo's was a little too tinny sounding and greater Onkyo has a …"  Read Full Review »
Was this Shelf System review on the Yamaha MCR-E810 Silver CD/DVD Receiver Micro Component System helpful to you?
 Report Abuse  (4)  (0)  0 comments
Dec 26 2006
Undisclosed
Reviewed at:
[1 of 2 customers found this review helpful]
YAMAHA MCR-E810SL
4.0
    Pros
  • Attractive Design
  • Easy Controls
  • Easy To Set Up
  • Great Sound
    Cons
  • CDDVD LOADING TIME
    Best Uses
  • Audiophiles
  • Basic Systems
  • Larger Rooms
  • Smaller Rooms
"I FIND THIS SYSTEM TO BE ALMOST PERFECT. I AM A MUSIC LOVER AND I FIND THAT THE FIDELITY OF THIS SYSTEM BRINGS OUT EVERY DETAIL OF THE MUSIC I PLAY. IT HAS EXCELLENT POWER CAPABILITIES FOR A COOL KRISP SOUND. THE LOOKS OF THIS SYSTEM ARE ALSO SUPERB. AFTER CHECKING OUT MANY SYSTEMS IN THE SAME CATEG …"  Read Full Review »
 Report Abuse  (1)  (1)  0 comments
Jun 13 2008
MIGUEL
SAN JUAN PUERTO RICO
I am:
  • Musically Inclined
Reviewed at:
Best mini-system on the market!!!!!
5.0
    Pros
  • Attractive Design
  • Easy To Set Up
  • Great Sound
  • Powerful
    Cons
  • NONE
    Best Uses
  • Audiophiles
  • Basic Use
  • Larger Rooms
  • Offices
  • Smaller Rooms
"I am blown away by the crisp, rich, full sound from this baby. I got the subwoofer which adds a nice punch to the low end. The system still sounds great without it. I checked them all. This is the best HANDS DOWN sound you can buy in theis price point. "
Oct 23 2008
Jason
Boston
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
[1 of 1 customers found this review helpful]
It doesn't get any better than this!!!!!
5.0
    Pros
  • Attractive Design
  • Easy Controls
  • Easy To Set Up
  • Great Sound
  • Powerful
    Cons
  • None
    Best Uses
  • Audiophiles
  • Larger Rooms
  • Offices
  • Smaller Rooms
"When it comes to sound, QUALITY makes a huge difference between utter bliss and dissapointment. This mini system is absolute pleasure!! I hooked it up with a YST subwoofer and it sounds as good as a system costing thousands more. "
 Report Abuse  (1)  (0)  0 comments
Oct 10 2008
Jason
Boston
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Wonderful Sytem!
5.0
    Pros
  • Attractive Design
  • Easy Controls
  • Easy To Set Up
  • Great Sound
    Cons
  • None
    Best Uses
  • None
"This is an wonderful system. The sound is impeccable for such a compact device. Couple this with a subwoofer and it will very much compliment your HDTV. "
Aug 10 2008
Karen
Baton Rouge, LA
I am:
  • Technically Challenged
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
