Yamaha DVD-S1700 DVD-A/SACD Progressive Scan Universal DVD Player
#5
4.5
based on 16 reviews
from $99.88
Ratings Distribution
5 star
9
4 star
6
3 star
1
2 star
0
1 star
0
Category Average
3.6
$99.88 at OneCall
Find it at Amazon
Find it at Ebay
More Images
Pros
  • High quality picture (14)
  • Easy to use (12)
  • Consistent performance (11)
  • Easy setup (11)
  • Attractive design (3)
  • Compact (1)
  • Durable (1)
  • High quility (1)
See less See more
Cons
  • Inconsistent (1)
  • No eject button on remote (1)
  • No eject on remote (1)
  • Slow to load (1)
Best Uses
  • Home (9)
  • Home theater (5)
  • Bedroom (3)
  • Office (2)
  • Critical listening (1)
  • My music room (1)
Provided by OneCall
High Sound and Picture Quality
Noise shaped Video(TM) and DCDi Progressive Scanning
This technology, from Analog Devices, uses oversampling and advanced techniques such as multi-bit sigma-delta processing and bit-shuffling to improve converter performance by moving converter noise to an area of the spectrum where it can be removed by an analog filter. This improves the accuracy of signal representation, allowing images to be displayed at much higher resolutions.
Other advanced technologies used to maximize image quality are Faroudja DCDi Processing, Motion Adaptive Noise Reduction, Cross Color Supression, Aspect Ratio Conversion and TrueLife Enhancer.
216 MHz/12-Bit Video DAC
This new high performance video DAC ensures superior image quality with all video sources.
High Sound Quality
Exceptionally Good sound Quality
This model delivers sound quality that is superior even to some more expensive players. It uses a high performance 192kHz/24-bit audio DACs.
Audio Direct Mode
Selecting the Audio Direct mode cuts the video circuitry out of the signal path, so there is no chance of it affecting the sound quality. The front panel illumination is also turned off to prevent noise interference from the LCD.
Advanced Features
Bass Management
This player provides Bass Management processing and a subwoofer/bass management output terminal. Bass management is important for DVD Audio and Super Audio CD multichannel playback, as it properly routes the bass frequencies for best performance from a multi-speaker home theater system. With normal 2-channel (stereo) CDs, the bass frequencies are routed to the subwoofer, so you can enjoy 2.1 channel sound with more powerful bass.
RS-232C Interface
An RS-232C interface is provided so this player can be controlled via computer in a custom installation.
On-Screen Display with GUI (Graphical User Interface)
This model makes operation extremely simple by displaying a variety of clearly understandable GUI menus right on the TV or monitor screen. It's easy to select and adjust any desired function with the remote control.
Three Wide Screen Modes
Three modes can be selected for optimum viewing on widescreen monitors via HDMI output: Non-Linear Stretch, Pillar Box and Zoom. Non-Linear Stretch helps minimize distortion of a 4:3 picture by trimming the top and bottom to make it closer to a 16:9 picture.
HDMI
High Definition Multimedia Interface (HDMI) is the first and only digital interface to combine uncompressed high-definition video, multi-channel audio and intelligent format and command data in a single digital interface. HDMI switching, providing the most advanced method of delivering high quality video signals to a home theater system to enable the reproduction of DVD and satellite TV sources with HD quality. HDMI can also send the digital audio signals from sources such as DVD Audio, CD, Dolby Digital and DTS to provide simple components connections.
DVD-Audio / Super Audio CD Ready
DVD-Audio is an extension of the highly popular DVD format, distinguished by its capability to deliver high quality multi-channel audio capability previously unavailable in traditional packaged audio media.
Super Audio CD
DVD Players that support Super Audio CD use a technology called Direct Stream Digital (DSD) to convert music into a digital signal that can be stored on a disc. Compared to the traditional PCM method (the technology used for CD), DSD offers a much higher resolution by following more closely the original waveform of music. With a frequency response of over 100kHz and a dynamic range over 120dB across the audible frequency range - some 64 times higher resolution then CD - Super Audio CD offers music reproduction that reveals details you just can`t hear on a normal CD.
DCDi TM (Directional Correlational Deinterlacing)
Invented and patented by Faroudja, Directional Correlational De interlacing (DCDi), virtually alleviates jagged oblique lines that appear when standard interlaced video is viewed on progressive scan displays, enabling the reproduction of beautiful, natural-looking moving images.
NSV
This technology, from Analog Devices, uses oversampling and advanced techniques such as multi-bit sigma-delta processing and bitshuffling to improve converter performance by moving converter noise to an area of the spectrum where it can be removed by an analog filter. This improves the accuracy of signal representation, allowing images to be displayed at much higher resolutions.
Dolby Digital
The most popular 5.1-channel home theater sound system. An improvement over Dolby Pro-Logic in that it offers: 1) Full frequency response in all channels (3Hz — 20kHz), 2) discrete surround channels, and 3) a separate track for bass only, called the Low Frequency Effects channel.
DTS Digital Surround
The basic DTS 5.1 channel sound format. Uses a higher data rate than Dolby Digital.
DivX
DivX is the video compression codec developed by DivX Networks and based on the MPEG-4 compression format. Its balance of high video quality and low bit rate has made it very popular and quickly established it as the best home video format thus far. The ability to play it on newer DVD models continues to add to its popularity as DivX Networks advances its support to many new household products. This compression technology has the potential for expanding the ways we view video media in much the way MP3 has given us many new ways to listen to music.
Video CD
DVD Players equipped with Video CD capabilities will be able to play video and sound media that has been compressed together using the MPEG 1 standard, and recorded onto a CD disc.
CD Digital Video
DVD Players equipped with CD Digital Video capabilities will be able to play video and sound media that has been compressed together and recorded onto a CD disc.
Specification Description
Model DVD-S1700, DVD-S1700BL, DVDS1700
UPC 027108925950
Coaxial Rear Output
Command / Control IR Input
Command / Control IR Output
Compatible Formats CD
Compatible Formats CD-R
Compatible Formats CD-RW
Compatible Formats DVD
Compatible Formats DVD Audio
Compatible Formats DVD+R
Compatible Formats DVD+RW
Compatible Formats DVD-R
Compatible Formats DVD-RW
Compatible Formats DiVX
Compatible Formats JPEG
Compatible Formats MP3
Compatible Formats SACD
Compatible Formats WMA
Component Video Rear Output
Composite Video Rear Output
D/A Converter 12-bit/216MHz
D/A Converter 192kHz / 24-bit
Depth (Inches) 11.2
Disc Capacity 1
HDMI Rear Output
Height (Inches) 3.4
Multi-Channel 7.1 Channel Pre-Out
Optical Rear Output
Power Supply 110 Volts AC
Progressive Scan Yes
Remote Control Included
RS-232C Rear In/Out
S-Video Rear Output
Surround Modes DTS
Surround Modes Dolby Digital
Type of DVD Unit Component DVD Player
Weight (Pounds) 13.9
Width (Inches) 17.1
Yamaha DVD-S1700 DVD-A/SACD Progressive Scan Universal DVD Player Questions
Questions and Answers
Where to Buy
$99.88
BizRate Rating Outstanding 9.1
Product Reviews
Last update: Oct 20, 2009
Yamaha DVD-S1700 DVD-A/SACD Progressive Scan Universal DVD Player Reviews
Most helpful positive review
Most helpful negative review
4.0
--- Quality product ---
"I am using this in my Home Theater setup. It is attached to my Yamaha Surround Sound system and I have a remote to control both. There are guides to get this working if you need help search google for your products... PROS- -Good solid product -Reads burned DVD+R's well -Reads burned CD-R's well -Reads DVD-R's with little or no issue CONS- -Sometimes has issue with DVD-R FINAL THOUGHT..." Read Full Review »
Oct 01, 2009 by xCOREx
See more positive Yamaha DVD-S1700 DVD-A/SACD Progressive Scan Universal DVD Player reviews
3.0
Great Picture, So-so Performance
"I bought two of these DVD/CD players due to their price and good ratings. They look nice, and are very easy to set up and use right out of the box. They're large, what you'd expect from a player with a DVD drawer and a CD drawer. The picture quality is great, but the oversampling leaves a lot to be desired. These players skip - a lot! And, when they do, they'll lock up and that's the last you'll be able to u..." Read Full Review »
Aug 31, 2009 by Unhappy Player
See more negative Yamaha DVD-S1700 DVD-A/SACD Progressive Scan Universal DVD Player reviews
Displaying 1 - 5 of 16 Reviews
Show
Sort by
4.0
    Pros
  • Consistent Performance
  • Durable
  • Easy To Set Up
  • Easy To Use
  • High Quality Picture
    Cons
  • None
    Best Uses
  • Home
  • Home Theater
  • Office
PROS-
-Good solid product
-Reads burned …"  Read Full Review »
Was this DVD Player review on the Yamaha DVD-S1700 DVD-A/SACD Progressive Scan Universal DVD Player helpful to you?
Oct 1 2009
xCOREx
Milwaukee, WI
I am:
  • Enthusiast
Reviewed at:
3.0
    Pros
  • Easy To Set Up
    Cons
  • Inconsistent
    Best Uses
  • Home
"I bought two of these DVD/CD players due to their price and good ratings. They look nice, and are very easy to set up and use right out of the box. They're large, what you'd expect from a player with a DVD drawer and a CD drawer. The picture quality is great, but the oversampling leaves a lot to …"  Read Full Review »
Aug 31 2009
Unhappy Player
Miami, FL
I am:
  • Casual User
Reviewed at:
Price: $99.88
[2 of 2 customers found this review helpful]
Superior Audio & Video Performance
5.0
    Pros
  • Attractive Design
  • Easy To Use
    Cons
  • None
    Best Uses
  • Critical Listening
  • Home Theater
"After owning several DVD & CD decks over the years, I have pretty much seen and heard it all. This Yamaha DVD-S1700 is by far the best unit for the money. Even at full list price, it out-performs all within its price range. I had owned the legendary Yamaha CDC-845 in the late 90's and thought it was …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Sep 6 2009
DJ Red
Clearwater, FL
I am:
  • Enthusiast
Reviewed at:
Price: $99.88
A QUALITY DVD PLAYER
5.0
    Pros
  • Attractive Design
  • Easy To Set Up
  • Easy To Use
    Cons
  • None
    Best Uses
  • Home
"THIS DVD PLAYER HAS A QUALITY APPEARANCE IN ITS BUILD AND STYLISH DESIGN, AND, SO FAR, ITS DEPENDABLE AND CONSISTENT PERFORMANCE, ITS EASE OF USE, AND VERY GOOD IMAGE AND AUDIO PRODUCTION. MY OLDER MODEL ANALOGUE TV ONLY ACCEPTS COMPOSITE CABLES, SO I HAVEN'T BEEN ABLE TO USE AND EXPERIENCE THE DVD …"  Read Full Review »
Sep 13 2009
GEORGE
TEXAS
I am:
  • Casual User
Reviewed at:
Price: $99.88
WOW What A Suprise!
5.0
    Pros
  • Attractive Design
  • Easy To Set Up
  • Easy To Use
    Cons
  • None
    Best Uses
  • Bedroom
  • Home
"Here I am again reviewing an excellent piece of equipment. I never thought that this Universal DVD player would sound this good in 2 channel stereo and sacd. I have used alot of other brands but so far the Yamaha sounds the best out of all of them. For the price it is unbeatable in every aspect. I w …"  Read Full Review »
Aug 4 2009
Levi
Cathedral City, CA
I am:
  • Enthusiast
Reviewed at:
Price: $99.88
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
