Yamaha DV-S5860 DVD Player
#15
4.4
based on 11 reviews
Ratings Distribution
5 star
7
4 star
2
3 star
1
2 star
1
1 star
0
Category Average
3.6
$39.99 at Your Electronic Warehouse
Find it at Amazon
Find it at Ebay
$39.99
from 1 store
More Images
Pros
  • Consistent performance (11)
  • Easy setup (10)
  • Easy to use (9)
  • High quality picture (7)
  • Durable (4)
  • Compact (2)
  • Attractive design (1)
  • Great sound quality (1)
  • High quality dac (1)
  • Plays all formats (1)
See less See more
Cons
  • Not enough connection options (2)
  • Needs better design (1)
Best Uses
  • Home (8)
  • Home theater (4)
  • Dorm room (3)
  • Bedroom (1)
  • High end audio system (1)
  • Low-end audiophile setup (1)
  • Office (1)
Provided by Beach Audio
If you're looking for a new DVD player that can grow with you and your family then the Yamaha DV-S5860-B DVD Video/Audio Player with Built-in Dolby Digital & DTS deserves a closer look.
This DVD player is so much more, offering you the flexibility of playing a wide variety of discs. You're not limited to DVDs either, with the Yamaha S5860 you can listen to your favorite audio CDs with top quality audio performance. Or take it even further and view your family photos in JPEG form on your home television set with a soundtrack provided by your favorite MP3 songs. It's top of the line technology today that everyone will be using tomorrow.
You not only get some of the best audio and video that Yamaha can provide but you also get some features that every family will adopt and fall in love with. Control your family's viewing habits as you deem appropriate with child locks and parental controls. Use sleep timers to your advantage, automatically turning off the DVD when their viewing time is over. Use repeat play and program play features to review footage for educational or entertainment purposes.
The DV-S5860 is really a DVD player that's in it for the long haul, providing top quality performance and features that will last through the latest technological craze.
Slide Show
Create your own home slides shows with JPEG and MP3 simultaneous playback. Pick your favorite JPEG images and then select your favorite songs and transfer them to an MP3 format and you've got the perfect soundtrack to go with your pictures.
Resume Play
Save your spot on up to 5 discs and then return to the exact spot when you're ready to begin watching again. This is a perfect feature for people with children who are often distracted.
Multiple Repeat and Program Play
If you'd like to review a particular part of a DVD set the repeat functions and see only those parts you need, over and over again. Or if you have little ones you can set a learning schedule for them and program in the DVD segments you want them to be focusing on for the day.
Child and Parental Locks
Whether you want to prevent your children from messing with the equipment entirely or you just want to limit their viewing, Yamaha has worked out all the details for you. Control locks help you decide what and when your family should watch.
Yamaha DV-S5860 DVD Player Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 21, 2009
Yamaha DV-S5860 DVD Player Reviews
Most helpful positive review
Most helpful negative review
5.0
Awesome sound for a budget priced player
"Purchased this unit to replace a cheap Memorex DVD player that I use for just playing CD's. First I bought a refurbished Denon from another website. It worked for 1 day! Exchanged it for another one, but I found out that it really didn't sound any better than the Memorex....very disappointing. I was starting to think it was the amplifier....bad tubes maybe? Found Y.E.W. through a search engine and I decided to t..." Read Full Review »
Apr 17, 2009 by TubeHead Johnny
See more positive Yamaha DV-S5860 DVD Player reviews
3.0
Your basic DVD player
"This is your basic dvd player. Nothing more, nothing less. Makes a good secondary dvd player for anything but your main system, unless you just want a basic unit to replace that old VCR...." Read Full Review »
Jul 11, 2008 by Computer Guy
See more negative Yamaha DV-S5860 DVD Player reviews
Displaying 1 - 5 of 11 Reviews
Show
Sort by
5.0
    Pros
  • Compact
  • Consistent Performance
  • Easy To Set Up
  • Easy To Use
  • High End Sound Quality
    Cons
  • None
    Best Uses
  • High End Audio System
  • Home
"Purchased this unit to replace a cheap Memorex DVD player that I use for just playing CD's. First I bought a refurbished Denon from another website. It worked for 1 day! Exchanged it for another one, but I found out that it really didn't sound any better than the Memorex....very disappointing. I was …"  Read Full Review »
Was this DVD Player review on the Yamaha DV-S5860 DVD Player helpful to you?
Apr 17 2009
TubeHead Johnny
Schenectady, The Electric City, New York
I am:
  • Power User
Reviewed at:
Price: $39.99
another great purchase
4.0
    Pros
  • Easy To Set Up
  • Easy To Use
  • High Quality Picture
    Cons
  • No HDMI output
    Best Uses
  • Home
"Another great product from Yamaha. I purchased this DVD player to use with the rest of my Yamaha equipment in my home theater. The first thing I noticed was the sound difference. The sound quality is amazing. The only low is the fact it doesn't have an HDMI output, which for me running it on my proj …"  Read Full Review »
Oct 21 2009
Denny
Flint, MI
I am:
  • Enthusiast
Reviewed at:
Price: $39.99
Need a SACD/ DVD-Audio player quick?Buy!
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Easy To Use
  • High quality DAC
  • More »
    Cons
  • No HDMI output
    Best Uses
  • Dorm Room
  • Home
  • Low-end Audiophile setup
"If you need a universal HD-audio player, this is it. Sure, it isn't a dedicated SACD player, but it plays them well. It also upconverts CD audio. Overall it is a *clear* well built audio player. I am not using it for video, so unfortunately I can't comment on that aspect. "
May 2 2008
Chris
Corona, CA
I am:
  • Gearhead
  • Poor Audiophile student
Reviewed at:
Price: $39.99
Amazing Value for DVD-A and SACD
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Easy To Use
    Cons
  • None
    Best Uses
  • Home
  • Home Theater
"Amazing sound quality as well as picture quality, the mere fact that it handles both high def audio sources is reason enough to buy it, and it does them justice!!! Highly Recommended!! "
Feb 24 2009
The audiophile
Chicago, Illinois
I am:
  • Enthusiast
Reviewed at:
Price: $39.99
At this price, I bought a second one.
5.0
    Pros
  • Attractive Design
  • Easy To Set Up
  • Easy To Use
    Cons
  • None
    Best Uses
  • Bedroom
  • Dorm Room
  • Home
  • Home Theater
"I bought one a month ago, and then realized-at this price-I had to get one for the bedroom before they disappear...worthwhile investment. "
Jun 8 2009
Lord Malokai
Harrisburg, PA
I am:
  • Power User
Reviewed at:
Price: $39.99
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
