XM Satellite Radio, Inc. Xpress Satellite Radio FM Direct Adapter
#3
4.5
based on 12 reviews
from $19.99 - $49.00
Ratings Distribution
5 star
7
4 star
3
3 star
1
2 star
0
1 star
0
Category Average
4.2
More Images
Pros
  • Easy to install (7)
  • Easy to use (5)
  • Quality construction (2)
  • Brand spankin new (1)
  • Crystal clear reception (1)
  • Reliable reception (1)
  • Versatile (1)
See less See more
Best Uses
  • Car (6)
  • Music (2)
  • Convertibles (1)
  • Larger cars (1)
  • Luxury cars (1)
  • News (1)
  • Small cars (1)
  • Sports (1)
  • Sports cars (1)
  • Talk shows (1)
Provided by Beach Audio
  • Works with Xpress receiver (XMCK10A) and helps increase performance
  • Converts receivers internal wireless modulator into a wired FM modulator
  • Allows for hardwired power and ground
  • Specification Description
    Model AVXXMFM1, XMFM1
    UPC 044476030635
    Accessory Indicator Yes
    Benefits Allows you to hardwire your Xpress car kit for a clean install for increased audio performanceConverts receivers internal wireless mo
    Capacity UOM mAh
    Country Of Origin China
    Description Header Get better receiption and better sound.
    Display Catalog Number 55033904
    Manufacturer Labor Warranty 12
    Manufacturer Part Number XMFM1
    Manufacturer Parts Warranty 12
    MAP Price 24.95
    Model XMFM1
    Operating Temperature UOM ° F
    Product Type Car kits
    Receiver Required Yes
    Supported Languages English
    XM Satellite Radio, Inc. Xpress Satellite Radio FM Direct Adapter Questions
    Questions and Answers
    Where to Buy
    $23.75
    BizRate Rating Outstanding 9.4
    $24.99
    $10 Off Orders Of Orders Over $85 + Free Shipping
    $19.99
    Show all 11 stores
    _
    Product Reviews
    Last update: Sep 14, 2009
    XM Satellite Radio, Inc. Xpress Satellite Radio FM Direct Adapter Reviews
    Most helpful positive review
    Most helpful negative review
    4.0
    This Audiovox FM Direct ...
    "This Audiovox FM Direct Adapter was a replacement for my old XM in-dash modulator that quit working after 4 years. The Audiovox adapter is a small, light unit easily tucks away behind the dash, provided that you can wire-tie remaining wire slack together behind the dash. Once in place, the unit provides a strong, clean signal with crisp sound once a clean FM frequency is found. Unfortunately, the modulator is l..." Read Full Review »
    Aug 18, 2009 by Cruffler
    See more positive XM Satellite Radio, Inc. Xpress Satellite Radio FM Direct Adapter reviews
    3.0
    Will not work with all radios
    "This product uses the old style antenna connector if you have a dodge product that uses a diffrent antenna connector you will have to find or make some kind of adapter to get this to work..." Read Full Review »
    Dec 28, 2008 by Gluey
    See more negative XM Satellite Radio, Inc. Xpress Satellite Radio FM Direct Adapter reviews
    Displaying 1 - 5 of 12 Reviews
    Show
    Sort by
    4.0
    "This Audiovox FM Direct Adapter was a replacement for my old XM in-dash modulator that quit working after 4 years. The Audiovox adapter is a small, light unit easily tucks away behind the dash, provided that you can wire-tie remaining wire slack together behind the dash. Once in place, the unit prov …"  Read Full Review »
    Was this Satellite Radio Accessory review on the XM Satellite Radio, Inc. Xpress Satellite Radio FM Direct Adapter helpful to you?
    Aug 18 2009
    Cruffler
    Columbia, SC
    Reviewed at:
    Price: $29.99
    Excellent product! Easy to install!
    5.0
      Pros
    • Easy to Install
    • Easy To Use
    • Versatile
      Cons
    • None
      Best Uses
    • Convertibles
    • Larger Cars
    • Luxury Cars
    • Small Cars
    • Sports Cars
    "This product was a breeze to install and once it was hooked to the car's antenna, it gave a clear signal with no static. Adding this product to my existing XM system took only minutes to complete and the result was very pleasing. Now, having my XM Radio hooked directly to my stereo makes listening …"  Read Full Review »
    Oct 21 2008
    Jon the Pharma Salesman
    Provo, UT
    I am:
    • Commuter
    Reviewed at:
    Best Price Around
    5.0
      Pros
    • BRAND SPANKIN NEW
    • Easy To Install
      Cons
    • NO CONS
      Best Uses
    • Car
    • Music
    "Simple and Easy to Install, I looked everywhere on the Web and nobody came close to matching the price. I would recommend this product to everyone that owns a Audiovox XM Satellite Radio. This Device guarantee's a perfect connection with your cars stereo. "What a Bargain" "
    Jan 25 2008
    bigaj49er
    Salt Lake City, Utah
    I am:
    • Audiophile
    • Professional
    • Tech Savvy
    Reviewed at:
    Price: $23.75
    A breeze to install
    5.0
    "If you can get to the back of your radio, then this is a breeze to install. My old XM radio would only work on 6 stations and if they were all occupied then I couldn't listen to XM. This overrides that! XM will take over the frequency and no bleedovers! No more cords hanging, everthing neatly tucked …"  Read Full Review »
    Nov 6 2009
    scubafitz
    Tulsa
    Reviewed at:
    Price: $29.99
    Works Well
    5.0
      Pros
    • Easy To Install
    • Easy To Use
    • Quality Construction
      Cons
    • None
      Best Uses
    • Car
    • Music
    • News
    • Sports
    • Talk Shows
    • More »
    "I use the device to put digital Satallite Programming on R V Radio and Car Radio.
    Works perfectly "
    Aug 1 2009
    Rodger
    Western U S, Mostly Phoenix, Az. and L A
    I am:
    • Quality Oriented
    Reviewed at:
    Price: $24.99
    pages: 1 2 3 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
