Winegard ® MetroStar® Omnidirectional Antenna
#47
3.7
based on 37 reviews
Ratings Distribution
5 star
16
4 star
12
3 star
0
2 star
0
1 star
9
Category Average
3.6
Low Price:
$49.88 at Meijer.com
 Trusted:
$89.99 at RadioShack
Find it at Amazon
$49.88 - $89.99
from 2 stores
More Images
Pros
  • Easy setup (29)
  • Strong signal (21)
  • Durable (19)
  • Attractive design (13)
  • Fine-tuning (4)
  • Fair signal (1)
  • Good digital reception (1)
  • It is positive (1)
  • Looks like it might work (1)
  • Weak signal (1)
See less See more
Cons
  • Poor reception (10)
  • Flimsy (1)
  • Good product (1)
  • Highly directional (1)
Best Uses
  • Attic/roof mount (25)
  • Living room (7)
  • Bedroom (5)
  • Portable devices (3)
  • Small rooms (3)
  • 30 ft tower mount (1)
  • Above the roof (1)
  • City (1)
  • Trash can (1)
  • With a clear 360 view (1)
Provided by Meijer.com
For install and forget convenience, you can't go wrong with the amplified omnidirectional Winegard MS2002 HDTV antenna. It features a built-in preamplifier to boost signal strength - up to 6 times the received signal on VHF, 9 times on UHF. A good companion for digital satellite systems, it requires no rotator system. Easy to install with hand tools on any antenna mast or light-duty antenna mount, it comes with power supply, 6' TV set cable, hardware, and mounting bracket.
Specification Description
Model MS-2002, MS2002
UPC 615798306496
Accessory Indicator Yes
Benefits Features a 360° receive pattern for receiving signal in multiple directions without a rotorFeatures a built-in amplifier that pro
Capacity UOM mAh
Country Of Origin United States
Description Header Pull in that signal
Display Catalog Number 55030426
Manufacturer Labor Warranty 90
Manufacturer Part Number MS-2002
Manufacturer Parts Warranty 90
MAP Price 0.0
Model MS-2002
Operating Temperature UOM ° F
Product Type UHF/VHF
Supported Languages English
Winegard ® MetroStar® Omnidirectional Antenna Questions
Questions and Answers
Where to Buy
$49.88
$89.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Nov 15, 2009
Winegard ® MetroStar® Omnidirectional Antenna Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
5.0
A good buy!
"Works well temporarily installed on the 2nd floor, located near the ceiling just below the attic. Likely will work even better on the roof once I get it up there. First tried amplified rabbit ear antennas. The MS-2002 makes those a joke. more distant HDTV channels that, with the amplified rabbit ears formerly were "no signal" come in clear with the MS-2002. I am pleased with this product...." Read Full Review »
Jun 30, 2009 by rf-sprinter
See more positive Winegard ® MetroStar® Omnidirectional Antenna reviews
1.0
Reception Area Critical
"I tried to use the Omnidirectional antenna in a fringe signal area with negative results. Moved the antenna around to several places and found reception to be flaky at best. Installed it on the roof and it was awful, but leaned it against the house,gutter and it worked much better. Ended up putting it on a table inside of the house for now. Reception degraded when someone entered room or if a care drive by. Will..." Read Full Review »
Oct 26, 2009 by Schnep
See more negative Winegard ® MetroStar® Omnidirectional Antenna reviews
Displaying 1 - 5 of 37 Reviews
Show
Sort by
A good buy!
5.0
    Pros
  • Attractive Design
  • Easy To Set Up
  • Strong Signal
    Cons
  • none
    Best Uses
  • Attic/Roof Mount
"Works well temporarily installed on the 2nd floor, located near the ceiling just below the attic. Likely will work even better on the roof once I get it up there. First tried amplified rabbit ear antennas. The MS-2002 makes those a joke. more distant HDTV channels that, with the amplified rabbit ear …"  Read Full Review »
Temporarily installed on an old fan stand;
  • Using Product
Was this Antenna review on the Winegard ® MetroStar® Omnidirectional Antenna helpful to you?
 Report Abuse  (1)  (0)  0 comments
Jun 30 2009
rf-sprinter
Grand Rapids, MI
I am:
  • Power User
Reviewed at:
Price: $49.88
[8 of 8 customers found this review helpful]
Great Reception
5.0
"The manufacturer only suggests up to 40 miles reception. I am getting reception from a 350 kw digital station that is 61.4 miles from my home with a 100 signal strength. I am also getting reception from a 8.7 kw digital station that is 40.4 miles from my house with a 60 signal strength. This thing …"  Read Full Review »
 Report Abuse  (8)  (0)  0 comments
Dec 28 2008
Don
Columbus Mississippi
Reviewed at:
Price: $89.99
Very Happy Again!
5.0
    Pros
  • Attractive Design
  • Durable
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
  • Attic/Roof Mount
"This is the second one we purchased, this one for our home, the first one was for our office. We have been very pleased with both. We bought them to stop paying a monthly cable bill, to help ease some of the bills during this tough time in our economy. Your results will depend on your location in re …"  Read Full Review »
Nov 15 2009
Plumber in NC
Durham, NC
I am:
  • Casual User
Reviewed at:
Price: $89.99
Not Intended for use in your Area
5.0
    Pros
  • Attractive Design
  • Durable
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
  • Attic/Roof Mount
  • Bedroom
  • Living Room
"For everyone who has knocked this powerful little disk, I don't know what you were talking about. This thing works great! I installed this on my roof using a 10ft piece of conduit and chimney straps. Couldn't ask for anything more economical than this for watching your local channels. According …"  Read Full Review »
Nov 14 2009
Ranger Matt
Northern MN
I am:
  • Enthusiast
Reviewed at:
Price: $89.99
1.0
    Pros
  • Easy To Set Up
    Cons
  • Poor Reception
    Best Uses
  • None
"I tried to use the Omnidirectional antenna in a fringe signal area with negative results. Moved the antenna around to several places and found reception to be flaky at best. Installed it on the roof and it was awful, but leaned it against the house,gutter and it worked much better. Ended up putting …"  Read Full Review »
Oct 26 2009
Schnep
Rye, NH
I am:
  • Casual User
Reviewed at:
Price: $89.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
