Close Login Module
Join
Winegard HD-7084P HDTV High-Definition Antenna
4.3
based on 18 reviews
Ratings Distribution
5 star
10
4 star
6
3 star
0
2 star
1
1 star
1
Category Average
3.6
Pros
  • Easy setup (13)
  • Strong signal (13)
  • Durable (8)
  • Fine-tuning (7)
  • Attractive design (2)
  • Good instructions (1)
  • Signal (1)
See less See more
Cons
  • Bulky (3)
  • Poor reception (2)
  • Better directions (1)
  • No instructions in box (1)
Best Uses
  • Attic/roof mount (6)
  • Living room (4)
  • Bedroom (3)
  • All tvs (1)
  • Attic antenna (1)
  • Office (1)
  • Portable devices (1)
  • Small rooms (1)
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: HD-7084P HDTV High-Definition Antenna
See all eBay results
  at eBay.com
Product Reviews
Last update: Jul 15, 2009
Winegard HD-7084P HDTV High-Definition Antenna Reviews
Most helpful positive review
[19 of 19 customers found this review helpful]
Most helpful negative review
[0 of 1 customers found this review helpful]
5.0
The 7084 P ULTRA DEEP FRINGE ANTENNA
"Sold Winegard Antennas For 20 yrs. More expensive But you only install it once. Heavy made and thicker elements & double connections to take weathers power. This Antenna by any measure is the best made you can own. Also the kind of antenna you want for radio receiption as well. Like HD Radio!..." Read Full Review »
Oct 27, 2008 by BUCK
See more positive Winegard HD-7084P HDTV High-Definition Antenna reviews
1.0
poor uhf reception
"This antenna has decent vhf reception but pi## poor uhf reception. I wasted my money and then had to use a seperate uhf antenna with a splitter combiner to get high channels. Don't buy this , do research like I wish I had done...." Read Full Review »
Jun 16, 2009 by Learn from experience
See more negative Winegard HD-7084P HDTV High-Definition Antenna reviews
Displaying 1 - 5 of 18 Reviews
Show
Sort by
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Strong Signal
    Cons
  • none
    Best Uses
  • None
"Sold Winegard Antennas For 20 yrs. More expensive But you only install it once. Heavy made and thicker elements & double connections to take weathers power. This Antenna by any measure is the best made you can own. Also the kind of antenna you want for radio receiption as well. Like HD Radio! "
Was this Antenna review on the Winegard helpful to you?
 Report Abuse  (19)  (0)  0 comments
Oct 27 2008
BUCK
MUNCIE, INDIANA
I am:
  • Enthusiast
Reviewed at:
[15 of 15 customers found this review helpful]
Great antenna!
5.0
    Pros
  • Strong Signal
    Cons
  • None
    Best Uses
  • None
"I live 50-55 miles from the the TV towers with a hill in between. This antenna gets the job done with VHF-Hi and UHF digital HD direct reception. Previous antenna could not receive channel 8.1 (ABC)at all. This one gets it at 85-87 and all the other channels at 90+. No cut-outs during severe T-st …"  Read Full Review »
 Report Abuse  (15)  (0)  0 comments
Nov 6 2008
Radioman
Bartlesville, OK
I am:
  • Enthusiast
Reviewed at:
[2 of 2 customers found this review helpful]
Don't waste $$ on cheap plastic ones
4.0
    Pros
  • Durable
  • Strong Signal
    Cons
  • Bulky
    Best Uses
  • Attic/Roof Mount
"I purchased this antenna after many frustrating attempts to settle with low profile indoor plastic [...].The cons are:- HUGE: you need some serious height to your home to hide this sucker from the street- DOES NOT COME with proper mounting equipment, it is sold separately and is NOT easy to find, I …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jun 30 2009
zebraman
Upstate NY
I am:
  • Enthusiast
Reviewed at:
[3 of 4 customers found this review helpful]
[...] Top Quality product!
5.0
    Pros
  • Easy To Set Up
  • Fine-Tuning
  • Good instructions
  • Strong Signal
    Cons
  • None
    Best Uses
  • Bedroom
  • Living Room
  • Office
"The Winegard antenna arrived in a timely manner. The instructions (yeah... I read them) were easy to follow. The performance was even better than I expected. Forget those HDTV antenna packages. This does it all. I am in a mountainous area of Southern Oregon and never got reception like this. And I h …"  Read Full Review »
 Report Abuse  (3)  (1)  0 comments
Mar 13 2009
Pat Nolen
Grants Pass, OR
I am:
  • Enthusiast
Reviewed at:
Very Good
4.0
    Pros
  • Strong Signal
    Cons
  • None
    Best Uses
  • Bedroom
  • Living Room
  • Portable Devices
  • Small Rooms
"This is a good antenna I have it under some oak trees and it gets digital signal good I live about forty miles from the TV station here in Florida I get channel 4-1 4-2 4-3 7-1 7-2 7-3 7-4 7-5 12-1 12-2 17-1 17-2 30-1 30-2 and 47 most of the time I can get them with out turning the antenna.I purchas …"  Read Full Review »
Apr 19 2009
Tony
St Augustine Florida
I am:
  • Casual User
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Out Of Stock
$149.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
