Whistler XTR-690 SE Radar/Laser Detector
#39
4.0
based on 3 reviews
Ratings Distribution
5 star
0
4 star
3
3 star
0
2 star
0
1 star
0
Category Average
3.9
Low Price:
$149.00 at CRISP-DEALS
 Trusted:
$159.17 at pcRUSH
Find it at Amazon
$149.00 - $229.99
from 6 stores
More Images
Pros
  • Clear alert (1)
  • Easy to mount (1)
  • Good sensitivity (1)
  • Neat features or extras (1)
  • Versatile (1)
See less See more
Best Uses
  • Highway driving (1)
Provided by RadarBusters.com
Peace of mind is no problem with the Whistler XTR-690 SE Radar / Laser Detector. Drive with confidence thanks to this high-tech device, which utilizes all of the latest technology to bring you a ton of advanced features. High-performance detection, exclusive radar signature ID, three filtering modes, and 360-degree band coverage are all included in this unit, which features a sleek black body with a red text display. You'll love how easy it is to use ... and how much protection it offers.
Advanced Features of the Whistler XTR-690 SE
Ka Max Mode
The XTR-690 SE offers enhanced high performance coverage, with 360-degree perimeter band monitoring, X band, K band, and new and improved Ka Max monitoring with extra-high sensitivity.
Exclusive radar and laser signature IDs (RSID and LSID)
This feature gives you a unique signature ID for Ka band radar and laser transmissions. You'll receive detailed information each time the XTR-690 SE receives an alert from either Superwideband (Ka) or laser frequencies. RSID will indicate Ka 33.8, 34.0, 34.3, 34.7, or 35.5 on the display screen (these are the most common police speed radar frequencies). Similarly, LSID will indicate the pulses per second transmitted by speed lasers, and lets you lock out "false alarms" from things like cruise control systems, based on their pulse rates.
72-point digital compass
72 total points of reference make the digital compass built into the XTR-690 extremely accurate. To use, simply mount the unit inside your vehicle in a level position, away from other magnetic sources such as speakers. Select a clear area in which to park, such as a parking lot or field, and follow the directions in your owner's manual to calibrate the compass. Calibration will stay set even when the unit is removed from the vehicle, although you should recalibrate if you reposition the mounting bracket to another location.
Intellicord ready
This unit can accept the Intellicord (sold separately), which is a power cord that lets you remotely control your detector's settings.
Selectable Real Voice alerts
Real Voice alerts give you an audio vocal alert in addition to the simple band ID tones. The unit will say "X band" if an X-band signal is detected. This allows the driver to keep his or her eyes on the road and eliminates possible confusion caused by the use of tones to identify various signals. The Voice Alert is selectable. It also vocalizes safety warning messages and feature selections.
POP mode radar detection with twin alert low-profile periscopes
POP mode is a form of police radar gun developed several years ago in an attempt to offer radar that would defeat detectors. The transmissions from POP mode radar are much faster than those from typical radars, and are emitted in short bursts rather than long signals like those from typical radar. The XTR-690 can detect even the quick signals of POP mode radar in your area, and alert you in plenty of time. Flashing LEDs on the twin low-profile periscopes give you a visual warning, but can be turned off if you choose.
3 city modes and 1 highway mode
City mode helps reduce the interference and confusion that can be caused by things like automatic door openers, burglar alarm alerts, and other things that can cause your detector to react. While in city mode, the detector will provide an initial alert when signals are detected, and then remain quiet unless the signal strength increases. When and if the signal does increase, the unit will alert you again to notify you. This helps "weed out" other types of signals. In highway mode, the XTR-690 provides full audio and visual warning of all laser and radar signals and maintains full sensitivity at all times. Highway mode is the set default.
Quiet and Auto Quiet modes
Quiet Mode cancels audio during an alert for 20 seconds. After 20 seconds, two beeps are provided on any new alert, and then the unit will remain quiet after that. Auto Quiet reduces the audio to level 1 approximately five seconds after a signal is detected.
Radar Frequencies:
  • 10.500 - 10.550 GHz (X band)
  • 24.050 - 24.250 GHz (K band)
  • 33.400 - 36.000 GHz (Ka Superwideband)
Additional Specifications
  • Stay Alert setting asks you to push buttons in response to beeps to prove driver alertness
  • 3 filter modes provide extra filtering
  • Dim and dark modes for day or nighttime driving
  • Vehicle battery saver option with selectable times for shut-off
  • Safety Warning system keeps you informed of highway safety conditions by alerting you to ambulances, non-moving vehicles, and other road hazards
  • High-gain lens for increased field of view
  • Red text display
  • Windshield mounting bracket and power cord included
  • Measures 4.9L x 3.15W x 1.4H inches; weighs 6.5 ounces
  • Sleek black body color
  • 1-year manufacturer's warranty included
  • Laser wavelength: 905 +/- 10 nanometers
  • Operating temperature range of -10 C to +70 C (14F to 158 F)
  • Power requirements: operational 12 to 15 volts DC, 250mA nominal
  • Vehicle battery saver operates at 30mA nominal
Specification Description
Model WHIXTR690SE, XTR-690 SE, XTR-690se
UPC 052303404542
Brand Whistler
Dimensions 4.92L x 3.15W x 1.36H inches
Type Corded Radar Detectors
Weight 6.5 oz.
Whistler XTR-690 SE Radar/Laser Detector Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jul 13, 2009
Whistler XTR-690 SE Radar/Laser Detector Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
Veil Guy's Review of the 690SE
4.0
    Pros
  • Clear Alert
  • Easy To Mount
  • Good Sensitivity
  • Neat Features or Extras
  • Versatile
    Cons
  • None
    Best Uses
  • Highway Driving
"What Whistler has accomplished with the XTR-690SE in improved reception to Ka radar is nothing short of remarkable, especially when one considers that the retail price points have not increased over their previous models, as a consequence.With the introduction of these three new detectors, Whistler …"  Read Full Review »
Whistler XTR-690SE, Beltronics STi-R, Escort Passport 9500ci vs Stationery CO 34.7 Ghz Ka Radar
  • Rearling
  • Whistler
  • Made with Product
  • Escort
  • Beltronics
  • Ka
  • Radar
  • Ghz
  • Passport
  • 9500ci
  • STi-R
  • Instant-on
  • Using Product
  • 347
  • XTR-695SE
Was this Radar & Laser Detector review on the Whistler XTR-690 SE Radar/Laser Detector helpful to you?
Jul 10 2009
Veil Guy
Philadelphia, PA
I am:
  • Auto Professional
Reviewed at:
Price: $209.99
Nice Detector
4.0
"I did a long week trip with this Radar Detector (around 3000 Miles) and it saved me at least 10 to 15 times in NJ and NY area. Ka Band rocks on this. You will have enough time to respond and slow down on Hihways. "
Jul 13 2009
Radar User
KS
Reviewed at:
[1 of 1 customers found this review helpful]
Good entry level detector
4.0
"Great features
Great KA band range (Radar Signature ID can be very helpful in distinguishing real radar threats from fakes ones)
Average K band range
Average X band range
LASER detection: fantastic "
 Report Abuse  (1)  (0)  0 comments
Jul 11 2009
Evan
Texas
Reviewed at:
Price: $229.95
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
