Whistler ® PI-400W 400 Watt Continuous Power Inverter
#314
3.9
based on 7 reviews
Ratings Distribution
5 star
5
4 star
0
3 star
0
2 star
0
1 star
2
Category Average
4.3
Low Price:
$24.00 at Walmart
 Trusted:
$28.99 at MacMall
$27.99 at ClubMac
see all stores
$24.00 - $59.00
from 9 stores
More Images
Pros
  • Affordable (1)
  • Charges quickly (1)
  • Powerful (1)
See less See more
Cons
  • Noisy (1)
  • Short life (1)
Best Uses
  • Laptop computer (1)
  • Portable electronics (1)
Provided by Shoppers Choice
CONVERTS 12V DC TO 110V AC; 800W MAX POWER, 400W CONTINUOUS POWER; PLUGS INTO CIGARETTE LIGHTER SOCKET; DIRECT WIRE CABLES WITH CLAMPS; ELECTRONIC CIRCUIT PROTECTION; SMART SURGE CONTROL; VOLTAGE PROTECTION; OVERLOAD PROTECTION; SHORT-CIRCUIT PROTECTION; THERMAL CUTOFF; COOLING FAN; 40-AMP POWER REQUIREMENT SUBCATEGORY2: POWER INVERTERS.
Specification Description
Model 546200100, PI-400W, PI400W, WHIPI400W
UPC 052303403361
Accessory Indicator Yes
Benefits Smart Surge™ control uses microprocessor-controlled circuitry to maximize startup performanceShuts down whenever input voltage e
Capacity UOM mAh
Country Of Origin Taiwan
Description Header Power at your fingertips.
Display Catalog Number 55017276
Included in the Box 400W power inverterBattery cable
Manufacturer Labor Warranty 2
Manufacturer Part Number PI-400W
Manufacturer Parts Warranty 2
MAP Price 0.0
Model PI-400W
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Height 2
Product Length 6.35
Product Type Inverters
Product Weight 2
Product Weight UOM pounds
Product Width 5
Supported Languages English
Voltage Required DC 9.5-16V
Whistler ® PI-400W 400 Watt Continuous Power Inverter Questions
Questions and Answers
Where to Buy
$39.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$44.14
$24.00
Show all 9 stores
Product Reviews
Last update: Aug 26, 2009
Whistler ® PI-400W 400 Watt Continuous Power Inverter Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
[4 of 5 customers found this review helpful]
Buzzes
1.0
    Pros
  • Charges Quickly
  • Inexpensive
  • Powerful
    Cons
  • Noisy
    Best Uses
  • Laptop computer
  • Portable Electronics
"After about 15 min use, the unit began to buzz noticeably. I checked the fan carefully for obstruction and found none. I believe the noise is due to vibration from the powerful cooling fan, amplified by the aluminum case. The noise is not the whir of the fan but a higher pitched and annoying buzz.
…"  Read Full Review »
Was this Surge Protector review on the Whistler ® PI-400W 400 Watt Continuous Power Inverter helpful to you?
 Report Abuse  (4)  (1)  0 comments
May 25 2008
charlie
boston
I am:
  • Value Oriented
Reviewed at:
Price: $39.99
[2 of 2 customers found this review helpful]
Nosey Fan
1.0
    Pros
  • None
    Cons
  • Short Life
    Best Uses
  • None
"I used this to run my laptop to watch DVD's while traveling. The unit worked fine except for the nose of the fan, I had to put in under the seet so I could keep from being distracted while driving. Then after about 30 hours of use it just stopped working. Would not recommend this unit. "
 Report Abuse  (2)  (0)  0 comments
Jul 22 2009
Mark
SLC Utah
I am:
  • Quality Oriented
Reviewed at:
Price: $39.99
Before I bought this ...
5.0
"Before I bought this Inverter I went to the products home wabsite and was shocked at the MSRP by the Whistler company. It is much more then you'll pay for the exact model on this sitet. I did have some concerns about the ability to charge my Netbooks battery's which were unfounded. I purchased the 4 …"  Read Full Review »
Jun 11 2009
C. P. Luca
Undisclosed
Reviewed at:
The inverter was ...
5.0
"The inverter was purchased to replace a 150 watt one that came bundled with a 60 watt photovotaic set. Blade type fuses make it certain they can be replaced if needed. Those for the previous inverter were not available in the hinterlands. Definitely a great value. Will try it on my next trip to the …"  Read Full Review »
Aug 18 2009
Rex
Undisclosed
Reviewed at:
Bought it for an extended ...
5.0
"Bought it for an extended tenting trip out West and used it to recharge cell phones, laptop, and even make coffee. The only warning is to make sure that all the things you intent to run do not excede the wattage, in this case 400. I learned to read all those labels attached to the electric items. "
Aug 26 2009
TK
Undisclosed
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
