Westinghouse 26" Flat Panel LCD HDTV DVD Combo - SK26H570D
3.5
based on 4 reviews
Ratings Distribution
5 star
1
4 star
2
3 star
0
2 star
0
1 star
1
Category Average
4.0
More Images
Pros
  • Attractive design (2)
  • Bright image (2)
  • Fast setup (2)
  • Good connection options (2)
  • High resolution (2)
  • Reduced glare (2)
  • Simple controls (2)
  • Durable (1)
  • Good value (1)
  • Great dvd set-up easy (1)
See less See more
Best Uses
  • Home (2)
  • Movies (1)
  • Video (1)
Provided by Buzzillions.com
Westinghouse's PixelDirect technology delivers DVD Video to the screen using a direct and shortest path possible, using the least amount of signal Processing & AutoSource technology. In addition, the SK-26H590D incorporates the best of Westinghouse Digital proprietary technology including DayBright panel technology for stunning picture quality during the day or night and SpineDesign construction for easy cable access to your favorite gaming platforms. The SK-26H590D provide a rich array of connections including two HDMI, component, composite, S-video, one VGA, RF tuner, one SPDIF and Stereo out; quick 8-millisecond response time, an Advanced Calibration Menu that allows the User to make adjustments to the video settings and Preset Video Modes to give consumers the Option to select from a menu of customized viewing styles. Native Resolution: 1366 x 768
  • Aspect Ratio: 16:9
  • Brightness: (typical) 400 cd/m
  • Contrast Ratio: (min) 800:1
  • Horizontal & Vertical 160 Degrees Viewing Angle
  • Active Display Area: 22.6 x 12.7 inches
  • Response Time: 8 ms
  • Lamp Life: (min) 60,000 Hours
  • Compatible Modes: TV 480i, 480p, 720p and 1080i
  • Integrated ATSC, NTSC & ClearQAM Tuner
  • Preset Video Modes: Enhanced, Movie, Game & Sports
  • Screen Fit Modes: Standard, Fill & Overscan
  • Progressive Scan
  • 3D Noise Reduction
  • Inverse 3:2 Pull Down
  • De-Interlacing
  • 3D Adaptive Comb Filter
  • 2D OSD Graphics Engine
  • Selectable Color Temperature: 3 Presets
  • Wall Mount VESA: 75 & 100 mm
  • Anti-Tip Over/Theft Deterrent Bracket
  • Connectors: Antenna In (RF), 2 Video/S-Video, 2 YpbPr, 2 HDMI + L/R, D-Sub (VGA), PC Audio (mini), 5 Audio (Dual RCA), SPDIF Optical and AC Power
  • Dimensions: Width 26.0 x Height 19.8 x Depth 7.5 inches with stand / Width 26.0 x Height 18.0 x Depth 5.8 inches without stand
  • Weight: 31.0 pounds with stand / 28.8 pounds without stand
  • Specification Description
    Model 2031558, SK-26H570D, SK-26H590D, WESSK26H590D
    UPC 882777050408
    Aspect Ratio 16:9
    color null
    Combo Unit Built-in DVD Player
    HDTV Capable HD Tuner is included
    Resolution 1366 x 768
    Screen Format 16:9 Widescreen TV Imaging
    Screen Size 26"
    Screen Size (Inches/Diagonal) 26
    sku 58186
    skuprice 749.9900
    style WESSK26H590D
    taxable Y
    TV Type TV/DVD Combo
    Westinghouse 26" Flat Panel LCD HDTV DVD Combo - SK26H570D Questions
    Questions and Answers
    Where to Buy
    Amazon   at Amazon.com
    ebay
    eBay listings for: 26" Flat Panel LCD HDTV DVD Combo - SK26H570D
    See all eBay results
      at eBay.com
    Product Reviews
    Last update: Aug 20, 2008
    Westinghouse 26" Flat Panel LCD HDTV DVD Combo - SK26H570D Reviews
    Displaying 1 - 4 of 4 Reviews
    Show
    Sort by
    horrible company to deal with
    1.0
    "We purchased this TV and the picture was poor. We thought it was our cable so after working with the cable company found it was the TV. We called customer service and were told we had to SHIP the TV back to Westinghouse ($70). We were told that a NEW TV would be sent out. We were sent a REFURBIS …"  Read Full Review »
    Was this TV / DVD / VCR Combo review on the Westinghouse 26" Flat Panel LCD HDTV DVD Combo - SK26H570D helpful to you?
    May 21 2008
    dissatified
    seattle
    I am:
    • Professional
    WOW, What a bargain
    4.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Connection Options
    • Good Resolution
    • More »
      Cons
    • None
      Best Uses
    • Home
    "This A great LCD DVD TV. I gave it to my mentally challenged daughter for XMAS. We put it in her bedroom on the wall. it was an easy set-up. It has a great picture, great sound. I especially like the front loading DVD player,not a slide out. You can also change the viewing screen to 3 different size …"  Read Full Review »
    Jan 22 2008
    K the bargain hunter
    Newark, California
    I am:
    • Practical
    Reviewed at:
    great TV with a DVD player
    5.0
      Pros
    • Durable
    • Good Value
    • High Quality
      Cons
    • None
      Best Uses
    • None
    "This is a great flat screen tv with tons of adjustments that the owner can make - be sure to do so as I didn't really like the factory settings. DVD works great and the sound is amazing - only wish i had a bigger space to house it so I could have bought the size up! "
    Aug 20 2008
    Perry Mason fan
    Portland Oregon
    Reviewed at:
    Plays exactly as it is supposed to.
    4.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Resolution
    • More »
      Cons
    • None
      Best Uses
    • Home
    • Movies
    • Video
    "Bigger than my previous TV but takes up less room and has a DVD as a bonus without having to have extra equipment. "
    Jan 21 2008
    Joeshoes
    Sarasota, FL
    I am:
    • Gearhead
    • Tech Savvy
    Reviewed at:
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    ebay
      at eBay.com
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
