#1
based on 42 reviews
Ratings Distribution
| 5 star |
77 |
| 4 star |
31 |
| 3 star |
2 |
| 2 star |
1 |
| 1 star |
2 |
Category Average
$64.00 - $85.99
from 8 storesPros
Cons
Best Uses
Where to Buy
| No Tax Outside NY ends 09/09/15 |
BizRate Rating
Outstanding 9.7
BizRate Rating
Good 8.7
Product Reviews
"Great Price. Great Drive. [...] Good expansion for Win XP computers that use IDE drives - either as additional drive or replacement for C: drive. I have had good luck with WD products (and jr.com) over the years and will keep buying from both. FYI: If using as replacement on a Windows XP PC you may want to connect it as 2nd drive first, create a 135GB partition using the XP Disk Manager and format it as NTFS..." Read Full Review »
Oct 18, 2009 by CheapSkate2
See more positive Western Digital Caviar SE 500GB Internal EIDE Hard Drive - Retail Kit reviews
"Purchased HDD to replace a failed Maxtor. Two different computors failed to recognize it, regardless of the program strapping (Master/Slave/cable select) both primary and alternate. I called their tech support and after being asked if I had followed all the instructions (I had) then for its serial number was told that it was probably defective! I returned it to my store for a refund and bought a used 20GB HDD..." Read Full Review »
Oct 01, 2009 by Crash & Burn
See more negative Western Digital Caviar SE 500GB Internal EIDE Hard Drive - Retail Kit reviews
Displaying 1 - 5 of 42 Reviews
Western Digital Caviar SE 500GB Internal EIDE Hard Drive - Retail Kit Review
Pros
Cons
Best Uses
"Largest drive I could find for and IDE hookup on my FreeNAS home server. Works great, about a gazillion songs on it now, it has replaced my old 250gb Seagate, which bit the dust hard...just a tip to the uninitiated, or to the complacent, I've been both, and I've learned my lesson....Back Up Your Dat …" Read Full Review »
Pros
Cons
Best Uses
"recently purchased this to upgrade the storage of an old machine. The installation is very simple and took less than 5 minutes. The harddrive performs so far so good. The only thing pulls me back to give a five star is that the drive does not come with a data cable. "
Pros
Cons
Best Uses
"Great Price. Great Drive. [...] Good expansion for Win XP computers that use IDE drives - either as additional drive or replacement for C: drive. I have had good luck with WD products (and jr.com) over the years and will keep buying from both. FYI: If using as replacement on a Windows XP PC you …" Read Full Review »
Pros
Cons
Best Uses
"I installed the disk on my Windows Home Server (WHS), the system recognized it, formatted it, and it has been working since (~8 weeks). This is a great drive at a great price. Since I installed it, it has just been running and backing up my 7 other systems. Thanks. "
[2 of 2 customers found this review helpful]
Pros
Cons
Best Uses
"My older PC's harddrive died and I needed to find an older PATA/EIDE drive replacement. This drive is faster and quieter than my old EIDE. This unit is priced comparable to sata drives. (The WD packaging that this drive came in was well constructed for shipping.) "
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Outstanding 9.7
BizRate Rating
Good 8.7
BizRate Rating
Outstanding 9.0
BizRate Rating
Good 8.5
| Free Shipping on Orders Over $299 ends 07/03/14 |
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
