Close Login Module
Join
Western Digital 1TB Internal Serial ATA Hard Drive for Desktops (WD10000LSRTL)
#16
4.4
based on 46 reviews
Ratings Distribution
5 star
29
4 star
12
3 star
1
2 star
2
1 star
2
Category Average
4.3
$99.99 - $149.99
from 5 stores
More Images
Pros
  • Easy to install (15)
  • Fast (14)
  • Highly compatible (14)
  • Quiet (14)
  • Reliable (11)
  • Affordable (2)
  • Durable (2)
  • Fast connectivity (2)
  • 5 year warrenty (1)
  • High-capacity (1)
See less See more
Cons
  • Runs hot (3)
  • None that i'm aware (1)
  • Only says 3-year warranty (1)
Best Uses
  • High-end multimedia (15)
  • Multimedia (2)
  • Audio pro (1)
  • Back-up (1)
  • Digital photography (1)
  • Gaming (1)
  • Large photo files (1)
  • Large projects (1)
  • Main drive (1)
  • Photo storage (1)
Where to Buy
Show all 5 stores
Product Reviews
Last update: Oct 22, 2009
Western Digital 1TB Internal Serial ATA Hard Drive for Desktops (WD10000LSRTL) Reviews
Most helpful positive review
[5 of 5 customers found this review helpful]
Most helpful negative review
[0 of 1 customers found this review helpful]
5.0
1TB WD Black Caviar 3.5" is tops
"This drive is fast for copying large sets of data files from one drive to another. This price is reasonable also at less than [$]. I have over 1TB of photo data for which I do a double backup. These means that I need 6 data hard drives and when I reorganize my data as my photo files evolve, I need fast data movement and reliable drives. With Core i7 Windows machine, I am seeing about 70 MB/sec sustained copy..." Read Full Review »
Feb 25, 2009 by SilverEagle
See more positive Western Digital 1TB Internal Serial ATA Hard Drive for Desktops (WD10000LSRTL) reviews
1.0
Warranty discrepancy
"The Western Digital website lists this drive as having a 5 year warranty, as does the Best Buy website. When I registered the drive with Western Digital on the website it came back as a 3 year warranty. I then looked over the box and noticed the sticker on the bottom says 3 year warranty. I called Western Digital and they said there is some kind of problem, and will update my warranty information in the system...." Read Full Review »
Sep 25, 2009 by cwhamsun
See more negative Western Digital 1TB Internal Serial ATA Hard Drive for Desktops (WD10000LSRTL) reviews
Displaying 1 - 5 of 46 Reviews
Show
Sort by
5.0
    Pros
  • Easy To Install
  • Fast
  • Highly Compatible
  • Quiet
  • Reliable
    Cons
  • None
    Best Uses
  • Photo storage
"This drive is fast for copying large sets of data files from one drive to another. This price is reasonable also at less than [$]. I have over 1TB of photo data for which I do a double backup. These means that I need 6 data hard drives and when I reorganize my data as my photo files evolve, I nee …"  Read Full Review »
Was this Internal Hard Drive review on the Western Digital helpful to you?
 Report Abuse  (5)  (0)  0 comments
Feb 25 2009
SilverEagle
Huntsville, AL
I am:
  • Frequent User
Reviewed at:
Fast, Reliable, Easy Install & NOT $$$$$
5.0
    Pros
  • Easy To Install
  • Fast
  • Highly Compatible
  • Inexpensive
  • Quiet
  • More »
    Cons
  • None that I'm aware
    Best Uses
  • Digital Photography
  • High-End Multimedia
  • Storage Backups
"Drive was very easy to install and came with everything required! The drive is very fast and I'm using it as my primary data drive. It came with software that helps recognize and setup the drive (choice of partitions, bootable, operating system, etc...) as well as the cables to connect the drive t …"  Read Full Review »
Aug 30 2009
Barry
Wayne, NJ
I am:
  • Heavy Duty User
Reviewed at:
[1 of 1 customers found this review helpful]
Very Above Average 1 TB Harddrive
5.0
"This is my second hard drive from Western Digital.
Here are my explanations for my ratings.
Value for Price:
This is a very well priced hard drive. At only $99.99 dollars, this is great! Many hard drives between 320 GB's to 640 GB's can cost up to $80 dollars. (Some good ones that is) For only $1 …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Oct 17 2009
Blaqkie
San Francisco, California
Reviewed at:
Price: $99.99
Solid and Reliable
5.0
    Pros
  • Easy To Install
  • Fast
  • Highly Compatible
  • Quiet
  • Reliable
    Cons
  • None
    Best Uses
  • Gaming
"I have had this drive for a month, installed as an external file sharing drive on my home network to store video and other media files. It has worked continuously without a hiccup. Formatted for a Mac, initialization was quick and easy and the drive runs quiet and cool. I have no regrets choosing …"  Read Full Review »
Oct 2 2009
Jim
Okinawa, Japan
I am:
  • Heavy Duty User
Reviewed at:
I would buy this HD again.
4.0
    Pros
  • Easy To Install
  • Highly Compatible
    Cons
  • None
    Best Uses
"For the moment it is working ok. I will see how it would work in the future. "
Oct 14 2009
Rich
Rahway New Jersey
I am:
  • Heavy Duty User
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
