VTI BLE Series Adjustable Surround Sound Speaker Stands
#3
4.7
based on 46 reviews
from $105.00
Ratings Distribution
5 star
33
4 star
12
3 star
1
2 star
0
1 star
0
Category Average
4.4
Low Price:
$105.00 at Racks and Stands
$105.00 at CSN Stores
Find it at Amazon
More Images
Pros
  • Sturdy (34)
  • Easy setup (32)
  • Attractive design (30)
  • Quality mounting hardware (27)
  • Adjustable (1)
  • Good price (1)
  • Matches most funiture (1)
  • Nice matte black finish (1)
  • Reasonably priced (1)
See less See more
Cons
  • Hand knob could b sleeker (1)
  • Hiding cables is tough (1)
  • Poor quality hardware (1)
  • Pricey (1)
  • Sharp metal floor stakes (1)
  • Shows cables (1)
  • Speaker shelf too small (1)
  • Unattractive design (1)
  • Unstable (1)
Best Uses
  • Surround sound speakers (25)
  • Saving space (13)
  • Improving sound (7)
  • Back surround speakers (1)
  • Getting around obsticles (1)
  • Studio set up at computer (1)
Provided by CSN Stores
Sturdy iron construction helps these stands to support speakers of various sizes. With an excellent acoustic quality and classy appearance, VTI speaker stands are a tribute to form and function all while complementing the elegance of any home.
Features:
  • Black finish
  • Powder coated cast iron base with heavy gauge steel pillar
  • Comes with pads on top to secure speaker
  • Comes with carpet spikes
  • Adjustable Height Range: 33 3/4 - 59"
  • Base Plate Dimensions: 10 3/4 W x 11 1/2" D
  • Top Plate Dimensions: 6 1/2" W x 8" D
  • Maximum Weight Capacity: 40 lbs
  • Price is per pair
About VTI Manufacturing, Inc.
VTI Manufacturing, Inc. specializes in manufacturing entertainment and presentation furniture for home and office use. VTI speaker stands are all metal construction with cast iron base. Most of them offer filling and wire management capacity. The most of unique feature of VTI stands is the beautiful design, stability, sturdiness and durability. These speaker stands will beautifully augment your home theater experience and enhance the style of your home’s décor.
VTI BLE Series Adjustable Surround Sound Speaker Stands Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 13, 2009
VTI BLE Series Adjustable Surround Sound Speaker Stands Reviews
Most helpful positive review
Most helpful negative review
4.0
I Can Recommend These Stands
"These stands are very heavy and very sturdy. They have entrance and exit holes so you can hide the speaker wire going to the speaker. The only Con is that the speaker shelf is too small and the sticky pads that they give you to keep the speaker from sliding off of the shelf are less than adaquate if your speakers are bigger than the speaker shelf. I had a problem with one of the stands. When I opened the box I ..." Read Full Review »
Apr 01, 2008 by Doug the Duck
See more positive VTI BLE Series Adjustable Surround Sound Speaker Stands reviews
3.0
Adjustability is nice, quality lacking
"I bought these stands because they are height-adjustable and because the price was reasonable. When I put them together, I tightened one bolt that holds the stand to the base too much and stripped the bolt. That stand was so wobbly that I couldn't use it anymore. Be careful, the bolts are made of soft metal and can be damaged from overtightening very easily! Also note that if you raise these stands to their ..." Read Full Review »
Jun 21, 2009 by malusman
See more negative VTI BLE Series Adjustable Surround Sound Speaker Stands reviews
Displaying 1 - 5 of 46 Reviews
Show
Sort by
4.0
    Pros
  • Attractive Design
  • Easy Setup
  • Quality Mounting Hardware
  • Sturdy
    Cons
  • Speaker Shelf too Small
    Best Uses
  • Getting Around Obsticles
  • Saving Space
  • Surround Sound Speakers
"These stands are very heavy and very sturdy. They have entrance and exit holes so you can hide the speaker wire going to the speaker. The only Con is that the speaker shelf is too small and the sticky pads that they give you to keep the speaker from sliding off of the shelf are less than adaquate if …"  Read Full Review »
Was this Speaker Stand & Mount review on the VTI BLE Series Adjustable Surround Sound Speaker Stands helpful to you?
Apr 1 2008
Doug the Duck
Midwest City, OK
I am:
  • Tech Savvy
Reviewed at:
Price: $105.00
I will be ordering another pair
5.0
    Pros
  • Attractive Design
  • Easy Setup
  • Sturdy
    Cons
  • None really
    Best Uses
"Used stands for R/L Back Surround in 7.1 Audio/Home Theater set up. Purchased because of adjustable height. Put grommet on speaker wire before snaking wire up the pole and out the top and it won't be a problem. Run wire through hole in top plate and connect to speaker which makes for a stable soluti …"  Read Full Review »
Jan 18 2009
Ranger One
Boston, Ma.
I am:
  • Practical
  • Professional
  • Retired
  • Tech Savvy
Reviewed at:
Price: $105.00
The Perfect Adjustable Stand
5.0
    Pros
  • Attractive Design
  • Easy Setup
  • Sturdy
    Cons
  • None
    Best Uses
"These stands are rated to hold up to 40 pounds and my surround speakers weight in at 18 pounds each. This stand works perfectly in handling that weight. However, since the base is actually a bit smaller than advertised(which I feel takes away from making it a more stable stand), I put a 10 pound w …"  Read Full Review »
Oct 13 2009
ezdriver
College Park, MD
I am:
  • Movie Enthusiast
  • Practical
Reviewed at:
Price: $105.00
Excellent Speaker Stands
5.0
    Pros
  • Attractive Design
  • Easy Setup
  • Sturdy
    Cons
  • None
    Best Uses
"These speaker stands were perfect for my situation. The room for my home theater does not have the perfect wall set up(what room does for most people?) and with these stands I was able to raise them to the height I needed without feeling the speaker would fall off, place them anywhere I want to get …"  Read Full Review »
May 20 2009
Gill
Shawnee Mission, KS
I am:
  • Home Theater Enthusiast
Reviewed at:
Price: $105.00
3.0
    Pros
  • Adjustable
  • Easy Setup
  • Reasonably priced
    Cons
  • Unstable
    Best Uses
"I bought these stands because they are height-adjustable and because the price was reasonable. When I put them together, I tightened one bolt that holds the stand to the base too much and stripped the bolt. That stand was so wobbly that I couldn't use it anymore. Be careful, the bolts are made of …"  Read Full Review »
Jun 21 2009
malusman
Garden City, MI
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Price: $105.00
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
