Vivitar 285hv Flash W/vari Power *4aa
#20
4.2
based on 163 reviews
Ratings Distribution
5 star
74
4 star
68
3 star
8
2 star
2
1 star
11
Category Average
4.1
Low Price:
$89.00 at Adorama
 Trusted:
$89.95 at B&H Photo Video
Find it at Amazon
$89.00 - $89.95
from 2 stores
More Images
Pros
  • Consistent output (109)
  • Durable (94)
  • Fast recycling (62)
  • Easy to use (60)
  • Lightweight (49)
  • Powerful (34)
  • Versatile (30)
  • Quiet (21)
  • Easily interchangeable (16)
  • Easy to clean (15)
See less See more
Cons
  • Heavy / bulky (53)
  • Slow recycling (16)
  • Weak casing (8)
  • Large (2)
  • Not interchangeable (2)
  • Poor battery life (2)
  • Aux socket no good (1)
  • Bad customer service (1)
  • Big (1)
  • Bracket interface (1)
Best Uses
  • General purpose (103)
  • Portraits (91)
  • Night photography (50)
  • Fill flash (46)
  • Photojournalism (35)
  • Back-up (22)
  • Sports photography (21)
  • Macro (3)
  • Strobist (3)
  • Weddings (3)
Provided by Adorama
Specification Description
Model 233965
UPC 681066325919
Dedication Non-Dedicated
Guide Number ISO 100 Above 150
Vivitar 285hv Flash W/vari Power *4aa Questions
Questions and Answers
Where to Buy
$89.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$89.00
BizRate Rating Outstanding 9.1
Product Reviews
Last update: Oct 29, 2009
Vivitar 285hv Flash W/vari Power *4aa Reviews
Most helpful positive review
Most helpful negative review
[3 of 3 customers found this review helpful]
4.0
amature stobist at large
"I've been using this flash for a few weeks. I've been bouncing it off ceilings, shooting through and bouncing off Umbrellas.I've been using some [...]triggers with the flash and have had good results, just have to make sure the hotshoe or sync cable is connected good.I really like the adjustability. As in on the front it has a dial where you can adjust the output power. Note I haven't had much sucess with NiMH(r..." Read Full Review »
Jan 20, 2009 by pete25r
See more positive Vivitar 285hv Flash W/vari Power *4aa reviews
1.0
Fragile and undependable
"I bought 3 of these flashes on the overwhelming praise they receive here and on the Strobist site (which I imagine many of you reading this might be frequenters of). I also own a Canon 580EX and a 430EX, and was wanting to pad out my lighting kit with something cheaper and allegedly more durable. Upon receipt of my 3 Vivitar flashes, one of them failed immediately upon putting batteries into it (it would, oddly,..." Read Full Review »
Feb 05, 2008 by Mangosteen
See more negative Vivitar 285hv Flash W/vari Power *4aa reviews
Displaying 1 - 5 of 163 Reviews
Show
Sort by
4.0
    Pros
  • Consistent Output
  • Easy To Use
  • Fast Recycling
  • Lightweight
  • Powerful Output
    Cons
  • Bulky
    Best Uses
  • Fill Flash
  • General Use
  • Portraits
"I've been using this flash for a few weeks. I've been bouncing it off ceilings, shooting through and bouncing off Umbrellas.I've been using some [...]triggers with the flash and have had good results, just have to make sure the hotshoe or sync cable is connected good.I really like the adjustability. …"  Read Full Review »
shot into shoot through/bounce umbrella
  • Using Product
  • Made with Product
  • Picture of Product
Was this Camcorder Accessory review on the Vivitar 285hv Flash W/vari Power *4aa helpful to you?
Jan 20 2009
pete25r
Atlanta, GA
I am:
  • Semi-Professional
Reviewed at:
Price: $89.00
Great Flash For The Buck...
4.0
    Pros
  • Consistent Output
  • Durable
    Cons
  • Missing Eighth of Power
  • Slow Recycling
    Best Uses
  • Fill Flash
  • General Use
  • Night Photography
  • Photojournalism
  • Portraits
  • More »
"For the price nothing can beat 285HV. Built quality is really good, it is a surprise since it's design date back from the 70s. Built almost like a tank. It's a great sub for 430EX if you don't need the fancy E-TTL stuff. I hope Vivitar would never discontinue 285HV.
It's a simple no frill flash. …"  Read Full Review »
Crazy Haired Michelle...
  • Made with Product
  • Made with Product
Nov 11 2008
Yan Ardianto
McMinnville, OR
I am:
  • Professional
Reviewed at:
Price: $89.00
[7 of 7 customers found this review helpful]
New Ideas Come to Light
4.0
    Pros
  • Consistent Output
  • Durable
  • Easily Interchangeable
  • Great instructions
    Cons
  • Bulky
  • Heavy
    Best Uses
  • General Use
  • Portraits
  • Sports Photography
  • strobist
  • Studio
"The one area of photography I have avoided since the beginning, seven years ago, is flash photography. In fact, I refused to use flashes, I would disable the flash on my cameras instead opting for ISO 1600 or even blurry photos. You can only pass off photos filled with tracers as artistic so many …"  Read Full Review »
 Report Abuse  (7)  (0)  0 comments
Jul 23 2008
Comatosed[@]
South Korea
I am:
  • Semi-Professional
Reviewed at:
Price: $89.95
285 HV
5.0
    Pros
  • Consistent Output
  • Easy To Use
  • Fast Recycling
    Cons
  • Bulky
  • Weak Casing
    Best Uses
  • Macro Photography
  • Portraits
"The Vivitar 285HV is a great flash for its price!
I hear (well read actually)a lot of people complaining about the quality of the Chinese made ones. My copy works fine - great actually. I did a lot of extensive research before buying this flash being worried about the quality drop. After reading …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Dec 10 2008
Leo the Lion
Palo Alto, CA
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $89.95
1.0
    Pros
  • Lightweight
    Cons
  • Fallible internals
  • Weak Casing
    Best Uses
  • General Use
"I bought 3 of these flashes on the overwhelming praise they receive here and on the Strobist site (which I imagine many of you reading this might be frequenters of). I also own a Canon 580EX and a 430EX, and was wanting to pad out my lighting kit with something cheaper and allegedly more durable. Up …"  Read Full Review »
Feb 5 2008
Mangosteen
Wellington, New Zealand
I am:
  • Semi-Professional
Reviewed at:
Price: $89.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
