Visiontek 900095 Radeon X1300 256MB PCI
#356
3.8
based on 20 reviews
Ratings Distribution
5 star
8
4 star
5
3 star
4
2 star
1
1 star
2
Category Average
4.1
Low Price:
$92.65 at Buydig.com
 Trusted:
$119.99 at Dell
Find it at Amazon
$92.65 - $119.99
from 2 stores
More Images
Provided by MAGo Enterprise
MODEL- VTKX1300256PCIVENDOR- VISIONTEK FEATURES- xTASY RADEON X1300 256MB PCIStep-up to serious 3D performance and image quality with ATIs Radeon X1300 Series. For greatly enhanced visuals the Radeon X1300 combines a radically new and efficient 3D architecture with ATI's revolutionary Avivo video and display technology. The X1300 delivers superior visual performance for all types of PC entertainment and productivity.Whether upgrading your present PC graphics or buying a new PC the Radeon X1300 will easily handle todays graphics-intensive games digital entertainment and productivity software. Includes 256MB X1300 PCI Graphics Card Installation CD drivers demos utilities. * Advanced Multi-Display CapabilityVisionTek's Radeon X1300 PCI card brings advanced multi-display capabilities to your personal computer. Easily connect and run two (2) displays simultaneously using a single X1300 card from VisionTek. Achieve your maximum productivity by running two (2) separate applications when utilizing side-by-side dual monitors on your desk top. Add two (2) VisionTek X1300 PCI cards to your PC and manage four (4) or more monitors at once. * Brilliant New Avivo Video and Display TechnologyWith ATI's Avivo technology the X1300 connects to home entertainment devices and allows you to view your digital media and play games with vibrant colors ultra sharp images true-to-life image reproduction and the smoothest video playback ever offered by ATI. * A New Era of 3D Gaming Enjoy a smooth gaming experience and control texture-rich games with advanced 3D features including: a 90-nanometer process GPU a new ultra-threaded 3D processing architecture an advanced memory controller and 256MB DDR2 RAM. * Opening Doors to Visual Realism and True-to-life image Graphic Animation With industry leading 90-nanometer process technology and ultra-threadedshader core the X1300 is optimized for Shader Model 3.0 to deliver newhigh dynamic range visual effects enhanced adaptive anti-aliasing realism and lightening fast performance. -- SPECIFICATIONs ----------------------------------- INTERFACE/BUS - 32-bit PCI (3.3v) MEMORY - 256MB DDR2 SDRAM 533MHz Memory Clock CHIPSET- ATI RADEON X1300 450MHz VPU clock CONNECTORs - (1) 7-pin S-Video/Composite port (1) 15-pin VGA port (1) 24-pin DVI-I port DISPLAY SUPPORT- Dual Link DVI (up to 2560 x 1600 resolution) Component HDTV YPbPr output (adapter sold separately) S-Video & Composite Video TV-Out (cable sold separately) Dual VGA (with DVI to VGA adapter optional) REQUIREMENTS - Intel Pentium 4/III/Celeron AMD K6/Duron/Athlon/Athlon XP K8 or compatible with an available PCI slot. 256MB of system memory (512MB recommended) Installation software requires CD-ROM drive DVD playback requires DVD drive. 250 Watt power supply or greater recommendedor support@visiontek.com
Specification Description
Model 900095-, VTK X1300256PCI, VTKX1300256PCI, X1300256PCI
UPC 784090024107
Graphics Memory Size 256MB
Interface PCI
Package Type Retail
Processor Speed 400MHz
Visiontek 900095 Radeon X1300 256MB PCI Questions
Questions and Answers
Where to Buy
$119.99
$92.65
BizRate Rating Outstanding 9.1
Product Reviews
Last update: Dec 4, 2008
Visiontek 900095 Radeon X1300 256MB PCI Reviews
Most helpful positive review
[5 of 5 customers found this review helpful]
Most helpful negative review
[3 of 3 customers found this review helpful]
5.0
ATI Radeon x1300 256 PCI graphics card
"Pros This card works "GREAT" in the Dimension E310/3000! Easy to install on this system! Just follow (in the package) directions. Cons Just make sure you disable the "integrated video"! Additional Thoughts Price is not bad for the performance. Fun to do stuff yourself!..." Read Full Review »
Apr 27, 2007 by JsFrEeK
See more positive Visiontek 900095 Radeon X1300 256MB PCI reviews
3.0
Vista Home Premium on a Dimension 2400?
"Pros Works on Vista where built in Intel 845G/GL is not Vista compatable. Works flawlessly on XP even while using multiple monitors (3) Cons If running Vista you must use "Microsoft Corporation - WDDM" driver, ATI drivers barely function, are slow & "chunky" Additional Thoughts A great upgrade for use on XP, a functional upgrade on Vista. I have ben using mine since OCT 2006..." Read Full Review »
Feb 19, 2008 by Solitaire982
See more negative Visiontek 900095 Radeon X1300 256MB PCI reviews
Displaying 1 - 5 of 20 Reviews
Show
Sort by
5.0
"Pros
Cons
Additional Thoughts
Price is not bad for the performance. Fun to do stuff yourself! "
Was this Sound & Video Card review on the Visiontek 900095 Radeon X1300 256MB PCI helpful to you?
 Report Abuse  (5)  (0)  0 comments
Apr 27 2007
JsFrEeK
Eugene,Oregon
Reviewed at:
Price: $119.99
3.0
"Pros
Cons
Additional Thoughts
A great upgrade …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Feb 19 2008
Solitaire982
Tyndall, SD
Reviewed at:
Price: $119.99
[4 of 4 customers found this review helpful]
Radeon X1300 256 MB PCI Graphics Card
5.0
"Pros
Worked like a charm.
Cons
None
Additional Thoughts
The product was recommended by the Dell staff, which fortunately helped me avoid purchase of an alternative card which would not have worked in my particular Dell computer. Thank you support! "
 Report Abuse  (4)  (0)  0 comments
May 16 2007
Herb942
Granthan, NH
Reviewed at:
Price: $119.99
I wanted to spruce up my ...
2.0
"I wanted to spruce up my back up system, but only had the PCI slot for video. I figured I would just get the best PCI video card and know that older system was maxed out. I did a lot of research and decided on this card. The cold hard truth is that no card (by any manufacturer) is going to run we …"  Read Full Review »
Jul 9 2008
tbrown
Undisclosed
Reviewed at:
ok i bought this for my ...
3.0
"ok i bought this for my old Intel board because its all i could afford at the time. It works with vista. It gets a 3.0 at the install of vista. once you install the catalyst drivers it drops your ration to a 2.0 the card. I've owed the card for a year now. I'm finally sick of the nonsense with this …"  Read Full Review »
Jan 3 2008
rmach89
Undisclosed
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
