Visible Dust SD-800 Arctic Butterfly Pro Kit
#208
4.4
based on 18 reviews
Ratings Distribution
5 star
9
4 star
7
3 star
2
2 star
0
1 star
0
Category Average
4.2
Low Price:
$134.95 at B&H Photo Video
 Trusted:
$134.95 at Adorama
Find it at Amazon
$134.95
from 2 stores
More Images
Pros
  • Easy to use (13)
  • Lightweight (7)
  • Durable (4)
  • Reliable (4)
  • A must have (1)
  • Improves product function (1)
  • Works as advertised (1)
See less See more
Cons
  • Bulky (2)
  • Pricey (2)
  • No light (1)
  • Not functional (1)
Best Uses
  • Everyday (8)
  • Travel (6)
  • Home (3)
  • Studio (3)
  • Camera maintenance (1)
  • Landscapes (1)
  • Macro (1)
  • Portraits (1)
  • Sensor cleaning (1)
Provided by B&H Photo Video
The Visible Dust SD-800 Arctic Butterfly Pro Kit includes everything for the photographer with more than one camera in their arsenal. This kit includes everything a photographer needs for 'dry cleaning' the digital SLR sensor. Packed in the SD800 kit is the Arctic Butterfly 724 with an APS 1.6x size sensor brush (thick for heavy cleaning) a 1.0x-1.3x size sensor brush an angled mirror/focusing screen brush and a one-size-fits-all brush adapter for the Arctic Butterfly 724. The stylish Visible Dust Arctic Butterfly - 724 Rotary Sensor Brush is ideal for travel and for light dusting of the sensor. This version now has a durable plastic body with a contoured grip and a snap-on battery cover that makes changing batteries easy. The Arctic Butterfly - 724 does not require canned air for use and therefore this is not an issue with regards to travel security restrictions. The patented rotary action and self-charging of the spinning device makes cleaning convenient on location. The Arctic Butterfly does not replace a regular Sensor Brush which has more filaments and is better suited for heavier dusting.The Brite Vue Sensor Loupe from Visible Dust makes it easier then ever before to locate even the smallest dust speck without resorting to inspection of camera images through a computer monitor. Utilizing advanced features such as BriteVue XLT technology and 6 super bright LEDs the SensorLoupe is the only tool you need for locating debris on your sensor.
Specification Description
Model 3425966
UPC 827912060287
Select Brushes & Accessories
Visible Dust SD-800 Arctic Butterfly Pro Kit Questions
Questions and Answers
Where to Buy
$134.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$134.95
BizRate Rating Outstanding 9.2
Product Reviews
Last update: Nov 3, 2009
Visible Dust SD-800 Arctic Butterfly Pro Kit Reviews
Most helpful positive review
[5 of 5 customers found this review helpful]
Most helpful negative review
[1 of 1 customers found this review helpful]
5.0
Excellent
"I reviewed the loupe at its own site. It was excellent. I previously used the Visible Dust brushes and like them a lot but could not travel with compressed air to charge them. This system eliminated that problem by charging the brushes by spinning them. No more need for compressed air. They are very effective on sensor dust. Be very careful however to avoid touching the chamber walls where oil may be prese..." Read Full Review »
Aug 19, 2007 by Billy
See more positive Visible Dust SD-800 Arctic Butterfly Pro Kit reviews
3.0
Almost perfect
"We are on location 90% of the time. Lens changes are inevitable. The Nikon D3 is a dust magnet, nothing new there. We chose the Visible Dust system because the "trusted" reviews said it worked. It does work and work well. No complaints about fit or function. We chose the "Pro" kit for versatility, it gave us cleaning methods tailored to different sized sensors. We paid more than the best individual Arctic..." Read Full Review »
Aug 21, 2009 by Dutch
See more negative Visible Dust SD-800 Arctic Butterfly Pro Kit reviews
Displaying 1 - 5 of 18 Reviews
Show
Sort by
Excellent
5.0
"I reviewed the loupe at its own site. It was excellent. I previously used the Visible Dust brushes and like them a lot but could not travel with compressed air to charge them. This system eliminated that problem by charging the brushes by spinning them. No more need for compressed air. They are …"  Read Full Review »
Was this Camera Accessory review on the Visible Dust SD-800 Arctic Butterfly Pro Kit helpful to you?
 Report Abuse  (5)  (0)  0 comments
Aug 19 2007
Billy
Barrington IL
Reviewed at:
Price: $134.95
Almost perfect
3.0
    Pros
  • Reliable
    Cons
  • No light
    Best Uses
  • Studio
  • Traveling
"We are on location 90% of the time. Lens changes are inevitable. The Nikon D3 is a dust magnet, nothing new there. We chose the Visible Dust system because the "trusted" reviews said it worked. It does work and work well. No complaints about fit or function. We chose the "Pro" kit for versatil …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Aug 21 2009
Dutch
Dallas GA
I am:
  • Professional
Reviewed at:
Price: $134.95
Good Brush Set.
4.0
    Pros
  • Durable
  • Easy To Use
  • Lightweight
  • Reliable
    Cons
  • None
    Best Uses
  • Everyday use
"The Visible Dust Artic Butterfly brush set provides an effective way of collecting dust off the sensor in the occasional dust off and prior to cleaning. It has a novel way of eliminating static from the brush prior to dusting. The only negative is some brushes may need cleaning first off (just use t …"  Read Full Review »
Nov 2 2009
Fine Art Photographer
Sydney, Australia
I am:
  • Semi-Professional
Reviewed at:
Price: $134.95
Great Presentation...
3.0
    Pros
  • Easy To Use
    Cons
  • Not Functional
    Best Uses
  • None
"Out of the box this is an awesome product, at least presentationaly. I've written Visible Dust, will see what they say/how they handle it...
My experience is one of tragedy. The Arctic Butterfly brush was throwing bristles from the first moment power was applied.
The smaller sensor brush and …"  Read Full Review »
Jun 10 2008
SeraphicImago
Mid Missouri
I am:
  • Semi-Professional
Essential Kit
5.0
    Pros
  • Easy To Use
  • Lightweight
    Cons
  • None
    Best Uses
  • Camera Maintenance
"Bought this kit when my 20D finally accumulated enough sensor dust to be a problem. I have only had to use it once so far, and it performed as advertised. When combined with a sensor loupe, cleaning becomes easy. Simply spot the dust with the loupe, spin the brush, and swipe along the sensor. Af …"  Read Full Review »
Jul 16 2008
Oz bloke
Australia
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $134.95
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
