Viewsonic VX2835wm 28" LCD Display w/Integrated Speakers w/HDMI for HD Quality Video
2.3
based on 3 reviews
from
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
2
Category Average
4.4
Pros
  • Turns on (1)
  • Wide viewing angle (1)
See less See more
Cons
  • Abusive viewsonic techs (1)
  • Bad interface (1)
  • Difficult to set up (1)
  • Difficult to use (1)
  • Low resolution (1)
  • Poor connection options (1)
  • Poor image quality (1)
  • Poor quality (1)
  • Poor value (1)
Best Uses
  • Door stop (1)
  • Dust collector (1)
  • Office (1)
  • Room lighting (1)
Provided by Beach Audio
Look no further than the new VX2835wm multifunctional LCD for the ultimate in premium LCD performance. Over-engineered to the most demanding expectations of both Professional users and power gamers, the VX2835wm astounds with 3ms Video response on a breathtaking panorama of a 28-inch widescreen LCD. Tailored to more comfortably fit the natural human field of vision, the 16:10 widescreen with 1920 x 1200 high-resolution envelops the user with brilliant Color rendition, crystal-clear moving images, and photorealistic image quality. Open multiple document windows, view full-page layouts side-by-side, enjoy wide-format HD cinema and overload your senses with Stereo Surround gameplay from the expansive widescreen. This sleek design is finished in ViewSonic's most premium designer style in Glossy Piano Black with silver accents. The VX2835wm with ClearMotiv 3ms video response thrills audiences with native HD 1080p support.
  • Package Content: LCD display, power cable, 15-pin VGA video cable, Audio cable, HDMI to DVI-D cable, Quick Start Guide, ViewSonic Wizard CD
  • Full 27.5-inch viewable widescreen Color TFT Active matrix LCD with 1920x1200 resolution
  • Display Area: 23.4 horizontal x 14.6 vertical, 27.5-inches diagonal
  • True 1080p with HDMI for HD quality video
  • ClearMotiv 3ms video response time - enables digital, HD broadcast-quality video
  • Stylish slim-bezel design with glossy, piano-black finish - high neck and floating Head design accentuate the visual experience
  • Multifunction LCD with OptiSync digital/analog inputs
  • Ultra-high brightness and contrast - 500-nit brightness and 800:1 Contrast Ratio for rich, detailed images, videos, and games
  • OnView controls for superior screen adjustability - Screen adjustments are precisely made via an easy-to-use on-screen menu
  • Viewing Angles: 160 degrees horizontal, 160 degrees vertical
  • Response Time: 3ms gray-to-gray, 5ms black-white-black
  • Brightness: 500 cd/m2
  • Video Input: Analog RGB analog (75 ohms, 0.7 Vp-p), Digital HDMI (with HDCP), component, composite, S-video
  • Connector: Analog/Digital 15-pin mini D-sub/HDMI
  • Specification Description
    Model VX2835WM
    UPC 766907240313
    Aspect Ratio 16:10
    Connector - Analog Yes
    Connector - Digital Yes
    Contrast Ratio 800:1
    Integrated Speakers 2 x 3W Speaker Integrated
    Macintosh Compatible Yes
    Resolution 1920 x 1200
    Response Time (Milliseconds) 3
    Screen Resolution - Maximum 1920x1200
    Screen Size 28"
    Speakers Built-in Yes
    Table Stand Yes
    Unit Weight (Approximate Pounds) 27
    Video Inputs Yes
    Wall Mountable Yes - Optional Mount Required
    Windows PC Compatible Yes
    Viewsonic VX2835wm 28" LCD Display w/Integrated Speakers w/HDMI for HD Quality Video Questions
    Questions and Answers
    Where to Buy
    Amazon   at Amazon.com
    ebay
    eBay listings for: VX2835wm 28" LCD Display w/Integrated Speakers w/HDMI for HD Quality Video
    See all eBay results
      at eBay.com
    Product Reviews
    Last update: Dec 22, 2008
    Viewsonic VX2835wm 28" LCD Display w/Integrated Speakers w/HDMI for HD Quality Video Reviews
    Displaying 1 - 3 of 3 Reviews
    Show
    Sort by
    [6 of 7 customers found this review helpful]
    Should Be Renamed the Abysmal VX2835wm
    1.0
      Pros
    • Turns ON
      Cons
    • Abusive ViewSonic Techs
    • Bad Value
    • Low Quality
      Best Uses
    • door stop
    • Dust collector
    • Room Lighting
    "I purchased the VX2835wm on July 25, 2007 from Online site unseen, because no one had one of these to see. Mostly to get a near 30" Monitor for 1/3 the price of others I went for this. Since its a ViewSonic I felt comfortable with my purchase. I got the VX2835wm in July 2007. It was a problem right …"  Read Full Review »
    Was this LCD TV review on the Viewsonic VX2835wm 28" LCD Display w/Integrated Speakers w/HDMI for HD Quality Video helpful to you?
     Report Abuse  (6)  (1)  0 comments
    Jan 31 2008
    ScottG
    Marlton, NJ
    Reviewed at:
    [3 of 3 customers found this review helpful]
    Anolog Monitor and doesn't do digital
    1.0
      Pros
    • Reduced Glare
      Cons
    • Bad Interface
    • Difficult to Setup
    • Difficult to Use
    • Dull Image
    • Poor Connection Options
    • More »
      Best Uses
    • Office
    "I purchased July 29, 2008. I should have followed the the review found on BH Site.I spent over $800.00 upgrading my computer and video card. The DVI-D-HDMI cable didn't work. Only VGA cab le. Viewsonic techs told me to get an nVidio card. My dealer spend over two hours on the phone with Tech S …"  Read Full Review »
     Report Abuse  (3)  (0)  0 comments
    Aug 4 2008
    Dart
    Camarillo, CA
    I am:
    • Professional
    • Tech Savvy
    • Technically Challenged
    Reviewed at:
    [14 of 17 customers found this review helpful]
    Kick butt monitor
    5.0
    "Pros
    Very bright and clear - love it!
    Cons
    Runs a bit warm but that doesn't bother me....
    Additional Thoughts
    Just wish the price was not as high as it was, but it feels like it's well made... "
     Report Abuse  (14)  (3)  0 comments
    Dec 22 2008
    MrGalaxy
    Undisclosed
    Reviewed at:
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    ebay
      at eBay.com
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
