Viewsonic VT2230 22" Widescreen Full 1080p LCD HDTV
#528
3.0
based on 3 reviews
from $232.99 - $329.99
Ratings Distribution
5 star
0
4 star
2
3 star
0
2 star
0
1 star
1
Category Average
4.4
More Images
Pros
  • Attractive design (1)
  • Good connection options (1)
  • Simple controls (1)
See less See more
Cons
  • Bad interface (1)
  • Poor connection options (1)
  • Poor sound quality (1)
Best Uses
  • Bedroom (2)
Provided by WolfCamera.com
The right HDTV for the other room.
Get maximum enjoyment in kids’ rooms, dens, kitchens and other small spaces in your home with the beautifully styled, high performance VT2230 LCD HDTV.
  • Immerse yourself in the action with Full HD 1080p resolution for incredibly precise images
  • Revel in the unparalleled definition and detail delivered by 8000:1 dynamic contrast ratio
  • Super-fast video response and advanced image processing ensure extreme clarity in all your HD entertainment
  • Integrated ATSC/NTSC/QAM tuner and multiple connectivity options including HDMI with HDCP give you all the inputs you need for game consoles, DVD and Blu-Ray players and computers.
    OptiSync technology now features HDMI
    Add versatility to your LCD TV with support for HDMI with high-definition content protection (HDCP) and analog (VGA) signals, plus component, S-video, composite, and TV/cable input.
    16:9 Full HD 1920x1080 resolution panel
    Experience a new dimension in movie viewing and gaming with Full HD 1080p super resolution for the optimum richness and clarity in picture quality.
    Advanced image processing delivers clearer, crisper, sharper images
    Advanced ClearPicture image processing eliminates noise, increases contrast and detail and optimizes color for rich, vibrant images. High-definition images look amazing and even standard television images are unbelievably smooth and sharp.
    Vivid graphics, clear text, stunning TV
    Ultra-high brightness of 300-nit (typ), dynamic contrast ratio of 8000:1 and 1920x1080 optimum PC resolution provide vibrant video and crisp data images in the living room or on the desktop.
  • Specification Description
    Model VSCVT2230, VT2230, VT2230-S
    UPC 766907337310
    16:9 Mode Yes
    Audio Controls Volume, balance, bass, treble
    Battery Type Remote
    Benefits 21.6" (diagonal) widescreen display delivers great 16:9 aspect ratio and up to 1920x1080 resolutionBuilt-in ATSC/QAM/NTSC tuners prov
    Brightness 300 cd/m2
    Capacity UOM mAh
    Channel Labeling Yes
    Chemistry Alkaline
    Closed Caption Capability Yes
    Color Depth 16.9 million
    Color Temperature Control Yes
    Compliant Standards UL, FCC, NOM, EN 55013, CB
    Connections Antenna (1)HDMI (1)VGA (1)Component (1)Composite video RCA (1)Analog audio in RCA (2)Hea
    Controls / Adjustments Contrast, brightness, color, tint, sharpness, color temperature
    Country Of Origin China
    Description Header A lot of HDTV in a little package.
    Display Catalog Number 55031264
    Display Languages English, Spanish, French
    Display Menu Language English, Spanish, French
    Display Size 21.6 inches
    Enclosure Color Black
    End Product Indicator Yes
    Image Aspect Ratio 16:9
    Included in the Box ViewSonic® VT2230 22" 22" HDTV (Black)Remote control"AA" batteries (2)Power cordUser's guide
    Manufacturer Labor Warranty 12
    Manufacturer Part Number VT2230
    Manufacturer Parts Warranty 12
    MAP Price 0.0
    Max Operating Temperature 104 Fahrenheit
    Min Operating Temperature 32 Fahrenheit
    Model VT2230
    Operating Temperature UOM ° F
    Output Power / Total 10 watts
    Parental controls Yes
    Pixel Response Time 5 ms
    Product Depth 8.4
    Product Dimensions UOM inches
    Product Height 16.6
    Product Type Flat-panel TVs
    Product Weight 13.2
    Product Weight UOM pounds
    Product Width 20.9
    Reception System NTSC/ATSC/QAM
    Screen Size Range 21-30"
    Secondary Audio Program (SAP) Yes
    Size AA
    Sound Output Mode Stereo
    Speaker(s) Built-in, 5W + 5W
    Speakers Included 2 Speakers
    Supported Languages English, Spanish, French
    Technology IR
    TV Diagonal Size 21.6 inches
    TV Image Contrast Ratio 16:9
    TV Resolution 1920x1080
    TV Technology LCD
    Type LCD
    V-Chip Control Yes
    Viewing Angle 170 Degrees
    Viewing Angle (Vertical) 160 Degrees
    Voltage 1.5
    Voltage Required AC 100240V, (universal), 4763Hz
    Voltage UOM Volts
    Widescreen Modes 480i, 480p, 720p, 1080i, 1080p
    Viewsonic VT2230 22" Widescreen Full 1080p LCD HDTV Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Nov 17, 2009
    Viewsonic VT2230 22" Widescreen Full 1080p LCD HDTV Reviews
    Displaying 1 - 3 of 3 Reviews
    Show
    Sort by
    Pros: Perfect for gaming. ...
    4.0
    "Pros: Perfect for gaming. Great for PC. QAM. I'll say it again: QAM. It picks up 720p and 1080i channels on basic cable. Lots of inputs. Lots of screen real estate.
    Cons: speakers are sometimes VERY tinny. It depends on the channel. If it finds a channel, and says it does not exist (like it's …"  Read Full Review »
    Was this LCD TV review on the Viewsonic VT2230 22" Widescreen Full 1080p LCD HDTV helpful to you?
    Sep 13 2009
    TK
    Undisclosed
    Television
    4.0
      Pros
    • Good Connection Options
    • Simple Controls
      Cons
    • None
      Best Uses
    • Bedroom
    "Bedroom TV, not much we watch (maybe news) "
    Nov 17 2009
    tomcat
    atlanta ga
    I am:
    • Casual User
    Reviewed at:
    Price: $239.99
    good picture poor sound not enough volum
    1.0
      Pros
    • Attractive Design
      Cons
    • Bad Interface
    • Poor Connection Options
    • Poor Sound
      Best Uses
    • Bedroom
    "I was going to use in travel trailer
    poor sound volume
    picture is poor when viewed at a upward angle
    did not work as a TV will have to use a monitor "
    Mar 24 2009
    Cliff
    Terrell,Texas
    I am:
    • Casual User
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
