Viewsonic NX2232w 22" Widescreen LCD HDTV
#354
3.4
based on 14 reviews
Ratings Distribution
5 star
6
4 star
1
3 star
3
2 star
1
1 star
3
Category Average
4.4
$392.00 at CompSource
Find it at Amazon
Find it at Ebay
$392.00
from 1 store
More Images
Pros
  • Attractive design (13)
  • Fast setup (9)
  • High resolution (8)
  • Simple controls (8)
  • Great picture quality (7)
  • Good connection options (6)
  • Wide viewing angle (6)
  • Built in qam tv tuner (1)
  • Built in speakers (1)
  • Cheap price (1)
See less See more
Cons
  • Bad interface (3)
  • Low resolution (3)
  • Difficult to use (2)
  • Poor connection options (2)
  • Poor reception / weak antenna (2)
  • 1 hdmi hookup (1)
  • 1...just 1 dead pixel (1)
  • Back light spill-through (1)
  • Hdmi not great on pc (1)
Best Uses
  • Home (8)
  • Office (5)
  • Video (5)
  • Movies (4)
  • Dorm room (2)
  • Kitchen (2)
  • Small rooms (2)
  • Bedroom (1)
  • Computer monitor (1)
  • Door stop - boat anchor (1)
Provided by WolfCamera.com
Extreme HD picture quality.
The exciting 22" DiamaniDuo widescreen HDTV/LCD monitor is the versatile new TV from ViewSonic that offers super HD 1680x1050 resolution, fast 5ms LCD panel and HDMI connectivity for the best possible picture. The PC input lets you use this display as a BRILLIANT COMPUTER MONITOR and an HDTV. It's ideal for watching stunning movies, videos and TV in the kitchen, den, office, dorm room, bedroom and even RVs. This versatile LCD HDTV offers six inputs, including HDMI to connect your DVD player, camcorder, and gaming console. Enjoy UNPARALLELED ENTERTAINMENT on your desktop. The stylish NX2232w optimizes your space with its beautiful high-gloss cabinet, cable-ready ATSC/NTSC tuner and wall-mount option. Get ready to enjoy dynamic entertainment that fits your life.
Experience widescreen HDTV
Enjoy a widescreen theater experience and high-definition picture quality with this display's widescreen aspect ratio, true HDTV capability, and wide viewing angles.
ClearPicture electronics deliver clearer, crisper, sharper images
ClearPicture electronics eliminate noise, increase contrast and detail and optimize color for rich, vibrant images. High-definition images look amazing and even standard television images are unbelievably smooth and sharp.
Vivid graphics, clear text, stunning TV & PC monitor
Ultra-high brightness of 300 nits (typ), dynamic contrast ratio of 2400:1 (typ), and 1680x1050 PC resolution provide vibrant video and crisp data images on the desktop or in the living room.
Expand your options with plug-and-play connectivity
This HDTV provides the ultimate viewing experience with integrated HDTV tuner and two HDMI inputs for HD set-top boxes, DVDs, game consoles and camcorders.
OptiSync technology now features HDMI
Add versatility to your LCD TV with support for HDMI with high-definition content protection (HDCP) and analog (VGA) signals, plus component, S-video, composite, and TV/cable input.
Specification Description
Model 766907274417, N4285P-S, NX2232W, NX2232w
UPC 613651845021
16:9 Mode Yes
Audio Controls Volume, balance, bass, treble
Battery Type Product
Benefits 22" (diagonal) widescreen display delivers great 16:9 aspect ratio and up to 1680x1050 resolutionBuilt-in ATSC/QAM/NTSC tuners provid
Brightness 300 cd/m2
Capacity UOM mAh
Channel Labeling Yes
Chemistry Alkaline
Closed Caption Capability Yes
Color Depth 16.9 million
Color Temperature Control Yes
Compliant Standards UL, FCC, NOM, EN 55013, CB
Connections Antenna (1)HDMI (1)VGA (1)Composite video RCA (1)Analog audio in RCA (2)Headphone 1/8" (1)
Controls / Adjustments Contrast, brightness, color, tint, sharpness, color temperature
Country Of Origin China
Description Header Dynamic entertainment for your life.
Display Catalog Number 55031252
Display Languages English, Spanish, French
Display Menu Language English, Spanish, French
Display Size 21.6 inches
Enclosure Color Black
End Product Indicator Yes
Image Aspect Ratio 16:1
Included in the Box ViewSonic® DiamaniDuo™ NX2232W 22" HDTV (Black)Remote control"AA" batteries (2)Power cordUser's g
Manufacturer Labor Warranty 12
Manufacturer Part Number NX2232W
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model NX2232W
Operating Temperature UOM ° F
Output Power / Total 10 watts
Parental controls Yes
Pixel Response Time 5 ms
Product Depth 6.1
Product Dimensions UOM inches
Product Height 17.1
Product Type Flat-panel TVs
Product Weight 14.3
Product Weight UOM pounds
Product Width 20.3
Reception System NTSC/ATSC/QAM
Screen Size Range 21-30"
Secondary Audio Program (SAP) Yes
Size AA
Sound Output Mode Stereo
Speaker(s) Built-in, 5W + 5W
Speakers Included 2 Speakers
Supported Languages English, Spanish, French
Technology IR
TV Diagonal Size 21.6 inches
TV Image Contrast Ratio 1000:1
TV Resolution 1680x1050
TV Technology LCD
Type LCD
V-Chip Control Yes
Viewing Angle 160 Degrees
Viewing Angle (Vertical) 160 Degrees
Voltage 1.5
Voltage Required AC 100240V, (universal), 4763Hz
Voltage UOM Volts
Widescreen Modes 480i, 480p, 720p, 1080i, 1080p
Viewsonic NX2232w 22" Widescreen LCD HDTV Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 9, 2008
Viewsonic NX2232w 22" Widescreen LCD HDTV Reviews
Most helpful positive review
Most helpful negative review
4.0
Good combo lots of connectivity
"I am currently using this 22" monitor primarily as a computer monitor in a dual screen setup. It sits next to a 17" Viewsonic monitor and viewing is surprisingly at the same screen level. I am also using it to plug in my game stations PS3 via HDMI. The display looks awesome running in HDMI, although there is lack of a DVI port on the monitor so you have to plug your computer screen with a standard VGA cable (a..." Read Full Review »
Mar 31, 2008 by Scotty
See more positive Viewsonic NX2232w 22" Widescreen LCD HDTV reviews
3.0
Buyer Beware -- Maybe
"am noticing a problem, am not sure if it's in the SIMA VS-502 selector or in the nx2232w: in movie sequences with gun fire, for example, when the guns start emitting white bursts, the screen fades to black for several moments. have noticed occasional fade outs in other movies where there are no white bursts. don't know what the cause of the problem is. that's why I gave the set an average rating. If it were..." Read Full Review »
Dec 08, 2007 by none
See more negative Viewsonic NX2232w 22" Widescreen LCD HDTV reviews
Displaying 1 - 5 of 14 Reviews
Show
Sort by
4.0
    Pros
  • Attractive Design
  • Built in QAM TV Tuner
  • Built in Speakers
  • Comes with Remote
  • Good Connection Options
  • More »
    Cons
  • HDMI not great on PC
  • HDTV anntenna lose signal
  • No standard DVI connectio
    Best Uses
  • Office
"I am currently using this 22" monitor primarily as a computer monitor in a dual screen setup. It sits next to a 17" Viewsonic monitor and viewing is surprisingly at the same screen level. I am also using it to plug in my game stations PS3 via HDMI. The display looks awesome running in HDMI, althou …"  Read Full Review »
Was this LCD TV review on the Viewsonic NX2232w 22" Widescreen LCD HDTV helpful to you?
Mar 31 2008
Scotty
W. Los Angeles, CA
I am:
  • Gearhead
  • Professional
  • Tech Savvy
Reviewed at:
AMAZING TV!!!
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • 1 HDMI hookup
    Best Uses
  • Bedroom
  • Computer monitor
  • Gaming TV
  • Home
  • Kitchen
  • More »
"This TV is one of the best TV's I have seen. I compaired it to the 22" Tvs at [...] This has the best over all quality. Contrast is amazing. I currently am using it in a bedroom with an Xbox 360 connected to the HDMI and it looks AMAZING. I also have a computer connected to it and it makes a great m …"  Read Full Review »
May 26 2008
Battleofarnhem
Jasper, Indiana
I am:
  • Professional
  • Tech Savvy
Reviewed at:
3.0
    Pros
  • Attractive Design
  • Bright Image
  • Excellent color rendition
  • Excellent resolution
  • Fast Setup
  • More »
    Cons
    Best Uses
  • Home
  • Movies
  • Video
"am noticing a problem, am not sure if it's in the SIMA VS-502 selector or in the nx2232w: in movie sequences with gun fire, for example, when the guns start emitting white bursts, the screen fades to black for several moments. have noticed occasional fade outs in other movies where there are no wh …"  Read Full Review »
Dec 8 2007
none
New York, New York
I am:
  • Tech Savvy
Reviewed at:
I am not satisfied
3.0
    Pros
  • Attractive Design
  • Fast Setup
  • Simple Controls
  • Slim design sleek
    Cons
  • Bad Interface
  • Difficult to Use
  • Is it me or the TV
  • Poor Connection Options
  • Poor Resolution
    Best Uses
  • Home
"Is it me or the TV? I have this TV for 2 days and I still can't get a clear picture. I called tech support and they told me it was the antenna, so I bought a newer antenna. It doesn't work with my VCR/DVD combo. Do I need a new vcr? Not sure. I'm willing to work with this, but I'm beginning to …"  Read Full Review »
Dec 16 2007
Chicago48
Chicago, IL
I am:
  • Tech Savvy
Reviewed at:
Never. Again.
1.0
    Pros
  • None
    Cons
  • Bad Interface
  • Difficult to Use
  • Poor Reception
  • Uncontrolable volume
    Best Uses
  • Home
"At first, this TV was excellent. But one day, I went into another room and left my TV going, the volume suddenly blared. It only stopped after turning it off for a few minutes, then when it came back on, it was at normal volume. This has happened numerous times. Another downside is the poor receptio …"  Read Full Review »
Jun 26 2008
Frustrated
Chicago, IL
I am:
  • Practical
Reviewed at:
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
