Viewsonic N3290W 32" 720p LCD TV (31.5")
5.0
based on 1 review
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
More Images
Pros
  • Attractive design (1)
  • Fast setup (1)
  • Good connection options (1)
  • Great picture quality (1)
  • High resolution (1)
  • Simple controls (1)
  • Wide viewing angle (1)
See less See more
Cons
  • Poor sound quality (1)
Best Uses
  • Bedroom (1)
  • Home (1)
  • Movies (1)
  • Wall mounting (1)
Provided by Super Warehouse
ViewSonic's sophisticated N3290w 32" widescreen LCD TV delivers premium HD entertainment in style. This beautiful TV features full HD 1080i resolution and an amazing 10000:1 dynamic contrast ratio for unmatched detail and depth in your movies- videos and HD TV shows. With 11 inputs- including three HDMI 1.3 connections for all your high-definition electronics- the N3290w easily becomes the centerpiece of your home entertainment system. The advanced video processor produces crisp- sharp pictures. The swivel base allows you to change your viewing perspective with a simple turn of the TV. And this display is environmentally friendly- using only one watt of power in its power save mode. Add a touch of class to your living room with the high-style- high-performance N3290w.
  • Product Description: ViewSonic N3290w- 32" LCD TV
  • Product Type: LCD TV
  • Diagonal Size: 32"- widescreen
  • Dimensions (WxDxH): 30.8 in x 3.7 in x 20.4 in- without stand
  • Weight: 24.3 lbs
  • Color: Black
  • Digital Television Certification: HDTV
  • Resolution: 1366 x 768
  • Display Format: 720p
  • Input Video Formats: 480p- 720p- 1080i- 480i
  • Video Interface: Component- composite- HDMI- S-Video
  • PC Interface: VGA (HD-15)
  • HDCP Compatible: Yes
  • Technology: TFT active matrix
  • Image Aspect Ratio: 16:9
  • TV Tuner: 1x analog/digital combo
  • Digital TV Tuner: ATSC- QAM
  • Analog TV Tuner: NTSC
  • Multi-channel Preview: Picture-in-picture (PIP)- POP
  • Additional Features: On-screen menu- anti-reflection coating- anti-glare coating
  • Sound Output Mode: Stereo
  • Speaker System: 2 speakers
  • Stereo Reception System: MTS
  • Remote Control: Remote control- infrared
  • Power: AC 120/230 V ( 50/60 Hz )
  • Manufacturer Warranty: 1 year warranty
Specification Description
Model 2079644, N3290W, N3290w
UPC 766907300116
16:9 Mode Yes
Audio Controls Volume, balance, bass, treble
Battery Type Remote
Benefits 31.5" (diagonal) widescreen display delivers great 16:9 aspect ratio and up to 1360x768 resolutionFeatures full HD 1080i resolution a
Brightness 500 cd/m2
Capacity UOM mAh
Channel Labeling Yes
Chemistry Alkaline
Closed Caption Capability Yes
Color Depth 16.9 million
Color Temperature Control Yes
Compliant Standards UL, FCC, NOM, EN 55013, CB
Connections HDMI (2)Component video (2)VGA (1)S-Video (1)Antenna (1)Composite video RCA (1)Analog au
Controls / Adjustments Contrast, brightness, color, tint, sharpness, color temperature
Country Of Origin China
Description Header Premium HD entertainment for your lifestyle.
Display Catalog Number 55031247
Display Languages English, Spanish, French
Display Menu Language English, Spanish, French
Enclosure Color Black
End Product Indicator Yes
Humidity Range Operating 10-65%
Image Aspect Ratio 16:9
Included in the Box ViewSonic® N3290w 32" LCD HDTV (BlackRemote control"AA" batteries (2)Power cordUser's guide
Manufacturer Labor Warranty 12
Manufacturer Part Number N3290w
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model N3290w
Operating Temperature UOM ° F
Output Power / Total 20 watts
Parental controls Yes
Pixel Response Time 6.5 ms
Power Consumption Operational 180W
Product Depth 8.3
Product Dimensions UOM inches
Product Height 24.8
Product Type Flat-panel TVs
Product Weight 37.4
Product Weight UOM pounds
Product Width 31.5
Reception System NTSC/ATSC/QAM
Screen Size Range 31-40"
Secondary Audio Program (SAP) Yes
Size AA
Sound Output Mode Stereo
Speaker(s) Built-in, 10W + 10W
Speakers Included 2 Speakers
Supported Languages English, Spanish, French
Technology IR
TV Diagonal Size 31.5 inches
TV Image Contrast Ratio 10000:1
TV Resolution 1360x768
TV Technology LCD
Type LCD
V-Chip Control Yes
Viewing Angle 178 Degrees
Viewing Angle (Vertical) 178 Degrees
Voltage 1.5
Voltage Required AC 90240V (universal), 4763Hz
Voltage UOM Volts
Widescreen Modes 480i, 480p, 720p, 1080i
Viewsonic N3290W 32" 720p LCD TV (31.5") Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: N3290W 32" 720p LCD TV (31.5")
See all eBay results
  at eBay.com
Product Reviews
Last update: Feb 17, 2009
Viewsonic N3290W 32" 720p LCD TV (31.5") Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
This is an excellent TVC for the price!
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • Poor Sound
    Best Uses
  • Bedroom
  • Home
  • Movies
  • Wall Mounting
"Ive had this TV for a couple of weeks now and am still amazed every time I watch it. The quality is excellent, it is very easy to see. I said poor sound because it lacks a lot of bass, but a home theatre wil fix that. I am 100% satisfied and actually bought a second Viewsonic TV after this one. "
Was this LCD TV review on the Viewsonic N3290W 32" 720p LCD TV (31.5") helpful to you?
Feb 17 2009
Mark the Viking
Houston TX
I am:
  • Enthusiast
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
