Viewsonic N3235W 32" Widescreen LCD HDTV
#359
3.8
based on 4 reviews
Ratings Distribution
5 star
2
4 star
1
3 star
0
2 star
0
1 star
1
Category Average
4.4
$474.95 - $699.99
from 14 stores
More Images
Pros
  • Bright image (3)
  • Attractive design (2)
  • High resolution (2)
  • Simple controls (2)
  • Easy to move (1)
  • Fast setup (1)
  • Good connection options (1)
  • Lightweight (1)
  • Reduced glare (1)
See less See more
Best Uses
  • Movies (2)
  • Bedroom (1)
  • Home (1)
  • Video (1)
  • Wall mounting (1)
Provided by photoalley.com
Immerse yourself in entertainment.
ViewSonic's 32" N3235w widescreen LCD HDTV brings impressive high-definition pictures to life. Fast video response, high brightness and contrast ratio combine to deliver crystal clear, fast action movies, videos and games. Advanced CLEARPICTURE electronics, enhance contrast, define details and boost color. Enjoy maximum versatility, connecting DVD players, game consoles, HD set top boxes and more with the full range of inputs including HDMI with HDCP, S-video and even PC connectivity. The Dolby Digital sound completes your home entertainment experience with clear, digital audio for DVDs, movies, sports and games. The N3235w's glossy piano-black finish adds a splash of high-tech style to your high-definition entertainment.
Experience widescreen HDTV
Enjoy a widescreen theater experience and high-definition picture quality with this display's widescreen aspect ratio, true HDTV capability, and wide viewing angles.
ClearPicture electronics deliver clearer, crisper, sharper images
ClearPicture electronics eliminate noise, increase contrast and detail and optimize color for rich, vibrant images. High-definition images look amazing and even standard television images are unbelievably smooth and sharp.
Vivid graphics, clear text, stunning TV
Ultra-high brightness of 500 nits (typ), high contrast ratio of 1200:1 (typ), and 1360x768 optimum PC resolution provide vibrant video and crisp data images on the desktop or in the living room.
Expand your options with plug-and-play connectivity
This HDTV provides the ultimate viewing experience with integrated HDTV tuner and plug-and-play, high-end connectivity for HD settop boxes, DVDs, game consoles and camcorders.
OptiSync technology now features HDMI
Add versatility to your LCD TV with support for HDMI with high-definition content protection (HDCP) and analog (VGA) signals, plus component, S-video, composite, and TV/cable input.
Powerful high-fidelity audio
It's all accompanied by an ultra-high fidelity 20-watt Dolby Digital sound that completes the entertainment experience.
Specification Description
Model N3235W, N3235W-R, N3235w, VSCN3235W
UPC 766907265415
16:9 Mode Yes
Audio Controls Volume, balance, bass, treble
Battery Type Remote
Benefits 32" (diagonal) widescreen display delivers great 16:9 aspect ratio and up to 1360x768 resolutionBuilt-in ATSC/QAM/NTSC tuners provide
Brightness 500 cd/m2
Capacity UOM mAh
Channel Labeling Yes
Chemistry Alkaline
Closed Caption Capability Yes
Color Depth 16.9 million
Color Temperature Control Yes
Compliant Standards UL, FCC, NOM, EN 55013, CB
Connections Antenna (1)Component (2)HDMI (2)VGA (1)Composite video RCA (1)Audio in RCA (4)Headphone
Controls / Adjustments Contrast, brightness, color, tint, sharpness, color temperature
Country Of Origin China
Description Header Immerse yourself in HD entertainment.
Display Catalog Number 55031246
Display Languages English, Spanish, French
Display Menu Language English, Spanish, French
Display Size 32 inches
Enclosure Color Black
End Product Indicator Yes
Humidity Range Operating 10-65%
Image Aspect Ratio 16:9
Included in the Box ViewSonic® N3235W 32" LCD HDTV (Black)Remote control"AA" batteries (2)Power cordUser's guide
Manufacturer Labor Warranty 12
Manufacturer Part Number N3235W
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model N3235W
Operating Temperature UOM ° F
Output Power / Total 20 watts
Parental controls Yes
Pixel Response Time 8 ms
Power Consumption Operational 150W
Product Depth 8.3
Product Dimensions UOM inches
Product Height 24.8
Product Type Flat-panel TVs
Product Weight 37.4
Product Weight UOM pounds
Product Width 31.5
Reception System NTSC/ATSC/QAM
Screen Size Range 31-40"
Secondary Audio Program (SAP) Yes
Size AA
Sound Output Mode Stereo
Speaker(s) Built-in, 10W + 10W
Speakers Included 2 Speakers
Supported Languages English, Spanish, French
Surround Sound Effects Dolby® Digital sound
Technology IR
TV Diagonal Size 32 inches
TV Image Contrast Ratio 1200:1
TV Resolution 1360x768
TV Technology 32
Type LCD
V-Chip Control Yes
Viewing Angle 176 Degrees
Viewing Angle (Vertical) 176 Degrees
Voltage 1.5
Voltage Required AC 90240V (universal), 4763Hz
Voltage UOM Volts
Widescreen Modes 480i, 480p, 720p, 1080i
Viewsonic N3235W 32" Widescreen LCD HDTV Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jan 23, 2009
Viewsonic N3235W 32" Widescreen LCD HDTV Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
Not Bad
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Easy to Move
  • Fast Setup
  • Good Connection Options
  • More »
    Cons
  • None
    Best Uses
  • Bedroom
  • Movies
  • Wall Mounting
"I use this TV for everyday use. It is my TV and monitor. The interface is quite user friendly and i have had no problems. "
Was this LCD TV review on the Viewsonic N3235W 32" Widescreen LCD HDTV helpful to you?
Jan 23 2009
Bear
Palm Bay FL.
I am:
  • Power User
[1 of 1 customers found this review helpful]
Very good luck with Viewsonic products
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Good Resolution
  • Simple Controls
    Cons
  • None
    Best Uses
  • Movies
  • Video
"- use for client exhibits
- corporate videos run up to 6 hrs straight
- client equipment camera's run thru LCD for customer viewing "
 Report Abuse  (1)  (0)  0 comments
Aug 22 2008
KVT
East Longmeadow, MA
I am:
  • Professional
Reviewed at:
Price: $474.95
quits after 2 years
1.0
"remote goes out than about a month later the set s hard to turn on with the button, there is not a unverisal remote that works with it that you can still buy. also after it becomes hard to turn on one day you will be watching it and it shuts off never comes back on again. "
Dec 7 2007
greatdanelover
chicago IL
I am 96 and it's clear and sharp.
5.0
    Pros
  • Bright Image
    Cons
  • None
    Best Uses
  • Home
"I am 96 and I can see it great. THANKS "
Jan 15 2009
Sugar
Holiday Island, AR.
I am:
  • Enthusiast
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
