Viewsonic N2230W 22" LCD TV
#437
4.3
based on 21 reviews
Ratings Distribution
5 star
10
4 star
9
3 star
1
2 star
1
1 star
0
Category Average
4.4
$285.99 at Super Warehouse
Find it at Amazon
Find it at Ebay
$285.99
from 1 store
Pros
  • Attractive design (12)
  • Great picture quality (12)
  • Fast setup (11)
  • High resolution (11)
  • Simple controls (10)
  • Good connection options (9)
  • Wide viewing angle (5)
  • Adjustable (1)
  • Lightweight (1)
  • Versatile (1)
See less See more
Cons
  • Poor sound quality (5)
  • Poor connection options (2)
Best Uses
  • Bedroom (10)
  • Dorm room (1)
  • Gaming (1)
  • Home (1)
  • Hooked to a laptop (1)
  • Movies (1)
  • Multimedia (1)
Provided by photoalley.com
Big entertainment in a small package.
ViewSonic's dual-purpose N2230w 22" (21.6"viewable) widescreen LCD TV delivers HD entertainment in style. The stylized glossy bezel houses a full-featured LCD HDTV/PC monitor that includes Super HD 1680x1050 resolution, fast 5ms video response and 4000:1 DYNAMIC CONTRAST RATIO (typ) for SUPERIOR DIGITAL ENTERTAINMENT. It also includes an ATSC/NTSC/QAM tuner, comprehensive inputs including HDMI, component, composite and S-video for all your entertainment devices. The N2230w is ideal for bedrooms, offices, dorm rooms, garages and kitchens. It's the hard-working, space-saving stylish LCD TV for your lifestyle.
Experience widescreen HDTV
Enjoy a widescreen theater experience and high-definition picture quality with this display's widescreen aspect ratio, true HDTV capability, and wide viewing angles.
ClearPicture electronics deliver clearer, crisper, sharper images
ClearPicture electronics eliminate noise, increase contrast and detail and optimize color for rich, vibrant images. High-definition images look amazing and even standard television images are unbelievably smooth and sharp.
Vivid graphics, clear text, stunning TV
Ultra-high brightness of 300-nit (typ), dynamic contrast ratio of 4000:1 and 1680x1050 optimum PC resolution provide vibrant video and crisp data images in the living room or on the desktop.
Expand your options with plug-and-play connectivity
This HDTV provides the ultimate viewing experience with integrated HDTV tuner and two HDMI inputs for HD set-top boxes, DVDs, game consoles and camcorders.
OptiSync technology now features HDMI
Add versatility to your LCD TV with support for HDMI with high-definition content protection (HDCP) and analog (VGA) signals, plus component, S-video, composite, and TV/cable input.
Specification Description
Model 2052036, N2230W, N2230w
UPC 766907299717
16:9 Mode Yes
Audio Controls Volume, balance, bass, treble
Battery Type Product
Benefits 21.6" (diagonal) widescreen display delivers great 16:9 aspect ratio and up to 1680x1050 resolutionBuilt-in ATSC/QAM/NTSC tuners prov
Brightness 300 cd/m2
Capacity UOM mAh
Channel Labeling Yes
Chemistry Alkaline
Closed Caption Capability Yes
Color Depth 16.9 million
Color Temperature Control Yes
Compliant Standards UL, FCC, NOM, EN 55013, CB
Connections Antenna (1)HDMI (1)Component (1)VGA (1)S-video (1)Analog audio in RCA (1)PC audio in 1/8
Country Of Origin China
Description Header Big entertainment in a small package
Display Catalog Number 55031243
Display Languages English, Spanish, French
Display Menu Language English, Spanish, French
Display Size 22 inches
Enclosure Color Black
End Product Indicator Yes
Humidity Range Operating 10-65%
Image Aspect Ratio 16:9
Included in the Box ViewSonic® N2230w 22" HDTV (Black)Remote control"AA" batteries (2)Power cordUser's guide
Manufacturer Labor Warranty 12
Manufacturer Part Number N2230w
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model N2230w
Operating Temperature UOM ° F
Output Power / Total 6 watts
Parental controls Yes
Pixel Response Time 5 ms
Power Consumption Operational 48W
Product Depth 6.1
Product Dimensions UOM inches
Product Height 16.6
Product Type Flat-panel TVs
Product Weight 12.9
Product Weight UOM pounds
Product Width 20.4
Reception System NTSC/ATSC/QAM
Secondary Audio Program (SAP) Yes
Size AA
Sound Output Mode Stereo
Speaker(s) Built-in, 3W + 3W
Speakers Included 2 Speakers
Supported Languages English, Spanish, French
Technology IR
TV Diagonal Size 22 inches
TV Resolution 1680x1050
TV Technology LCD
Type LCD
V-Chip Control Yes
Viewing Angle 160 Degrees
Viewing Angle (Vertical) 160 Degrees
Voltage 1.5
Voltage Required AC 100240V, (universal), 4763Hz
Voltage UOM Volts
Widescreen Modes 480i, 480p, 720p, 1080i
Viewsonic N2230W 22" LCD TV Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jul 15, 2009
Viewsonic N2230W 22" LCD TV Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
5.0
Amazing TV, unbeatable price
"I started with an idea to purchase a 22" LCD monitor for my macbook. A friend suggested why not a LCD HDTV just by paying a coupla $$$ more and it just happened. A LCD monitor = $220 (inclv. shipping n tax).A LCD HDTV = [$] all inclusive (PRICELESS is what I'd say!!)[...] satisfactory product. does what it says!!All in all a very good buy for the listed price!!..." Read Full Review »
Mar 25, 2009 by Shax
See more positive Viewsonic N2230W 22" LCD TV reviews
3.0
Great picture, but...
"If you plan to use this as a stand-alone TV be aware that the audio is poor. There are no "Audio Out" connections to allow for external speakers to be added. Unless you connect it thru a surround-sound system, the quality of the sound is weak and tinny. I have been a fan of the ViewSonic line of products for a long time so, it was with disappointment that I have to write this review and return the unit...." Read Full Review »
Apr 18, 2009 by divans
See more negative Viewsonic N2230W 22" LCD TV reviews
Displaying 1 - 5 of 21 Reviews
Show
Sort by
3.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • Reduced Glare
  • More »
    Cons
  • Poor Connection Options
  • Poor Sound
    Best Uses
  • None
I have been a fan of the ViewSonic line …"  Read Full Review »
Was this LCD TV review on the Viewsonic N2230W 22" LCD TV helpful to you?
 Report Abuse  (1)  (0)  0 comments
Apr 18 2009
divans
Porterville, CA
I am:
  • Enthusiast
Reviewed at:
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Bedroom
  • Movies
"I started with an idea to purchase a 22" LCD monitor for my macbook. A friend suggested why not a LCD HDTV just by paying a coupla $$$ more and it just happened. A LCD monitor = $220 (inclv. shipping n tax).A LCD HDTV = [$] all inclusive (PRICELESS is what I'd say!!)[...] satisfactory product. does …"  Read Full Review »
Mar 25 2009
Shax
San Jose, CA
I am:
  • Enthusiast
Reviewed at:
Great for the price
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
    Cons
  • None
    Best Uses
  • Bedroom
"I wanted a hdtv to double as computer monitor on daughter's bedroom desk.
Setup was a breeze, you don't even have to install drivers on the PC, the monitor self-adjusted.
The picture is outstanding for the price. I can understand people's comments on the sound especially if it was in a large …"  Read Full Review »
Jun 11 2009
Toon Fan
New York, NY
I am:
  • Enthusiast
Reviewed at:
Good Overall
4.0
    Pros
  • Attractive Design
  • Good Resolution
  • Simple Controls
    Cons
  • None
    Best Uses
  • Bedroom
"I use this TV in my dorm room and it works excellent with my MacBook Pro. I went to [...] and bought a re-packaged DVI-HDMI cable for [$] to connect the two. I haven't had any problems with the audio as some others may be having. The only reason I am giving it 4 stars rather than 5 is because it cam …"  Read Full Review »
May 27 2009
UMass12
Temecula, CA
I am:
  • Casual User
Reviewed at:
Good for the price
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • Simple Controls
    Cons
  • Poor Sound
    Best Uses
  • Bedroom
"Since the N2230W has average (at best) sound quality, Viewsonic *should* provide an audio-out jack so its customers could attach and enjoy independent speakers. For the price, though, provides good TV images for a *small* studio apt. or bedroom. "
May 20 2009
KS
Santa Monica, CA
I am:
  • Casual User
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
