Viewsonic 22 in Wide LCD TV Model N2201W
#12
4.0
based on 13 reviews
from $299.96 - $399.99
Ratings Distribution
5 star
4
4 star
6
3 star
2
2 star
1
1 star
0
Category Average
4.0
Pros
  • Attractive design (9)
  • Fast setup (9)
  • Great picture quality (9)
  • Simple controls (7)
  • Affordable (1)
  • Good interface (1)
  • Price wdvd (1)
  • Set-up manual complicated (1)
  • Versatile (1)
See less See more
Cons
  • Poor image quality (2)
  • Bad interface (1)
  • Not great but okay audio (1)
  • Piano finish means dust (1)
Best Uses
  • Home (9)
  • Office (5)
  • Movies (4)
  • Professional (2)
  • Video (2)
  • Bedroom or spare room (1)
  • On a sailboat (1)
  • Wouldda in bedroom (1)
Provided by CameraWorld.com
The 3-in-1 LCD HDTV and DVD combo. Professional Color Certified.
ViewSonic's N2201w 22" widescreen LCD HDTV/DVD combo is the perfect HDTV for the kids' room, a dorm room or other location where space is at a premium. Enjoy full-featured HD entertainment from this TV's integrated ATSC/NTSC/QAM tuner and DVD player. Watch your favorite DVDs, movies and HD TV shows in incredible detail supplied by the Super-Hd 1680x1050 resolution. The integrated stereo speakers round out the experience with rich, stereo sound. Inputs include HDMI 1.3, component, composite and S-video to hook up all your entertainment devices and even your PC, allowing this TV to double as a PC monitor. The N2201w is just what you need to complement your lifestyle.
Experience widescreen HDTV
Enjoy a widescreen theater experience and high-definition picture quality with this display's widescreen aspect ratio, true HDTV capability and wide viewing angles.
Delivers clearer, crisper, sharper images
Advanced image processing eliminates noise, increases contrast and detail, and optimizes color for rich, vibrant images.
Vivid graphics, clear text, stunning TV & PC monitor
Ultra-high brightness of 300 nits (typ), contrast ratio of 1000:1 (typ) and 1680x1050 resolution provide vibrant video and crisp data images for TV or PC viewing.
Versatile entertainment options
This HDTV provides the ultimate viewing experience with a built-in DVD player, integrated HDTV tuner and plug-and-play, high-end connectivity for HD set-top boxes, DVDs, game consoles and more.
OptiSync technology now features HDMI 1.3
Add versatility to your LCD HDTV with support for HDMI 1.3 with high-definition content protection (HDCP) and analog (VGA) signals, plus component, S-video, composite and TV/cable inputs.
Specification Description
Model N2201W, N2201w
UPC 766907319811
16:9 Mode Yes
Audio Controls Volume, balance, bass, treble
Benefits 22" (diagonal) widescreen display delivers great 16:9 aspect ratio and up to 1680x1050 resolutionBuilt-in DVD player accepts DVD-Vide
Brightness 300 cd/m2
Capacity UOM mAh
Closed Caption Capability Yes
Color Depth 16.9 million
Color Temperature Control Yes
Compliant Standards UL, FCC, NOM, EN 55013, CB
Connections Antenna (1)HDMI (1)Component (1)Composite video VGA (1)VGA (1)S-video (1)Analog audio in
Country Of Origin China
Description Header Everything you need in one package.
Display Catalog Number 55031242
Display Languages English, Spanish, French
Display Menu Language English, Spanish, French
Display Size 22 inches
Enclosure Color Black
End Product Indicator Yes
Humidity Range Operating 10-65%
Image Aspect Ratio 16:9
Included in the Box ViewSonic® N2201W 22" HDTV/DVD Combo (Black)Remote control"AA" batteries (2)Power cordUser's guide
Manufacturer Labor Warranty 12
Manufacturer Part Number N2201W
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model N2201W
Operating Temperature UOM ° F
Output Power / Total 6 watts
Parental controls Yes
Pixel Response Time 5 ms
Power Consumption Operational 75W
Product Depth 8.6
Product Dimensions UOM inches
Product Height 17
Product Type TV/DVD/VCR combos
Product Weight 17.1
Product Weight UOM pounds
Product Width 20.8
Reception System NTSC/ATSC/QAM
Screen Size Range 21-30"
Sound Output Mode Stereo
Speaker(s) Built-in, 3W + 3W
Speakers Included 2 Speakers
Supported Languages English, Spanish, French
Technology IR
TV Diagonal Size 22 inches
TV Image Contrast Ratio 1000:1
TV Resolution 1680x1050
TV Technology LCD
Type LCD
V-Chip Control Yes
Viewing Angle 160 Degrees
Viewing Angle (Vertical) 160 Degrees
Voltage Required AC 100240V, (universal), 4763Hz
Widescreen Modes 480i, 480p, 720p, 1080i
Viewsonic 22 in Wide LCD TV Model N2201W Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 21, 2009
Viewsonic 22 in Wide LCD TV Model N2201W Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
4.0
Excellent HDTV & DVD Combo Set - Value
"The 22" combo HDTV - DVD player was bought for a summer home and it was easy for a techo-idiot (me) to set-up and use. Excellent picture quality, and nice design. The audio is a bit hollow (I also play CD's on it); but for my use that's okay. Very reasonably priced and when I called Viewsonic before purchasing it for add'l info, their rep was intelligent, helpful, & professional!..." Read Full Review »
Jul 16, 2009 by Klugs
See more positive Viewsonic 22 in Wide LCD TV Model N2201W reviews
3.0
Inexpensive, but you get what you pay 4!
"We purchased this to replace a Sony XBRITE LCD TV in our bedroom so we could get a disc spinner and a bigger size (the Sony was a meager 17"). Out of the box, build quality is average, you definitely get the feeling of plastic - the roots of this TV definitely carries over from a computer monitor. Things remained just average turning it on - the panel, while large and bright, just doesn't have the contrast and..." Read Full Review »
Jul 30, 2009 by PianoMan
See more negative Viewsonic 22 in Wide LCD TV Model N2201W reviews
Displaying 1 - 5 of 13 Reviews
Show
Sort by
3.0
    Pros
  • Good Interface
  • Inexpensive
    Cons
  • Poor Picture Quality
    Best Uses
  • Home
"We purchased this to replace a Sony XBRITE LCD TV in our bedroom so we could get a disc spinner and a bigger size (the Sony was a meager 17"). Out of the box, build quality is average, you definitely get the feeling of plastic - the roots of this TV definitely carries over from a computer monitor. …"  Read Full Review »
Was this TV / DVD / VCR Combo review on the Viewsonic 22 in Wide LCD TV Model N2201W helpful to you?
Jul 30 2009
PianoMan
San Diego, CA
I am:
  • Enthusiast
Reviewed at:
Price: $324.95
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Set-up Manual Complicated
  • Simple Controls
    Cons
    Best Uses
  • Home
  • Movies
  • Office
Very reasonably priced and when I called Viewsonic be …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jul 16 2009
Klugs
Long Island, NY
I am:
  • Enthusiast
Reviewed at:
Price: $329.99
Great, Simple, Small Screen LCD TV
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
    Best Uses
  • Bedroom or Spare room
  • Home
  • Office
"So far this is just the tv I was looking for.
Simple to use. Built in DVD is useable and compact, not just an afterthought like some others with the built in. Remote has well thought out controls with buttons for features you actually use. The 1080i is a bit cheaper than a 1080p, but the differn …"  Read Full Review »
Dec 28 2008
Nick Name
California central coast
I am:
  • Casual User
Excellent TV combo
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Office
  • Video
"I ordered the N2201w 22" 720p LCD TV Viewsonic for my son's birthday. He has used it for a month now and it was a great buy. He has it connected to his PC as a very large computer monitor. Also using it for his Playstation and the built in DVD player. I would recommend...great picture and sound. …"  Read Full Review »
Mar 8 2009
Steve
Athens, GA
I am:
  • Casual User
Reviewed at:
Price: $324.95
Great product for the money
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
    Cons
  • None
    Best Uses
  • None
"I installed this TV/DVD combo on my boat in the salon area and it works absolutely perfectly. Great picture via over the air HD and great DVD picuture as well. Plenty of sound to fill the area and just a pleasure to watch. "
Sep 21 2009
Bob the Boater
Baltimore, MD
I am:
  • Enthusiast
Reviewed at:
Price: $324.95
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
