Viewsonic 19" Widescreen LCD HDTV/PC Monitor
#461
4.1
based on 20 reviews
Ratings Distribution
5 star
9
4 star
8
3 star
1
2 star
0
1 star
2
Category Average
4.4
$209.99 - $282.88
from 10 stores
More Images
Pros
  • Attractive design (13)
  • Fast setup (12)
  • Good connection options (11)
  • Great picture quality (10)
  • Simple controls (10)
  • High resolution (9)
  • Wide viewing angle (7)
  • Lightweight (2)
  • Versatile (2)
  • Vivid colors (2)
See less See more
Cons
  • Looses channels cuts off (1)
  • Low resolution (1)
  • Poor image quality (1)
  • Poor sound quality (1)
  • Poor video quality (1)
  • Volume (1)
Best Uses
  • Bedroom (6)
  • Home (6)
  • Kitchen (3)
  • Dorm room (2)
  • Wall mounting (2)
  • Gaming (1)
  • Hooked to a laptop (1)
  • Motorhome (1)
  • Movies (1)
  • Multimedia (1)
Provided by HSN
The Viewsonic 19" N1930W Widescreen LCD HDTV/PC Monitor is where high-definition meets high style and maximum versatility — all in one space-saving design. With the integrated HDTV tuner and 720p progressive-scan screen, you'll enjoy your favorite movies and TV shows in amazingly crisp detail. Then when the mood strikes, use the N1930W to surf the internet or immerse yourself in high-def PC gaming. And the built-in HDMI port opens up a world of options with connectivity to the latest HD devices. It's the perfect dual-purpose solution for the college dorm, kid's room, den or kitchen! Viewsonic 19" N1930W Widescreen LCD HDTV/PC Monitor Features: Fast 5ms video response — produces blur-free fast action movies, sports and games ClearPicture Technology — deliver clearer, crisper, sharper images by eliminating noise, increasing contrast and detail and optimizing color for rich, vibrant images ATSC tuner — means it's ready to receive over-the-air digital broadcasts Built-in stereo speakers — complete the multimedia experience Plug-and-Play connectivity Convenient controls — auto and manual adjustments; remote control included Compatible with PC or Mac Additional Product Specifications: TV Tuner: ATSC, NTSC, QAM Display: TFT active matrix LCD Resolution (in pixels): 1440 x 900, 1280 x 1024, 1360 x 768 (PC); 1440 x 900 (Mac) Aspect Ratio: 16:9 Brightness: 300 cd/m2 Dynamic Contrast Ratio: 4,000:1 — delivers richer blacks for better dark scene performance Response Time: 5ms Viewing Angles: 160 horizontal and vertical Video Input Formats: 480i, 480p, 720p, 1080i Child Lockout/V-Chip: Yes Inputs: HDMI, component (YPbPr/YCbCr), S-video, composite (RCA), PC RGB analog (VGA), cable/antenna (75 ohms), audio 3.5mm mini stereo audio, RCA (left/right) audio in Speakers: 2.5 watts per channel Mounting Bracket: Compatible with VESA 100mm x 100mm standard (mount not included) Measures approx. 17.4"W x 14.8"H x 6.1"Deep Weighs approx. 10.4 lbs. Power Requirement: 100 to 240 volts AC Power Consumption: 48 watts Model #: N1930W Made in China Accessories Include: Remote control with batteries VGA cable AV cable RF cable Power cable Quick-start and user guides
Specification Description
Model N1930W, N1930W-S, N1930w, VSCN1930W
UPC 766907299618
16:9 Mode Yes
Audio Controls Volume, balance, bass, treble
Battery Type Product
Battery Type Remote
Benefits 19" (diagonal) widescreen display delivers great 16:9 aspect ratio and up to 1440x900 resolutionBuilt-in ATSC/QAM/NTSC tuners provide
Brightness 300 cd/m2
Capacity UOM mAh
Chemistry Alkaline
Closed Caption Capability Yes
Color Depth 16.9 million
Color Temperature Control Yes
Compliant Standards UL, FCC, NOM, EN 55013, CB
Connections Antenna (1)HDMI (1)Component (1)Composite video RCA (1)VGA (1)S-video (1)Analog audio in
Controls / Adjustments Contrast, brightness, color, tint, sharpness, color temperature
Country Of Origin China
Description Header HD performance and style in a small package.
Display Catalog Number 16-865
Display Catalog Number 55031241
Display Languages English, Spanish, French
Display Menu Language English, Spanish, French
Display Size 19 inches
Enclosure Color Black
End Product Indicator Yes
Humidity Range Operating 10%~65%
Humidity Range Operating 10-90%
Image Aspect Ratio 16:9
Included in the Box ViewSonic® N1930w 19" LCD HDTVRemote control"AA" batteries (2)Power cordUser's guide
Manufacturer Labor Warranty 12
Manufacturer Part Number N1930w
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model N1930w
New Date Sun Jun 21 00:00:00 CDT 2009
Operating Temperature UOM ° F
Output Power / Total 5 watts
Parental controls Yes
Pixel Response Time 5 ms
Power Consumption Operational 48W
Product Depth 14.8
Product Depth 6.1
Product Dimensions UOM inches
Product Height 10.4
Product Height 14.8
Product Type Flat-panel TVs
Product Weight 10.4
Product Weight UOM pounds
Product Width 17.4
Reception System NTSC/ATSC/QAM
Screen Size Range 10-20"
Secondary Audio Program (SAP) Yes
Size AA
Sound Output Mode Stereo
Speaker(s) Built-in, 2.5W + 2.5W
Speakers Included 2 Speakers
Supported Languages English, Spanish, French
Technology IR
TV Diagonal Size 19 inches
TV Image Contrast Ratio 4000:1
TV Resolution 1440x900
TV Technology LCD
Type LCD
V-Chip Control Yes
Viewing Angle 160 Degrees
Viewing Angle (Vertical) 160 Degrees
Voltage 1.5
Voltage Required AC 100240V, (universal), 4763Hz
Voltage UOM Volts
Widescreen Modes 480i, 480p, 720p, 1080i
Viewsonic 19" Widescreen LCD HDTV/PC Monitor Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 2, 2009
Viewsonic 19" Widescreen LCD HDTV/PC Monitor Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[3 of 3 customers found this review helpful]
4.0
Exellent value and great pictures
"Needed a small TV for kitchen, did tons of research and picked the ViewSonic N1930. Fast and easy setup (under 15 minutes), no dead pixels, bright display. Sound is a bit "tinny" but that's to be expected from TV this size with small speakers. Easily solved by attaching a pair of PC speakers. Display is not tiltable so keep this in mind if you are not going to add a wall mount. Overall, an excellent buy and..." Read Full Review »
Jun 29, 2008 by Med Guy
See more positive Viewsonic 19" Widescreen LCD HDTV/PC Monitor reviews
1.0
Factory will not competely solve problem
"Had a NX1932W for ~ a year. Had problems from week one. Set looses nearly all channels (many, many times), cuts off for no reason, bad picture. Factory did help some at first but then stopped. If a View Sonic product fails, take it back to the store. I tried one last time to get them to fix/replace the product and got no response at all from Customer Service. I gave them chance after chance to resolve their..." Read Full Review »
Jan 27, 2009 by North Fork Hunter
See more negative Viewsonic 19" Widescreen LCD HDTV/PC Monitor reviews
Displaying 1 - 5 of 20 Reviews
Show
Sort by
1.0
    Pros
  • Attractive Design
  • Easy To Set Up
    Cons
  • Poor Video Quality
    Best Uses
  • Small Rooms
"Had a NX1932W for ~ a year. Had problems from week one. Set looses nearly all channels (many, many times), cuts off for no reason, bad picture. Factory did help some at first but then stopped. If a View Sonic product fails, take it back to the store. I tried one last time to get them to fix/repl …"  Read Full Review »
Was this LCD TV review on the Viewsonic 19" Widescreen LCD HDTV/PC Monitor helpful to you?
 Report Abuse  (3)  (0)  0 comments
Jan 27 2009
North Fork Hunter
Claremont/Hickory/Charlotte, NC
I am:
  • Casual User
looks good, sound is poor
3.0
    Pros
  • Attractive Design
  • Fast Setup
  • Good Connection Options
    Cons
  • Volume
    Best Uses
  • Kitchen
"I bought this TV to use in the kitchen. It fits perfectly on the 12" counter under the cabinets. It is easy to see from anywhere in our kitchen. I have standard cable hooked up to it and it found HD channels on its own. The quality of non-HD channels is OK. My biggest complaint is the sound. If …"  Read Full Review »
Mar 8 2009
partyof5
Middletown,NJ
I am:
  • Casual User
Reviewed at:
Price: $229.95
4.0
    Pros
  • Bright Image
  • Fast Setup
  • Good Resolution
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
"Needed a small TV for kitchen, did tons of research and picked the ViewSonic N1930. Fast and easy setup (under 15 minutes), no dead pixels, bright display. Sound is a bit "tinny" but that's to be expected from TV this size with small speakers. Easily solved by attaching a pair of PC speakers. Di …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jun 29 2008
Med Guy
Staten Island
I am:
  • Tech Savvy
Reviewed at:
Great set for older motorhome
4.0
    Pros
  • Attractive Design
    Cons
  • None
    Best Uses
  • Motorhome
  • Wall Mounting
"I live fulltime in a 1990 motorhome. Original 13" tv at front of RV was failing. With only minor work involved adjusted for installation of this TV to replace the original. I now have a larger set, great picture, like the optional channel list, optional tv guide for ota reception. This set fits so n …"  Read Full Review »
Jun 21 2009
George_R
Tacoma, WA
I am:
  • Power User
Thumbs up for sound and picture
5.0
    Pros
  • Adjustable
  • Lightweight
  • Versatile
  • Vivid Colors
    Cons
  • None
    Best Uses
  • None
"This 19 inch was great for my daughters New York apartment. She didn’t have very much room to work with to begin with but when we saw how this television we thought it would be perfect fit. It is very easy to set up and I was amazed at how fast we were able to learn the system. The sound and pictu …"  Read Full Review »
Dec 29 2008
Kristen and Angela
New York, NY
I am:
  • Quality Oriented
Reviewed at:
Price: $266.88
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
