Velbon Tripod El Carmagne Carbon Fiber 540
4.8
based on 5 reviews
from $174.95 - $339.99
Ratings Distribution
5 star
4
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.1
More Images
Pros
  • Easily adjusted (5)
  • Locks in tight (5)
  • Smooth movement (5)
  • Good footing (4)
  • Lightweight (4)
  • Compact (2)
  • Rugged (2)
See less See more
Best Uses
  • Travel (4)
  • Home (3)
  • Special events (3)
  • Sports (2)
  • Classroom (1)
  • Wilderness (1)
Provided by WolfCamera.com
Carmagne Series Tripods - The name Carmagne stands for CARBON FIBER and MAGNESIUM (Mg) - 3-section Carbon Fiber legs with die-cast Magnesium (Mg) alloy components combine to create a lightweight tripod of superior strength offering features not found in other conventionally designed tripods. Ideally suited for use with all 35mm SLRs and most medium format cameras.
This extremely light, yet very sturdy tripod is constructed with rigid Carbon Fiber Legs, a superior, durable Magnesium Body and Magnesium Panheads. Carbon fiber and magnesium materials are One Third Lighter than aluminum. This durable and versatile tripod has Low-Angle and Semi Low-Angle Positions with a Split Center Column, as well as scratch resistant Neoprene Grips and Rubber Feet. The effortless Lever Lock System enables extending or contracting the legs at any position even in cold weather. As a standard it comes with a Tripod Case, Stone Bag, Accessory Hook and a Limited Lifetime Warranty.
  • Carbon Fiber is 1/3 lighter than aluminum with strength superior to that of iron and aluminum. It is an excellent vibration absorbing material and is resistant to temperature changes.
  • Maximum versatility is achieved with its individually adjustable 3-position leg spread: normal, semi lowangle and full low-angle.
  • Die-cast Magnesium (Mg) alloy body for strength and light weight. Velbon was one of the first to utilize this method in the manufacturing of tripod components.
  • Carbon fiber black Finish
Velbon Tripods offer superb quality and exceptional value to everyone from the demanding professional to the enthusiastic hobbyist.
The El Carmagne 540 Tripod features
  • Includes 3-way Panhead (PH-250B)
  • 4 Section w/ split center column
  • Neoprene grips and rubber feet
  • Effortless Lever Lock System
  • Tripod Case
Specification Description
Model ELCARMA-540, ELCARMA540
UPC 017915515406
Maximum Capacity 20 Lbs & More
Maximum Height 48" to 59.9"
Select Carbon Fiber
Velbon Tripod El Carmagne Carbon Fiber 540 Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 7, 2008
Velbon Tripod El Carmagne Carbon Fiber 540 Reviews
Displaying 1 - 5 of 5 Reviews
Show
Sort by
Velbon Tripod
5.0
    Pros
  • Compact
  • Easily Adjusted
  • Good Footing
  • Lightweight
  • Locks In Tight
  • More »
    Cons
  • None
    Best Uses
  • Classroom
  • Home
  • Special Events
  • Travel
  • Wilderness
"Right now am using it for school mostly but also use it for wildlife photography, still photos, and potraits. It is excellant for trekking up threw the woods and setting up for wildlife photography. It isn't heavy or cumbersome. You don't need to make special trips back to the car just for your trip …"  Read Full Review »
sneeky gator
sneeky gator
  • Using Product
Trying To Hide
Trying To Hide
  • Using Product
Was this Camera Tripod review on the Velbon Tripod El Carmagne Carbon Fiber 540 helpful to you?
Nov 5 2008
daisy311
NE GA
I am:
  • Hobbyist/Enthusiast
Reviewed at:
[10 of 10 customers found this review helpful]
Solid
4.0
    Pros
  • Easily Adjusted
  • Locks In Tight
  • Smooth Movement
    Cons
  • None
    Best Uses
  • Travel
"I just used this tripod for a week in the Sierra and White Mtns. It performed better than expected and made a stable support for 35mm, 6x9, and 4x5 in varying conditions. I used it around the car, day hiking, and on a couple overnight backpacks. I got the 540 because of the shorter collapsed leg s …"  Read Full Review »
 Report Abuse  (10)  (0)  0 comments
Jun 15 2008
Sierra Hiker
San Pedro, CA
I am:
Reviewed at:
Price: $179.99
[1 of 1 customers found this review helpful]
Great Tripod
5.0
    Pros
  • Easily Adjusted
  • Good Footing
  • Lightweight
  • Locks In Tight
  • Rugged
  • More »
    Cons
  • None
    Best Uses
  • Special Events
  • Sports
  • Travel
"Very light, yet extremely strong. Able to hold my D200 with 70-200 f2.8 without any movement for multi exposures. Weight bag convenient for uneven terrain. Only downside is having to unscrew the vertical handle from the horizontal handle to store. Would recommend for anyone with Heavy equipment. "
 Report Abuse  (1)  (0)  0 comments
Aug 25 2008
Jody Johns Photography
Atlanta, GA
I am:
Reviewed at:
Outstanding Value
5.0
    Pros
  • Compact
  • Easily Adjusted
  • Good Footing
  • Lightweight
  • Locks In Tight
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Special Events
  • Sports
  • Travel
"I really like this product. It is reasonably priced and a great value. I use it indoors and out. Works great. "
Nov 7 2008
Ed
Cincinnati Ohio
I am:
Reviewed at:
5.0
    Pros
  • Easily Adjusted
  • Good Footing
  • Lightweight
  • Locks In Tight
  • Rugged
  • More »
    Cons
  • None
    Best Uses
  • Home
"I purchased this product because of its durability, light weight and adjusts quite easily. It's been great! "
Aug 25 2008
Gail
Saint Paul, MN
I am:
  • Getting started
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
$179.99
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$174.95
BizRate Rating Outstanding 9.2
$303.99
$324.99
Code SEARS5OFF50 : $5 Off Orders Over $50!
$324.99
Code KMART5OFF50 : Save $5 off $50 with coupon
$339.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
