Vector 1000 Watt Maxx Power Inverter with USB Port - VEC049D
#166
1.0
based on 1 review
Ratings Distribution
5 star
0
4 star
0
3 star
0
2 star
0
1 star
1
Category Average
3.9
Low Price:
$122.47 at Shoppers Choice
 Trusted:
$139.00 at Rainbow Appliance
Find it at Amazon
$122.47 - $171.80
from 3 stores
More Images
Pros
  • Cheap (1)
  • Compact design (1)
  • Easy to install (1)
  • Simple / intuitive controls (1)
See less See more
Cons
  • Auto reset don't work (1)
  • Not for solar power uses (1)
  • Runs hot (1)
  • Unreliable (1)
Best Uses
  • Useless (1)
Maxx SST 1000 Watt power inverters enables automobile, truck or RVs 12 volt DC system to convert to AC household current to run appliances. These inverters range from 70 to 3000 watt input and are perfect for computers, power tools, buffers, TV/VCRs, stereos and blenders. In addition, Vector's inverters have UL approved, another statement of rigid quality assurance. Vector introduces a new line of Digital Smart Control (DCS) power inverters - a revolutionary advancement in power inverters.
  • 1000 watt continuous power/2000 watt peak
  • Converts vehicle's 12 volt dc to 110/120 volt ac household power
  • Soft Start Technology (SST)
  • Short Circuit Protection and fault interrupter shock protection
  • Automatic Reset
  • New turbo cooled heat sink design
  • New noise free technology— prevent TV Buzz, Snow & Static lines
  • Three grounded AC outlets
  • One USB Port
  • High surge capability
  • Powerful internal HIGH-SPEED cooling fan
  • High and low voltage protection
  • Overload protection
  • Low battery alarm and low battery shutdown
Maximum Continous Power1000 Watts
Surge Capacity (Peak Power)2000 Watts
Maxuimum EfficiencyApprox. 90%
No Load Current Draw0.6 Amps
Input Voltage Range10.5 - 15.5 VDC
Output Voltage110/120V AC 60 HZ
Under Voltage Shutdown10.0 Volts
Thermal ShutdownAuto Resets
Wave FormFilterd Modified Sine Wave
Internal Fuse35 Amp (Spade Type)
  • 2 Year Limited Warranty.
  • Specification Description
    Model 049D, 617977000768, VEC 049, VEC049
    UPC 617977000768
    Product Details Offering 1000-watts continuous power, the VEC049 Power Inverter from Vector® gives you enough power to operate many of your favorite household electronics from inside your vehicle.  Featuring noise-reducing technology, this power inverter provides a quieter power option than some other inverters. Plus, with three household AC power receptacles, this power inverter allows for multiple devices to simultaneously charge or operate.
    Vector 1000 Watt Maxx Power Inverter with USB Port - VEC049D Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Jul 18, 2008
    Vector 1000 Watt Maxx Power Inverter with USB Port - VEC049D Reviews
    Displaying 1 - 1 of 1 Reviews
    Show
    Sort by
    A waste of Money Buy A Zantrex Inverter
    1.0
      Pros
    • Cheap
    • Clear Controls
    • Compact Design
    • Easy To Install
      Cons
    • Not for Solar power uses
    • Runs Hot
    • Unreliable
      Best Uses
    • Useless
    "I've had this inverter for a Year now and last sunday it cranked out. I use it on my solar power system to charge my laptop after charging was complete i switched it off and then on a couple of minutes later. Amazing enough the fault light and the power light was on and the fan was spinning up and d …"  Read Full Review »
    Was this Car Audio & Electronics Accessory review on the Vector 1000 Watt Maxx Power Inverter with USB Port - VEC049D helpful to you?
    Jul 18 2008
    Genuine American
    Kansas
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
