#347
based on 22 reviews
Ratings Distribution
| 5 star |
17 |
| 4 star |
4 |
| 3 star |
1 |
| 2 star |
0 |
| 1 star |
0 |
Category Average
Pros
Cons
Best Uses
Where to Buy
BizRate Rating
Outstanding 9.1
Product Reviews
[8 of 8 customers found this review helpful]
[16 of 16 customers found this review helpful]
"These mounts are the best you can buy in terms of quality, features and price. 1. These can be wall mounted or ceiling mounted. 2. Can be used for speakers with key hole type mount or the built in metalic hole type mount. 3. Comes with 2 screws for installing the mount itself. Also included are 2 alligator clips for mounting on a drywall. 4. Comes with several different types of screws to install almost any k..." Read Full Review »
Feb 03, 2006 by P. Chaturvedi
See more positive Vantage Point Satellite Speaker Mount reviews
"For smaller, lighter weight satellites (I'm guessing 4 lbs or less), these are a really good deal. As other reviewers have said, they come with a lot of hardware for different types of speakers, including a key-hole adapter. However, for heavier speakers that come close to the manufacturer's stated limit (8 lbs), these aren't great. I just hung 4 Infinity Primus 140's with these. The 140's are 7 lbs and phys..." Read Full Review »
Sep 18, 2006 by Doug Funny
See more negative Vantage Point Satellite Speaker Mount reviews
Displaying 1 - 5 of 22 Reviews
Vantage Point Satellite Speaker Mount Review
"For smaller, lighter weight satellites (I'm guessing 4 lbs or less), these are a really good deal. As other reviewers have said, they come with a lot of hardware for different types of speakers, including a key-hole adapter. However, for heavier speakers that come close to the manufacturer's state …" Read Full Review »
Read Full Review »
[10 of 10 customers found this review helpful]
"I bought these to mount a Paradigm Cinema series in the basement. They did a solid job. I wouldn't recommend them if you continuously make adjustments in the speaker position (loosening and tightening the set screws). The set screws will eventually wear out. Otherwise, if you need to set it up, …" Read Full Review »
[14 of 14 customers found this review helpful]
"I have used it for wall mounting as well as ceiling mounting
Its very sturdy and easily held on to my 5 lb Polk RM 7200 speakers.
Its finishing is good and can be oriented easily in all directions.
I have configured it at a 90 degree angle for my front speakers
Much better option than buying more ex
Read Full Review »
[6 of 6 customers found this review helpful]
"After looking in local electronics stores for speaker mounts, I could find nothing under $90. I came across these Vantage Point mounts and was skeptical at first because they were offered at such a lower price than what I had seen in stores. Nevertheless I ordered 2. These items arrived and my hu …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
