Uniden DECT 6.0 Expandable Cordless Phone with Call-Waiting Caller ID
#188
3.3
based on 12 reviews
Ratings Distribution
5 star
5
4 star
1
3 star
2
2 star
0
1 star
4
Category Average
3.6
$54.99 - $79.00
from 3 stores
More Images
Pros
  • Simple / intuitive controls (3)
  • Clear reception (2)
  • Durable (2)
See less See more
Cons
  • Poor reception / weak antenna (1)
Best Uses
Provided by Best Buy
Chat with your friends and family on this water-resistant phone, which features a large 3-line LCD display with a backlit keypad for easy viewing even in dim light. The call-waiting/caller ID feature allows you to know who is calling before you answer the phone.
Specification Description
Model WXI2077
UPC 050633271643
Antenna Internal
Battery Type Product
Benefits Floating, waterproof handset expandable to 10 handsetsBuilt-in handset speakerphone for handsfree freedomAdvanced phonebook
Cables Included Telephone line cable
Call Forwarding Yes
Call Hold Yes
Call Transfer Yes
Call Waiting Yes
Caller ID Yes
Caller ID on base Yes
Caller ID waiting Yes
Capacity UOM mAh
Chemistry Ni-MH
Conference Call Capability Yes
Connections RJ11 telephone (1)
Cordless Phone Standard DECT
Country Of Origin Vietnam
Description Header Catch your calls from your lawnchair.
Dial-Back Function Yes
Dialer Location Handset
Dialer Type Keypad
Digital Transmission Yes
Display Catalog Number 55033087
Enclosure Color Yellow
End Product Indicator Yes
Function Buttons Navigation keys, Talk key, Hang-up/Exit key, Menu key, Loudspeaker key, Redial key, Keypad lock/format key, OK key, Back/clear key, Call tranfer/Inter
Handset Locator Yes
Hearing Aid Compatible Yes
Included in the Box Uniden® WXI2077 DECT 6.0 (1.9GHz) Submersible Handset PhoneRechargeable Ni-MH batteryBase station with bracketA
Intercom Yes
Manufacturer Labor Warranty 12
Manufacturer Part Number WXI2077
Manufacturer Parts Warranty 12
MAP Price 49.99
Max Handsets Supported 10 Handsets
Model WXI2077
Multiline Operation Capability Single-line
Operating Temperature UOM ° F
Power Device AC adapter
Product Disclaimer *Call Waiting/Caller ID require phone company service.
Product Type DECT phones
Rechargeable Yes
Ring Tones 7 Tones
Ringer Control Yes
Size Pack
Speakerphone Yes
Speed dial Yes
Supported Languages English, Spanish
Transmission Band 1.9 GHz
Transmission Band UOM GHz
Volume Control Yes
Walkie-Talkie Mode Yes
Water-Resistant | Waterproofness Standard Yes
Waterproof/Water Resistant Yes
Uniden DECT 6.0 Expandable Cordless Phone with Call-Waiting Caller ID Questions
Questions and Answers
Where to Buy
$69.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$54.99
$79.00
Product Reviews
Last update: Sep 27, 2009
Uniden DECT 6.0 Expandable Cordless Phone with Call-Waiting Caller ID Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[1 of 1 customers found this review helpful]
5.0
VERY DURABLE!
"I USE THIS PHONE AT WORK. IT IS VERY DURABLE. I HAVE DROPPED IT SEVERAL TIMES,ON CONCRET FLOORS, IT JUST BOUNCES. ALSO IT IS WATER PROOF, WHAT MORE COULD YOU ASK FOR?..." Read Full Review »
Aug 19, 2009 by OKIE
See more positive Uniden DECT 6.0 Expandable Cordless Phone with Call-Waiting Caller ID reviews
1.0
I would not recommend this phone
"This phone will not let me answer or talk on the phone even on my patio. Sometimes, even when I am in the house I get static and then disconnected!! Worst phone I ever have had. Wanted a phone I could take out in the yard and by the pool. This is not it, for sure!!!..." Read Full Review »
Aug 30, 2009 by Deb the gardener
See more negative Uniden DECT 6.0 Expandable Cordless Phone with Call-Waiting Caller ID reviews
Displaying 1 - 5 of 12 Reviews
Show
Sort by
1.0
    Pros
  • Easy Controls
    Cons
  • Poor Reception
    Best Uses
  • None
"This phone will not let me answer or talk on the phone even on my patio. Sometimes, even when I am in the house I get static and then disconnected!! Worst phone I ever have had. Wanted a phone I could take out in the yard and by the pool. This is not it, for sure!!! "
Was this Telephone Accessory review on the Uniden DECT 6.0 Expandable Cordless Phone with Call-Waiting Caller ID helpful to you?
 Report Abuse  (1)  (0)  0 comments
Aug 30 2009
Deb the gardener
Millington TN
I am:
  • Practical
Reviewed at:
Price: $69.99
VERY DURABLE!
5.0
    Pros
  • Clear Reception
  • Durable
  • Easy Controls
    Cons
  • None
    Best Uses
  • None
"I USE THIS PHONE AT WORK. IT IS VERY DURABLE. I HAVE DROPPED IT SEVERAL TIMES,ON CONCRET FLOORS, IT JUST BOUNCES. ALSO IT IS WATER PROOF, WHAT MORE COULD YOU ASK FOR? "
 Report Abuse  (2)  (0)  0 comments
Aug 19 2009
OKIE
STILLWATER, OK
I am:
  • Practical
Reviewed at:
Price: $69.99
tough and actually waterproof
5.0
    Pros
  • Clear Reception
  • Durable
  • Easy Controls
    Cons
  • None
    Best Uses
  • None
"It's actually waterproof, i will float it or throw it to someone to use while in the pool or spa and it freaks everyone out when it works like a champ, "
Aug 31 2009
KD
Las Vegas, NV
I am:
  • Practical
Reviewed at:
Price: $69.99
Extremely Durable and Waterroof!
5.0
"If you have a pool, Hot tub, (It floats), do a lot of yard work or have a work shop, this is the phone for you. There are very few options available for a rough service phones and this one is the best I have tried. After doing a lot of research I decided to go with Uniden. Uniden has a great reputat …"  Read Full Review »
Dec 1 2008
HomeyGee
Boston
Reviewed at:
Price: $54.99
This phone has been great ...
5.0
"This phone has been great for my family. The design is great because of the large display and bright screen. It is nice to be able to take it outside and not worry about it being dropped and destroyed. It is a little bit heavier, but that even has it's plus side. It is easy to locate and doesn't tak …"  Read Full Review »
Jul 18 2009
DLBSH
Memphis, Tn
Reviewed at:
Price: $54.99
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
