Uniden CRS 300 Channel Clock Radio Base Scanner
#12
3.4
based on 10 reviews
Ratings Distribution
5 star
4
4 star
2
3 star
1
2 star
0
1 star
3
Category Average
3.9
Low Price:
$147.99 at Kmart
 Trusted:
$149.00 at Rainbow Appliance
Find it at Amazon
$147.99 - $199.99
from 16 stores
More Images
Pros
  • Clear signal (5)
  • Easy to use (3)
  • Lightweight (3)
  • Accurate controls (2)
  • Nice sound (2)
  • Compact (1)
  • Cool design (1)
  • Durable (1)
  • Easy setup (1)
  • Gobs of features (1)
See less See more
Cons
  • Audio not good (1)
  • Confusing / difficult controls (1)
  • Med learning curve (1)
  • Poor quality (1)
  • Poor reception (1)
  • Short range (1)
  • Similar scanner died (1)
Best Uses
  • Emergencies (5)
  • Audiophiles (1)
  • Basic systems (1)
  • Beginer (1)
  • Boat anchor (1)
  • Families (1)
  • Hwy accidents (1)
  • Larger rooms (1)
  • Police detours (1)
  • Smaller rooms (1)
Provided by DollarRite
Uniden BC370CRS Bearcat Scanner
- Atomic clock
- All hazard alert
- AM/FM radio with 30 presets
- Backlit display
- Weather scan
- Includes 800MHz
- 300 Channels in 10 banks
- Service search (police fire EMS airham marine)
- Audio TV CH 2-13
- Alarm clock with snooze
- 3 AA batteries required for backup not included
- Black
Specification Description
Model BC-370CRS, BC370CRS, UNNBC370CRS
UPC 050633650479
adjustable auto date/timeĀ  Yes
AM/FM Mode Yes
Antenna Type AM loop
Audible Battery Alert Yes
Benefits Band coverage from 25-54, 108-174, 225-380, 406-512 and 806-956MHz (excluding cellular bands)10 banks of 300 channels include 30 pres
Built-in Clock Digital clock with alarm
Capacity UOM mAh
Channel Scan Yes
Controls Volume, squelch, scan, hold, time set, alarm, snooze, mode, program
Country Of Origin China
Description Header Stay informed.
Desktop Design Yes
Display Catalog Number 55020872
Display Form Factor Built-in
Display Illumination Color Orange
EEPROM memory backup Yes
End Product Indicator Yes
Features Skip over stored frequencies using the lockout feature to enable faster scanningAutomatic squelch, channel lockout and memory backup
Form Factor Telescopic
Frequency Coverage 25-54MHz, 108-174MHz, 225-380MHz, 406-512MHz and 806-956MHz (excluding cellular bands)
Frequency Storage 300 channels in 10 banks
Included in the Box ScannerAM loop antennaTelescopic antennaAC adapter
Includes NOAA Weather Channels Yes
Inputs 1 x (Antenna jack), 1 x (AM radio antenna jack), 1 x (DC 12V power jack)
Manufacturer Labor Warranty 12
Manufacturer Part Number BC370CRS
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 122 Fahrenheit
Memory Channels 300 Channels
Min Operating Temperature 14 Fahrenheit
Model BC-370CRS
Mounting Kit Optional
No. of Preset Counties 4 Counties
Operating Temperature UOM ° F
Outputs 1 x (Headphone jack)
Power Device AC adapter
Preprogrammed Frequencies Yes
Product Dimensions UOM inches
Product Disclaimer Warranty is 1 year limited. Mobile use of scanners may be unlawful in some areas or may require a permit. Check with local authorities.
Product Height 3.18
Product Length 5.81
Product Type Scanners
Product Weight 1.32
Product Weight UOM pounds
Product Width 7.87
Scanner Type Non-trunking
Supported Languages English
Type LCD
Weather Alert Yes
Uniden CRS 300 Channel Clock Radio Base Scanner Questions
Questions and Answers
Where to Buy
$149.95
$10 Off Orders Of Orders Over $85 + Free Shipping
$149.00
$147.99
Code KMART5OFF50 : Save $5 off $50 with coupon ends 12/31/09
Show all 16 stores
Product Reviews
Last update: Oct 30, 2009
Uniden CRS 300 Channel Clock Radio Base Scanner Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
[9 of 9 customers found this review helpful]
5.0
great NON-trunktracker!!!
"Because of city, state and county budget contraints, many fire and rescue depts have "not" gone to digital or scrambling systems(check your local first) this receiver is great for such analog systems. I had a trunktracker but found there were just too many entries to be made to get it to work. I would recommend an outside antenna to pull in the weaker signals but can say most of the channels can be received wit..." Read Full Review »
Nov 29, 2007 by Don
See more positive Uniden CRS 300 Channel Clock Radio Base Scanner reviews
1.0
IT DOES NOT PICK THE LATEST CODES!
"WHEN I PURCHASED THIS ITEM I DID SO AT A LIVE RADIO SHACK. THE SALESMAN TOLD ME "YES THIS WILL PICK UP THE NEW DIGITAL CODES". HE ACTUALLY PLACED THE ORDER FOR ME. I WANTED TO BE CERTAIN I BOUGHT THE RIGHT SCANNER FOR THE LATEST CODES. GUESS WHAT? IT DOES NOT! I MADE 3 TRIPS TO THIS STORE FOR HELP. 1. THE PURCHASE 2. I CANNOT GET THIS TO WORK. I WAS TOLD TO COME BACK THE FOLLOWING SATURDAY AS THE GUY THAT COULD ..." Read Full Review »
Apr 05, 2009 by LILMAE
See more negative Uniden CRS 300 Channel Clock Radio Base Scanner reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
1.0
"WHEN I PURCHASED THIS ITEM I DID SO AT A LIVE RADIO SHACK. THE SALESMAN TOLD ME "YES THIS WILL PICK UP THE NEW DIGITAL CODES". HE ACTUALLY PLACED THE ORDER FOR ME. I WANTED TO BE CERTAIN I BOUGHT THE RIGHT SCANNER FOR THE LATEST CODES. GUESS WHAT? IT DOES NOT! I MADE 3 TRIPS TO THIS STORE FOR HELP. …"  Read Full Review »
Was this Communication System review on the Uniden CRS 300 Channel Clock Radio Base Scanner helpful to you?
 Report Abuse  (9)  (0)  0 comments
Apr 5 2009
LILMAE
INDIANA
Reviewed at:
Price: $149.95
[8 of 9 customers found this review helpful]
beware
1.0
    Pros
  • None
    Cons
    Best Uses
  • Boat anchor
"i have other scanners that are thirty plus years old that still work great. bought a radio shack scanner a while back and it malfunctioned not long after purchase. has gone out again, with no satisfaction from the company. this unit was faulty from the beginning and they knew it. i will no longer be …"  Read Full Review »
 Report Abuse  (8)  (1)  0 comments
May 3 2009
disgusted
crawfordville, fl
I am:
  • Practical
Reviewed at:
Price: $149.95
[6 of 6 customers found this review helpful]
BC370CRS
1.0
    Pros
  • Lightweight
    Cons
  • Difficult Controls
  • Poor Reception
  • Short Range
    Best Uses
  • Emergencies
"I'm sorry I bought it. The Radio Shack Pro 2060 is 10 times the scaner. Can't get anything out of it. The Atomic clock is nice. I'd pass this one up. "
 Report Abuse  (6)  (0)  0 comments
Oct 14 2008
Mr. Bob
Champlin, Minnesota
I am:
  • Avid Adventurer
Reviewed at:
Price: $149.95
5.0
    Pros
  • Clear Signal
    Cons
    Best Uses
  • Emergencies
  • Hwy accidents
  • Police detours
"Because of city, state and county budget contraints, many fire and rescue depts have "not" gone to digital or scrambling systems(check your local first) this receiver is great for such analog systems. I had a trunktracker but found there were just too many entries to be made to get it to work. I wou …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Nov 29 2007
Don
Jax.,Fla....Sunshine State..
I am:
  • Casual/ Recreational
[4 of 5 customers found this review helpful]
Too much whiz and not enough bang
3.0
    Pros
  • Durable
  • Runs up to 24hr on 3-AA
    Cons
  • Audio not good
  • Low Quality
    Best Uses
  • Beginer
"Well made scanner but it lacks audio output and sensitivty. Also, the instruction manuel is not easy for the average person to set up the atomic clock. Besides that, the fact that this scanner can operate on 3-AA batteries during a power failure is GREAT. "
 Report Abuse  (4)  (1)  0 comments
Sep 7 2007
Bob
Tuckahoe,NY
Reviewed at:
Price: $149.95
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
