Uniden BC-246T 800 MHz 1600 Channel Handheld Scanner
#10
4.4
based on 22 reviews
from $224.99 - $239.99
Ratings Distribution
5 star
14
4 star
5
3 star
2
2 star
0
1 star
1
Category Average
3.9
More Images
Pros
  • Durable (8)
  • Consistent performance (5)
  • Versatile (5)
  • Easy to configure (4)
  • Clear signal (3)
  • Easy to use (3)
  • Good value (3)
  • Lightweight (3)
  • High quality (2)
  • Rugged (2)
See less See more
Cons
  • Difficult to configure (2)
  • Bad directions (1)
  • Can't use trunking (1)
  • Confusing / difficult controls (1)
  • Must carry manual to prog (1)
  • Time staking to program (1)
  • Uniden knows nothing (1)
Best Uses
  • Travel (5)
  • In the car (4)
  • Portable devices (4)
  • Emergencies (3)
  • Home (2)
  • Air (1)
  • Camping (1)
  • Cb (1)
  • Easy listening (1)
  • Families (1)
Provided by Sears
Uniden is creating a World Without Wires. Which means that Uniden is building products that give its customers more freedom to enjoy life, solve problems and always stay connected with others. From cordless phones to two-way radios to radar detectors, the company makes electronic wonders an everyday occurrence. As one of the world's largest manufacturers of cordless phones and consumer communications devices, chances are there's a Uniden product that's already making things more convenient in an
Specification Description
Model 1806967, BC 246T, BC-246T, BC246T
UPC 050633650400
Audible Battery Alert Yes
Benefits Specific 6-band coverage ranging from 25MHz to 1300MHz (excluding cellular)CloseCall™ RF technology detects nearby radio frequen
Capacity UOM mAh
Channel Scan Yes
Country Of Origin China
Description Header Scanning made easy.
Display Catalog Number 55016549
Display Form Factor Built-in
Display Illumination Color Orange
End Product Indicator Yes
Features 10 custom and 10 preprogrammed search capabilities for plenty of optionsAutomatic repeater reverse, pager skip and channel alert give
Frequency Coverage 25-54, 108-174, 216-225, 400-512, 806-956, 1240-1300 MHz (Excluding Cellular)
Handheld Design Yes
Included in the Box ScannerWrist strapConnection cableBelt clipAC adapterBatteriesAntenna
Includes NOAA Weather Channels Yes
Includes SAME Alerts Yes
Manufacturer Labor Warranty 12
Manufacturer Part Number BC-246T
Manufacturer Parts Warranty 12
MAP Price 0.0
Marine Band Yes
Memory Channels 2500 Channels
Model BC-246T
Operating Temperature UOM ° F
Preprogrammed Frequencies Yes
Product Dimensions UOM inches
Product Disclaimer Warranty is 1 year limited.
Product Height 4.6
Product Length 1.26
Product Type Scanners
Product Weight 0.48
Product Weight UOM pounds
Product Width 2.72
Scanner Type Single trunking
Supported Languages English
Type Backlit LCD
Weather Alert Yes
Uniden BC-246T 800 MHz 1600 Channel Handheld Scanner Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: May 11, 2009
Uniden BC-246T 800 MHz 1600 Channel Handheld Scanner Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
5.0
Its user friendly if you have software
"I will say that this was a well thought out scanner for those that enjoy a manual in their pocket. The Close call feature is nice. Without the manual it maybe the only way you can program it. The Close call feature works very well. This scanner is good for those that do not have Digital systems in use by their Police or other emergency personel. I just found out that an area Police agency will be rebanded from 8..." Read Full Review »
Sep 09, 2007 by Chuck
See more positive Uniden BC-246T 800 MHz 1600 Channel Handheld Scanner reviews
3.0
Good if you don't use batteries
"I use this product to keep track of road conditions, weather and emergencies. I am disappointed with the scanner because I frequently have to use batteries. I go threw a LOT of batteries. If you need a scanner that is portable and have to rely on batteries, I WOULD NOT recommend this scanner...." Read Full Review »
Dec 25, 2008 by Sonny
See more negative Uniden BC-246T 800 MHz 1600 Channel Handheld Scanner reviews
Displaying 1 - 5 of 22 Reviews
Show
Sort by
5.0
    Pros
  • Clear Signal
  • Fits in your pocket.
  • Lightweight
    Cons
  • Difficult Controls
    Best Uses
  • Camping
  • Emergencies
  • Hiking
  • Shopping Malls
"I will say that this was a well thought out scanner for those that enjoy a manual in their pocket. The Close call feature is nice. Without the manual it maybe the only way you can program it. The Close call feature works very well. This scanner is good for those that do not have Digital systems in u …"  Read Full Review »
Was this Home Electronics & Gadget review on the Uniden BC-246T 800 MHz 1600 Channel Handheld Scanner helpful to you?
 Report Abuse  (2)  (0)  0 comments
Sep 9 2007
Chuck
North Carolina
I am:
  • Casual/ Recreational
[3 of 3 customers found this review helpful]
This one is a winner!
4.0
    Pros
  • Consistent Performance
  • Durable
  • Easy To Configure
  • Versatile
    Cons
  • None that I can find.
    Best Uses
  • In The Car
  • Portable Devices
  • Travel
"I don't know how the previous reviewer could possibly call himself tech savy and make the statements about this scanner he did! This scanner is a winner. Uniden did good coming up with their Dynamic Memory Architecture (DMA) scheme. It runs circles around the standard bank/channel method. There …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Feb 20 2008
David
Virginia
I am:
  • Tech Savvy
It is the best scanner ever
5.0
    Pros
  • Durable
  • Good Value
  • High Quality
  • Programming a new system
    Cons
    Best Uses
  • Firemen in front of house
  • My company radios at once
  • Paramedics near by
  • Police around the corner
  • To listen to
"I love how it also allows you to type in frequencies [...] When programming remeber that there are subfolders like in a computer and a new system means the big folder. When you progam a new sytem do not be afraid it will not erase what has been pre programmed just do not save it under number 9 or yo …"  Read Full Review »
Aug 12 2007
tony s
Chicago IL
A Great Railroad Scanner .
5.0
    Pros
  • Durable
  • Easy To Configure
  • Excellent Reception
  • Great sound
  • More »
    Cons
  • None
    Best Uses
  • Air
  • CB
  • In The Car
  • Noaa
  • Portable Devices
  • More »
"This scanner beats the Pro-84 to the ground on the Range , Alpha Tags , with the software It is easy to program . I use it for Air , CB , Police , Fire and Rail listing to . Would buy it again . "
Apr 21 2008
CJ the FL Railfan .
DeFuniak Springs , FL.
I am:
  • Railfan
  • Tech Savvy
[1 of 1 customers found this review helpful]
"I was looking for a ...
5.0
"I was looking for a scanner that could help with traffic conditions live from those who are communicating about them, well this one has all the features you could ask for. Police, fire, EMS, GMRS/FRS (those walkie talkies mainly used by families traveling down the highway or at parks) and CB radio. …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
May 31 2006
Ray J
Undisclosed
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
