#93
based on 78 reviews
Ratings Distribution
| 5 star |
50 |
| 4 star |
13 |
| 3 star |
11 |
| 2 star |
3 |
| 1 star |
1 |
Category Average
Low Price:
Trusted:
Where to Buy
| $1.99 Shipping On Orders Over $100 at TigerDirect ends 12/31/09 |
BizRate Rating
Outstanding 9.1
| $1.99 Shipping on Orders Over $75 ends 12/31/09 |
Product Reviews
"Certainly not at the very high end, but it does the job quite well. The beef I have with it is that all the aluminum edges are sharp as hell, even on the tension bar... You could easily cut yourself installing this puppy. It is a little bigger than I had imagined, which I guess helps in heat dissipation... However, running a plastic fan at 2800rpm doesn't circulate as much air as I'd hope, though it's fine ev..." Read Full Review »
Mar 27, 2009 by bkl
See more positive Ultra Products Ultra X-Wind CPU Fan reviews
"I put this on my 5000+ BE about 8 months ago. The only real pro about it is it cooled my north bridge and RAM because of it's design. With my BE running at 3.1 Mhz it would hit 55C within two minutes, so I pulled it, lapped it, lapped my processor, and got it down to 53C after 2 minutes under load, and 55C after 2 hours of PRIME 95. This was using Arctic Silver 5 for my TIM, and using the minimum amount. I wou..." Read Full Review »
Mar 17, 2009 by billy66bar
See more negative Ultra Products Ultra X-Wind CPU Fan reviews
Displaying 1 - 5 of 78 Reviews
Ultra Products Ultra X-Wind CPU Fan Review
Read Full Review »
"I liked the low profile design but the CPU/HS contact points are really bad. This might work on AMD64's fine but my AMD64 X2 6400+ Black Edition went to max temp of 71c, Idled in the mid 30's. Removed and reinstalled Silver thermal compound to make sure paste wasn't the problem, no change. Ordered a …" Read Full Review »
"Certainly not at the very high end, but it does the job quite well. The beef I have with it is that all the aluminum edges are sharp as hell, even on the tension bar... You could easily cut yourself installing this puppy. It is a little bigger than I had imagined, which I guess helps in heat diss …" Read Full Review »
"Purchased this HSF to put on my old system (AMD Sempron 64bit 1.8 GHz Socket 939), it is not that big really, it has a large circumference but I would not call it ''big''. Big, get something like the OCZ Vanquisher or the Chilltec hehe. I like this one though, even though I put it on my old low end …" Read Full Review »
"I did not have an issue attaching as described in other reviews. AMD Quad core running around 30-35C with this fan. Great value for the price. Only has 3 wire plug so not able to regulate fan speed. "
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Outstanding 9.1
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
