#28
based on 59 reviews
Ratings Distribution
| 5 star |
40 |
| 4 star |
12 |
| 3 star |
1 |
| 2 star |
0 |
| 1 star |
2 |
Category Average
Pros
Cons
Best Uses
Where to Buy
| $1.99 Shipping On Orders Over $100 at TigerDirect |
BizRate Rating
Outstanding 9.1
Product Reviews
"A solid HD enclosure. Simple to set up besides the absurdly tiny screws used to seal it. You'll need a Philips head screwdriver for eyeglasses screws which I didn't have so it was a pain. Also, it's unclear to me why there's a power port and plug provided since the USB connection provides power. (I'm guessing it might be for USB 1.0 compatibility which maybe doesn't provide power through the connection?) And the..." Read Full Review »
Mar 07, 2009 by Ninjawa
See more positive Ultra Products USB 2.0 External Drive Enclosure for 2.5" PATA Hard Drive reviews
"I bought this unit to recover data from a dead laptop. At about $22, that was a cheap data recovery. I never assembled mine...I just plugged the PCB into the drive, hooked up the usb, and it worked. Highly recommended. EDITOR'S NOTE: BASED ON THE REVIEWER'S COMMENTS, IT IS OBVIOUS THAT HE INTENDED TO ASSIGN A BETTER RATING THAN THE ONE STAR THAT HE ULTIMATELY SELECTED. PLEASE TAKE THIS INTO CONSIDERATION...." Read Full Review »
Aug 01, 2007 by Stevec31
See more negative Ultra Products USB 2.0 External Drive Enclosure for 2.5" PATA Hard Drive reviews
Displaying 1 - 5 of 59 Reviews
Ultra Products USB 2.0 External Drive Enclosure for 2.5" PATA Hard Drive Review
Pros
Cons
Best Uses
"A solid HD enclosure. Simple to set up besides the absurdly tiny screws used to seal it. You'll need a Philips head screwdriver for eyeglasses screws which I didn't have so it was a pain. Also, it's unclear to me why there's a power port and plug provided since the USB connection provides power. (I' …" Read Full Review »
Pros
Cons
Best Uses
"This is an excellent product! The only thing you need to be sure of is that the drive you are converting is an internal EIDE or IDE 2.5", NOT ESATA or SATA. It's very easy to set up-you pop the drive onto the circuit board, then secure it with screws. Then you screw the encasing on with a choice of …" Read Full Review »
"The HDD in my laptop computer, which runs on Windows XP, died a little time ago. On startup I got the blue screen with a STOP sign...
I called my laptop manufacturer and was told to buy a new HDD. Ughhh! I then spent quite a bit of time trying to get something done using MS-DOS; I got a look at the
Read Full Review »
"I can not rate the performance because, so far my computer does not recognize the hard drive enclosure, with laptop hard drive inside. I first hooked up the hard drive cable, no recognition. The drive did spin, but no dice. Then I called the manufacturer for answers, and they said plug in the extra …" Read Full Review »
"This is an amazing product.! My laptop failed but the HD still worked. I needed to access my data.
I removed my laptop's IDE hard drive and installed it in this case. Plugged it in my new computer's USB port and had access to my old hard drive. PRO's: The ultra USB storage case has a bracket inside
Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Outstanding 9.1
| $1.99 Shipping on Orders Over $75 ends 12/31/09 | ||||
| $10 Off Orders Of Orders Over $85 + Free Shipping |
BizRate Rating
Good 8.7
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
