Ultra Products Ultra MD2 5.25 4 Port USB 2.0 and Card Reader
3.8
based on 49 reviews
Ratings Distribution
5 star
15
4 star
16
3 star
6
2 star
4
1 star
4
Category Average
4.2
Low Price:
$24.99 at CompUSA
 Trusted:
$24.99 at TigerDirect
Find it at Amazon
$24.99
from 2 stores
More Images
Provided by TigerDirect
Ultra Products Ultra MD2 5.25 4 Port USB 2.0 and Card Reader Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 26, 2009
Ultra Products Ultra MD2 5.25 4 Port USB 2.0 and Card Reader Reviews
Most helpful positive review
Most helpful negative review
4.0
Great value: easy to ...
"Great value: easy to install;I do wish that it had more detailed instructions for finding the ports on the motherboard. There are 2 adaptors for the 2 usb's, which may or may not be needed. Instructions were to put the adaptors on but then there were no ports for it without routing to the back panel usb's. I discovered by accident that the adaptors were not needed for the motherboard. Sometimes following the ins..." Read Full Review »
May 03, 2009 by E.K.
See more positive Ultra Products Ultra MD2 5.25 4 Port USB 2.0 and Card Reader reviews
3.0
I bought this reader with ...
"I bought this reader with trepidation because of the DOA units reported by other buyers. Fortunately, mine seems to work correctly. Be advised tho, of the USB disclaimer that the USB ports are non-powered, and are intended only for self-powered USB devices. It won't even reu my thumb drive. I wish I had looked further for a different model. This one has many good features, but to me they all are overshado..." Read Full Review »
Aug 25, 2009 by Yank
See more negative Ultra Products Ultra MD2 5.25 4 Port USB 2.0 and Card Reader reviews
Displaying 1 - 5 of 49 Reviews
Show
Sort by
Don't buy it. The side ...
2.0
"Don't buy it. The side where the screws go did not line up and it is not made out of metal, it is soft plastic, so the holes are not very rigid, and it makes the whole front side look uneven.
I haven't had any problems with USB ports saying anything about power, but my power supply is 1000Watts. O …"  Read Full Review »
Was this Computer Drive & Storage review on the Ultra Products Ultra MD2 5.25 4 Port USB 2.0 and Card Reader helpful to you?
Nov 17 2009
Gerald
Undisclosed
4.0
"Great value: easy to install;I do wish that it had more detailed instructions for finding the ports on the motherboard. There are 2 adaptors for the 2 usb's, which may or may not be needed. Instructions were to put the adaptors on but then there were no ports for it without routing to the back panel …"  Read Full Review »
May 3 2009
E.K.
Undisclosed
Looks good - Works Well - ...
4.0
"Looks good - Works Well - Does not mount well in a tooless case - I just used a small drill bit to make a hole in the side of the plastic and placed a screw in the hole to make it more secure on the right side. I used a 4 GB SDHC SD card in the reader that I was having trouble properly formating in …"  Read Full Review »
Apr 21 2009
Al
Undisclosed
3.0
I …"  Read Full Review »
Aug 25 2009
Yank
Undisclosed
For the price I paid, ...
4.0
"For the price I paid, about $25, it hasn't let me down. One thing to remember about Windows when using the card readers, use the eject feature in the "computer" window. Right click your drive's icon and select eject, don't safely remove hardware, unless you've found that you can still put something …"  Read Full Review »
May 13 2009
Kenny
Undisclosed
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
