Ultra Products Ultra Max (ULT40061) Case Cooling Fan
4.1
based on 73 reviews
Ratings Distribution
5 star
35
4 star
19
3 star
13
2 star
3
1 star
3
Category Average
4.3
More Images
Pros
  • Easy to install (3)
  • Highly compatible (2)
  • Quiet (2)
  • Reliable (2)
  • Affordable (1)
  • Fast (1)
See less See more
Best Uses
  • Gaming (2)
  • High-end multimedia (2)
  • Keeps loud fans at bay (1)
  • Upgrade (1)
Provided by Beach Audio
MODEL- ULT40061 VENDOR- ULTRA PRODUCTS
FEATURES- Multi-Fan Controller for 3.5" Drive Bay
You want complete control over your case fan RPM's in order to get
that perfect balance of low noise and keeping components cool. But
when you're gaming, and your components start getting hot, isn't it
good to know that your fans are capable of moving as much air as
possible? Most fan controllers won't even let a fan spin at 100% of
it's specified RPM even when the controller is turned up to it's
maximum. It's not unusual for power to get lost through the
circuitry of the controller and the resulting drop in voltage
prevents your fans from moving as much air as possible. This is why
Ultra designed the new Overclocking Multi-Fan Controller from the
ground up.
By thinking outside of the box, we've created a fan controller that
not only runs the fans from 0% to 100% of their rated speed, but is
also completely silent. The Ultra Fan Controller has four
channels, each capable of outputting between 6.5V and 13V. The
controller fits in any available external 3.5" bay and emits a
subtle blue light from around each knob. The controller uses
standard 3-pin fan headers and even includes 3-pin extensions so
RPM's can be monitored by the motherboard and it's all backed by
Ultra's unparalleled 3 year warranty.
* 4 Channel Multi-Fan Controller
* Adjustable Blue LED Fan Speed Knob
* Silent
* RPM monitor cable for compatible motherboards
-- SPECIFICATIONs -----------------------------------
INPUT VOLTAGE - 5V
OUTPUT VOLTAGE- 6.5V - 13V
OUTPUT CURRENT- Up to 3A
CONTROLLERS - 4 Fans
COMPATIBILITY - Fits in a standard 3.5" drive bay
DIMENSIONS - 4" x 1" x 5.5"
www.Ultra.com
Ultra Products Ultra Max (ULT40061) Case Cooling Fan Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: Ultra Max (ULT40061) Case Cooling Fan
See all eBay results
  at eBay.com
Product Reviews
Last update: Oct 22, 2009
Ultra Products Ultra Max (ULT40061) Case Cooling Fan Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
5.0
Best for the buck
"First of all - the knob doesn't translate voltage the way you think it would. IE; Let's say all the way to the left is 0. All the way to right is 100. Half way being 50. At "0" - a 120mm fan is at 800rpm. At "50" - it's at 900ish. At "75" - it's at 1400. At "100" - it's at 1750. Same pattern for a smaller 80mm. Claims to overclock; does NOT. It's slightly less than what they run straight from the mothe..." Read Full Review »
Jun 13, 2008 by wastedfluid
See more positive Ultra Products Ultra Max (ULT40061) Case Cooling Fan reviews
1.0
Well I made the mistake ...
"Well I made the mistake of buying fans which were rated at a very very high cfm and dB rating... needless to say I was dissapointed with one aspect of this fan controller, NO 4-PIN POWER CABLES !!!! Do NOT buy this fan controller unless you're using only 3-pin fans, or it will simply not work. Haven't found any converters yet on this site either, you have to shop elsewhere for them. You will need a cable that c..." Read Full Review »
Oct 12, 2009 by ASAP
See more negative Ultra Products Ultra Max (ULT40061) Case Cooling Fan reviews
Displaying 1 - 5 of 73 Reviews
Show
Sort by
Best for the buck
5.0
    Pros
  • Easy To Install
  • Fast
  • Highly Compatible
  • Quiet
  • Reliable
    Cons
  • None
    Best Uses
  • Gaming
  • High-End Multimedia
"First of all - the knob doesn't translate voltage the way you think it would. IE; Let's say all the way to the left is 0. All the way to right is 100. Half way being 50. At "0" - a 120mm fan is at 800rpm. At "50" - it's at 900ish. At "75" - it's at 1400. At "100" - it's at 1750. Same pattern …"  Read Full Review »
Was this Computer Fan & Cooling System review on the Ultra Products Ultra Max (ULT40061) Case Cooling Fan helpful to you?
 Report Abuse  (1)  (0)  0 comments
Jun 13 2008
wastedfluid
Roanoke, VA
I am:
  • Heavy Duty User
Reviewed at:
Love It!
5.0
    Pros
  • Affordable
  • Easy To Install
    Cons
  • None
    Best Uses
  • Gaming
  • Keeps Loud Fans at Bay
  • Upgrade
"I have 7 fans in my rig, and it was REALLY LOUD. Until I put four nonessential fans on this baby. Now I can turn them up for gaming, and down while listening to music and other non-hardware-intensive tasks. Best of all, this thing is dirt cheap! Nothing begins to compare for quality and price. Overa …"  Read Full Review »
May 7 2009
Soccerluver13
LA, CA
I am:
  • Heavy Duty User
Reviewed at:
Solid Fan Control
5.0
    Pros
  • Easy To Install
  • Highly Compatible
  • Quiet
  • Reliable
    Cons
  • None
    Best Uses
"I run a quad-core machine dedicated to video editting/rendering. During renders, I go to an overclock setting and use this controller to help manage the thermal loads by dialing up fan speeds. When I'm doing setups or edits, I use a non-overclock setting to save power and heat. Overclocked quad c …"  Read Full Review »
Jun 21 2008
TJ
Minnesota
I am:
  • Frequent User
Reviewed at:
1.0
"Well I made the mistake of buying fans which were rated at a very very high cfm and dB rating... needless to say I was dissapointed with one aspect of this fan controller, NO 4-PIN POWER CABLES !!!! Do NOT buy this fan controller unless you're using only 3-pin fans, or it will simply not work. Haven …"  Read Full Review »
Oct 12 2009
ASAP
Undisclosed
Reviewed at:
As for this fan ...
4.0
"As for this fan controller. You get what you pay for. As mentioned before, the overall structure of the controller is decent. But It looks nice from the outside of the case. I'm sorry to say that on of the LEDs burnt out in mine. The major flaw I found was with the 4 potentiometers that control the …"  Read Full Review »
Aug 20 2009
That Guy
Undisclosed
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
