#233
based on 20 reviews
Ratings Distribution
| 5 star |
9 |
| 4 star |
6 |
| 3 star |
2 |
| 2 star |
2 |
| 1 star |
1 |
Category Average
$29.00 - $29.99
from 3 storesWhere to Buy
| $1.99 Shipping On Orders Over $100 at TigerDirect ends 12/31/09 |
BizRate Rating
Outstanding 9.1
| $1.99 Shipping on Orders Over $75 | ||||
Product Reviews
"This hard drive cooler looks really sleek and cools fairly well. The anti-shock and vibration also seems to do their job well, however, because of them this cooler is nearly impossible to install in tooless 5.25 drive bays because it is suspended. Only if you have optional screw mounts on both sides as well would I recommend this. I ended up having to bend and snap parts of my case to make holes for this to moun..." Read Full Review »
Aug 22, 2009 by Raccoony
See more positive Ultra Products Ultra Aluminum Hard Drive Cooler with Heatpipes reviews
"Mounting hardware only fits 5'' drive bays (which I have never seen before) or, if you have a rail kit, you might get it to fit into a standard 5-1/4'' drive bay. If you have ''tool less'' drive bays, forget it. The heat pipes are probably just to keep both sides of the drive at equal temperature. I suspect the base aluminum drive chasis does this anyway. Since I honestly can't use the product in any of my sy..." Read Full Review »
Apr 16, 2009 by ARNOLD
See more negative Ultra Products Ultra Aluminum Hard Drive Cooler with Heatpipes reviews
Displaying 1 - 5 of 20 Reviews
Ultra Products Ultra Aluminum Hard Drive Cooler with Heatpipes Review
"This hard drive cooler looks really sleek and cools fairly well. The anti-shock and vibration also seems to do their job well, however, because of them this cooler is nearly impossible to install in tooless 5.25 drive bays because it is suspended. Only if you have optional screw mounts on both sides …" Read Full Review »
Read Full Review »
"I purchased two of these for use with 1.5TB drives.
When I tried to install them the screw holes did NOT match up with the screw holes on the drives. This made them absolutely unusable.
Also, even if the drives did fit, they are so BIG that it would have been impossible to use two of them in the
Read Full Review »
"Works as advertised.
However please note that it needs a full 5.25'' drive bay PLUS ample space above it (like another empty 5.25'' drive bay).
Also make sure that your IDE cable can be routed conveniently before buying this cooler.
(I had to change the case with a bigger one and do some extra work
Read Full Review »
"Not being a computer hardware genius, I didnt realize that my case was considered tool less. Duhhh.
I finally made a couple of brackets and modified the original mounting bracket for my HD and It works great. I really like the lack of power consumption, and it is quiet. Have a small windmill on my
Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Outstanding 9.1
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
