Turtle Beach Tbs-1120-01 Micro Sound Card ( Tbs112001)
#5
4.8
based on 38 reviews
from $26.95 - $45.00
Ratings Distribution
5 star
32
4 star
6
3 star
0
2 star
0
1 star
0
Category Average
4.1
More Images
Pros
  • Easy to install (7)
  • Easy to use (4)
  • Highly compatible (4)
  • High quality (3)
  • Powerful (3)
  • Quality output (3)
  • Reliable (3)
  • Added features (1)
See less See more
Cons
  • Driver installation (1)
Best Uses
  • Everyday (2)
  • Replacement (2)
  • Gaming (1)
  • High-end multimedia (1)
  • Movies h264 (1)
  • Multimedia (1)
  • Upgrade (1)
Provided by Shoppers Choice
MODEL- AUDIOADVMICRO VENDOR- TURTLE BEACH-VOYETRA FEATURES- Audio Advantage Micro Home-Theater realism on your PC or Laptop! Surround sound experience with stereo headphones! The Turtle Beach Audio Advantage Micro is a portable USB Audio Adapter with both digital and analog outputs that incorporates a surround-sound simulator for creating an immersive listening experience on standard headphones or stereo speakers. Power LED lights up when the Audio Advantage Unit is plugged into an active USB port to indicate power has been applied. Insert headphones or analog powered speakers into the Analog Mini Jack. Use the USB Connector Cap to protect the USB socket when storing the Audio Advantage unit. Insert the SPDIF Digital Adapter into the mini jack to connect a TOSLINK optical cable when using the digital audio output. Includes Audio Advantage Unit with cover, USB Extender cable, Optical SPDIF adapter, software CD. Stereo analog output. Connect headphones or powered speakers to your PC or laptop. Works with USB port on any PC or Laptop Provide a second audio output source or additional headphone output so you can stop fumbling around the back of your computer just to switch from speakers to headphones Multi-channel digital audio pass-through Send Dolby Digital and DTS multi-channel DVD sound to A/V receivers or digital speakers. (DTS pass-through is only available in Windows 2000/XP). S/PDIF optical digital audio output. Connect your PC or Laptop to the latest high-tech home entertainment equipment with a pure-digital, distortion-free signal, for highest fidelity, low noise audio reproduction. Revolutionary signal processing system. Listen to stereo digital music or movies with the simulated sound of a multi-speaker, surround-sound system using ordinary stereo headphones or stereo speakers. Virtual 5. 1 Surround Sound with stereo music. Replace the in your head effect of regular headphone listening with spacious surround sound on stereo sources such as CDs or MP3 files. It is almost like having a whole new music collection! Virtual 5. 1 Surround Sound with DVDs. Listen to DVD audio with spectacular simulated home-theater surround- sound on stereo headphones. Simulated 3D audio effects with games. Enjoy realistic 3D sound effects with stereo headphones while playing multi-channel games. Wide variety of ambiance settings ( Environments ). Enhance music playback with simulated big room effects such as concert hall, hallway, stadium, and more. Multi-band equalizer with user-defined presets for adjusting tone. Adjust the bass, treble or other tone settings so you can listen to your music exactly the way you like it. Easily switch between sound field settings. Select whichever one suits the particular program material and your own preferences. Powered by USB bus. No external power supply is required, so it is convenient to carry around with your laptop. Convenient and portable package. Easy to carry in your laptop bag and does not get in the way when using it for travel or work - about the size of your thumb! -- SPECIFICATIONs -------------------------------------INTERFACE/BUS- USBSOFTWARE - Includes CD with Audio Advantage Control Panel Audio Advantage 3DPlay Demo 3D Flying Helicopter Game with 3D HRFT Audio. 3D Multi-Channel Audio Demo Rock War Game with 3D HRTF Audio AudioSurgeon Demo MusicWrite Demo Record Producer DemoREQUIRES - Pentium 450MHz or faster (the Audio Advantage offers limited limited capabilites for Mac Users. For more information, click here. Available USB port 128MB RAM (minimum) Approx. 50MB free had drive space 1024 x 768 High Color (24-bit) Display Windows 98SE/ME/2000/XP CD-ROM or DVD-ROM drive required for software installation. A DVD drive, compatible DVD player software, and a high- quality 5. 1 Surround speaker system (5 powered speakers plus a powered subwoofer) are required for playing back Dolby Digital (AC-3) audio from DVD movies with the Audio Advantage. High quality stereo (2-speaker) sound system, stereo powered speakers or headphones are recommended to properly hear the Audio Advantage high-quality stereo playback. A digital speaker system or home theater A/V receiver with optical TOSLINK is necessary for connecting the Audio Advantage optical digital output. Www. Turtlebeach. Com
Specification Description
Model AUDIOADVMICRO, TBS-1120-01, TBS112001
UPC 731855011209
Accessory Indicator Yes
Benefits Digital audio adapter lets you easily connect to home theater or recording equipmentCrystal clear music reproduction on the road or a
Capacity UOM mAh
Country Of Origin United States
Description Header Mind-blowing sound.
Display Catalog Number 55015227
Included in the Box Audio Advantage Micro unit with coverOptical SPDIF adapterUSB extender cable
Manufacturer Labor Warranty 90
Manufacturer Part Number TBS-1120-01
Manufacturer Parts Warranty 90
MAP Price 0.0
Model TBS-1120-01
Operating Temperature UOM ° F
Product Disclaimer Warranty is 90 days limited.
Product Type 5.1 channel
Required to function Intel® Pentium® 450MHz processor or fasterAn available USB port128MB of RAM50MB free hard disk space
Supported Languages English
Turtle Beach Tbs-1120-01 Micro Sound Card ( Tbs112001) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 8, 2009
Turtle Beach Tbs-1120-01 Micro Sound Card ( Tbs112001) Reviews
Displaying 1 - 5 of 38 Reviews
Show
Sort by
[8 of 8 customers found this review helpful]
This has saved me alot of money!
5.0
"Pros
Turns any PC into an HTPC in a matter of minutes. Works perfectly with Vista.
Cons
None I have experienced.
Additional Thoughts
OK. Maybe it can't turn ANY PC into an HTPC. You do need a decent video card and a few programs to go along with it. But if you don't have an SPDIF interface on y …"  Read Full Review »
Was this Sound & Video Card review on the Turtle Beach Tbs-1120-01 Micro Sound Card ( Tbs112001) helpful to you?
 Report Abuse  (8)  (0)  0 comments
Jul 24 2007
RainyDaze
Oly, WA
Reviewed at:
Price: $27.99
Great value and convenience
5.0
    Pros
  • Added features
  • Easy To Use
    Cons
    Best Uses
  • None
"I wanted something inexpensive that was portable and would give me the ability to 'equalize' some audio while playing it back. This has a software equalizer that works just fine.
the only downside is that if you don't always use the same usb port you have to reinstall driver package and reboot(?). …"  Read Full Review »
Jul 7 2008
bgolden
Ogallala, NE
I am:
  • Value Oriented
Reviewed at:
Price: $28.99
[1 of 1 customers found this review helpful]
Great Product
4.0
    Pros
  • Easy To Install
  • Easy To Use
  • Quality Output
  • Reliable Performance
    Cons
  • None
    Best Uses
  • Everyday use
  • Gaming
  • Multimedia
"This is a great easy way to add a second sound card. Plug and play,fast. Don't use thier software. It uses to many resources. Windows sound drivers are good enough unless..you want 5.1 or are seriously upgrading your sound card. This will do it. It just takes some time to get the software that is th …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
May 29 2009
DJ Jackson
Norwich, Conn
I am:
  • Power user
Reviewed at:
Price: $29.99
great product-would recommend
4.0
    Pros
  • Easy To Install
  • High Quality
  • Highly Compatible
  • Powerful
    Cons
  • None
    Best Uses
  • Replacement
"lost sound on my laptop. learned an external sound card would work, so found the TBeach usb plug-in, but of course needed speakers to project, so bought some for [$]. i'm no savvy tech geek, and was not willing to invest [$]for labour/new internal sound card for my 5yr old laptop. "
Feb 19 2009
ladybirdmt
BC, Canada
I am:
  • Quality Oriented
Reviewed at:
Price: $29.99
Once upon a time I ...
4.0
"Once upon a time I plugged my laptop into my home stereo system and the sound sucked. This prevented me from digitizing my music. I found this device and thought I'd give it a try. After installing it, I tried it out and the sound was no better. This was the problem: this device has a present equali …"  Read Full Review »
Jul 1 2009
frauS
Undisclosed
Reviewed at:
Price: $34.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
