TRIPP Omni VS 1500VA Tower UPS (Model #OMNIVS1500)
#78
4.6
based on 5 reviews
Ratings Distribution
5 star
4
4 star
0
3 star
1
2 star
0
1 star
0
Category Average
4.3
$165.26 - $224.84
from 12 stores
More Images
Pros
  • Charges quickly (1)
  • Long lasting (1)
  • Powerful (1)
  • Reliable (1)
See less See more
Best Uses
  • High-end equipment (1)
  • Office (1)
Provided by Beach Audio
Tripp Lite's OMNIVS1500 line interactive UPS system offers voltage regulation, surge suppression and battery support for personal computers, internetworking equipment and other sensitive electronics. Internal UPS circuits support entry level PC systems for up to 75 minutes during power failures so that connected equipment can be shut down without data loss. Automatic Voltage Regulation (AVR) circuits regulate brownouts as low as 75 and overvoltages up to 147 volts back to usable 120V levels without using battery power. Offers complete desktop power protection in an attractive black tower configuration. Includes 6 battery supported outlets for computer, monitor and one vital system peripheral, plus 2 additional surge suppression-only outlets for printers and other system accessories not requiring battery support. USB port enables optional unattended system shutdown without data loss in the case of extended power failure, USB cable included. PowerAlert software available via free download from www.tripplite.com. Built-in dataline suppression offers protection for equipment with single line TEL/DSL or network ethernet connection. Audible alarm and 4 front panel LEDs indicate line power, battery power, battery low/replace status and voltage boost operation. 1500VA power handling ability supports entry-level PCs, network workstations, point-of-sale equipment, small business phone systems, audio/video equipment and home theater systems. Offers 5 minutes battery runtime with a full load of 1500VA and 14 minutes with a half load of 750VA. Supports hot-swappable battery replacement via built-in access panel. KEY BUYING POINTS OMNIVS1500 Uninterruptible Power Supply offers voltage regulation, surge suppression and long lasting battery support Supports entry level PCs up to 75 minutes during blackouts to enable shutdown without data loss Regulates brownouts as low as 75 and overvoltages to 147V back to usable 120V nominal levels without using battery power 6 UPS battery supported outlets, plus 2 additional surge suppression-only outlets USB port and cable enables UPS monitoring and unattended shutdown in the case of extended power failure PowerAlert software available via free download from www.tripplite.com Dataline surge suppression protects standard dialup/DSL or ethernet line connection Audible alarm and 4 front panel LEDs offer complete UPS and line power status information 1500VA power handling ability supports a variety of sensitive electronic equipment 5 minutes full load runtime (1500VA), 14 minutes half load runtime (750VA) Supports hot swappable battery replacement via built-in access panel
Specification Description
Model 1155726, OMNIVS1500
UPC 037332126382
Form Factor Tower
Input Voltage 110V AC
Load Capacity 1500VA / 940W
Output Voltage 120V AC Nominal
Plug/Connector Type NEMA 5-15P
Receptacles 8 x NEMA 5-15R
Standard Warranty 2 Year(s)
UPS Type Line-interactive UPS
TRIPP Omni VS 1500VA Tower UPS (Model #OMNIVS1500) Questions
Questions and Answers
Where to Buy
$169.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
$165.26
$166.66
Show all 12 stores
Product Reviews
Last update: Aug 19, 2009
TRIPP Omni VS 1500VA Tower UPS (Model #OMNIVS1500) Reviews
Displaying 1 - 5 of 5 Reviews
Show
Sort by
Good value for this product
5.0
    Pros
  • Charges Quickly
  • Long Lasting
  • Powerful
  • Reliable Performance
    Cons
  • None
    Best Uses
  • High-End Equipment
  • Office
"I use this UPS for 3 high end workstations that require 24 hour operation. Ths UPS accomodates monitor and CPU for 3 computers plus surge protection for two other devices such as printers and scanners. I find nothing I don't like about it. "
Was this Surge Protector review on the TRIPP Omni VS 1500VA Tower UPS (Model #OMNIVS1500) helpful to you?
Oct 4 2008
Cadbury
Forestburg, TX
I am:
  • Quality Oriented
Reviewed at:
If Linux is your ...
3.0
"If Linux is your operating system, there are much better choices than this Tripplie UPS (or any Tripplite UPS with a USB interface).
The problem is that Tripplite does not provide a
Linux driver for the USB interface, instead they refer users to: www.networkupstools.org
However from the discussion …"  Read Full Review »
Jun 2 2009
Disappoint
Undisclosed
Reviewed at:
Price: $169.99
I believe it's misleading ...
5.0
"I believe it's misleading to name it 8 outlets, when only 6 are back up outlets. FYI. This is our first time with Tripplite, so far so good! We have 1 PC, 1 monitor, a cable modem, router and 2 telephony adapters running on this model. I calculated at about 50% load to keep the running time up l …"  Read Full Review »
Aug 21 2008
Karissa
Undisclosed
Reviewed at:
Price: $169.99
I swore by Tripplite for ...
5.0
"I swore by Tripplite for many years, excellent customer service, good upgrade plans, until I had an Omni 1440 fail and fry my system, calls went unanswered, emails went unanswered, end result is I will NOT buy a Tripplite product again, their ''connected equipment'' warranty is non-existant! "
Jul 12 2006
Phil
Undisclosed
Reviewed at:
Price: $169.99
Maybe it does not play ...
5.0
"Maybe it does not play well with Linux systems; but, if this product works as well as the other TrippLite units I have used in the past, well as you can see I am still buying TrippLite! "
Aug 19 2009
LITTLE-JOH
Undisclosed
Reviewed at:
Price: $169.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
