TRENDnet TU-400E 4-Port Compact USB Hub
#244
4.0
based on 9 reviews
Ratings Distribution
5 star
4
4 star
3
3 star
0
2 star
2
1 star
0
Category Average
4.1
$9.17 - $25.99
from 12 stores
More Images
Pros
  • Easy to use (3)
  • Durable (1)
  • Fast (1)
  • Reliable (1)
See less See more
Cons
  • Blue light is very bright (1)
Best Uses
  • Dorm room (1)
  • Travel (1)
Provided by Buzzillions.com
4-Port Bus-Powered USB Hub
Specification Description
Model TU-400E
UPC 710931302073
Connectivity Type USB - Hub
Form Factor External
Number of Ports 4
TRENDnet TU-400E 4-Port Compact USB Hub Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jan 22, 2009
TRENDnet TU-400E 4-Port Compact USB Hub Reviews
Displaying 1 - 5 of 9 Reviews
Show
Sort by
[9 of 10 customers found this review helpful]
Caution! Older USB 1-1 Spec, not USB 2.x.
2.0
"I missed in the description that these hubs do not support the much-faster USB 2.0 spec, but are the older, slower and therefore less-desirable USB 1.1 compliant. This could have been emphasized more in the description to avoid misunderstanding. "
Was this Networking Hub & Switch review on the TRENDnet TU-400E 4-Port Compact USB Hub helpful to you?
 Report Abuse  (9)  (1)  0 comments
Sep 13 2007
M. Jones
Colorado Front Range, USA
Reviewed at:
Price: $25.99
Skip it
2.0
"This is a pretty worthless 4 port hub considering it doesn't support USB 2.0. These are also subject to causing issues with key binds when you have a keyboard plugged into one. The port will not allow multiple keys to be used simultaneously which is highly frustrating.
There are much better option …"  Read Full Review »
Jan 22 2009
Nathan Beauchamp
Oak Park, IL USA
Reviewed at:
Price: $25.99
[1 of 1 customers found this review helpful]
Works great.
4.0
"It works great. My only complaint is that the outputs are too close together. It would of been nice to see two on each side.
Also, a way to put a screw in the wall and slide it on it would of been nice. Sort of like the back of a power strip.
Otherwise, it works fine and I have no problems wit …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Sep 10 2008
Eugene Domingo
Laurel, MD
Reviewed at:
Price: $25.99
unit does what it should
4.0
    Pros
  • Easy to Use
    Cons
  • None
    Best Uses
  • None
"We needed more usb port and this got it done, not usb 2 so not as fast. self powered via usb cable. Works well. "
Jun 19 2008
zacman
CT
I am:
  • Value Oriented
Reviewed at:
Price: $9.99
[0 of 1 customers found this review helpful]
good choice
5.0
"I had been having trouble with the keyboard hook up in the pack of my processor.This really helped.I'm also goimg to go wireless and will need extra ports and I thought this would really help.I've been real happy with this trendnet 4 port,and expect even better in the near future. "
 Report Abuse  (0)  (1)  0 comments
Jun 18 2008
J. White
galax va
Reviewed at:
Price: $25.99
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
