TRENDnet TMR-61U2 USB 2.0 6-in-1 Memory Card Reader/Writer
#42
4.3
based on 3 reviews
from $19.99 - $23.31
Ratings Distribution
5 star
1
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.1
Low Price:
$19.99 at Dell
 Trusted:
$23.31 at pcRUSH
Find it at Amazon
More Images
Pros
  • Fast transfer (3)
  • Excellent interface (2)
  • Lightweight (2)
  • Reliable (2)
  • Durable dock (1)
  • Long cable (1)
See less See more
Cons
  • Difficult to set up (1)
  • Poor interface (1)
Best Uses
  • Image transfer (3)
  • Digital photography (1)
Provided by OnSale
TMR-61U2 USB 2.0 6-in-1 Memory Card Reader/Writer Reads and Writes Compact Flash Card (CF), Micro Drive (MD), Smart Media Card (SM), Memory Stick (MS), Secure Digital Card (SD) and MultiMedia Card (MMC) TRENDnet's TMR-61U2 USB 2.0 6-in-1 Memory Card Reader/Writer provides an ideal solution to read and write up to 6 types of memory cards including MultiMedia Card, CompactFlash Card, IBM Micro Drive, Smart Media Card, Secure Digital Card, and Memory Stick. Its 4-slot design accommodates up to 4 different types of memory cards at the same time for convenient file transfers between different types of cards. Transfer large files between your computer, digital camera, PDA, MP3 player and more. The TMR-61U2 has a UBS 2.0 interface that offers plug-and-play installation, Hi-Speed data transfer rate, and backward compatibility with USB1.1 interface. TRENDnet's TMR-61U2 6-in-1 Memory Card Reader/Writer provides incredibly easy and fast data transfer method for your memory cards. -Compliant with Hi-Speed USB 2.0 standard -Backward compatible with USB 1.1 interface -Reads and Writes Compact Flash Card (CF), Micro Drive (MD), Smart Media Card (SM), Memory Stick (MS), Secure Digital Card (SD) and MultiMedia Card (MMC) -Reads/writes up to 4 different types of memory cards at the same time -Compatible with Windows 98/98SE/ME/2000/XP, Mac OS 8.6 and above, and Linux kernel 2.4.0 and above -Does not require driver installation for Windows ME/XP, Mac OS 10.1.2 or above, and Linux Kernel 2.4.0 or above -Supports USB high-speed (480Mbps), full-speed (12Mbps) and low-speed (1.5Mbps) transfer rates -Supports Plug & Play and Hot-Swap -Portable compact design and no external power source required -Low Power consumption (power saving mode supported) -USB cable embedded on the device (75mm/2.95 inches). An extension cable is included. -1-year Warranty
Specification Description
Model 10273676, TMR-61U2, TMR61U2
UPC 710931503036
Form Factor External Hot-swappable
Interface 1 x 4-pin Type A Male USB 2.0 - USB
Media Slots 4
TRENDnet TMR-61U2 USB 2.0 6-in-1 Memory Card Reader/Writer Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jun 1, 2009
TRENDnet TMR-61U2 USB 2.0 6-in-1 Memory Card Reader/Writer Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Great little unit
5.0
    Pros
  • Durable Dock
  • Excellent Interface
  • Fast Transfer
  • Lightweight
  • Reliable
    Cons
  • None
    Best Uses
  • Digital Photography
  • Image Transfer
"Worked right out of the box. Just plugged it in and started to transfer file. Could not be any easier. "
Was this Card Reader review on the TRENDnet TMR-61U2 USB 2.0 6-in-1 Memory Card Reader/Writer helpful to you?
 Report Abuse  (1)  (0)  0 comments
Dec 8 2008
Biking Colorado
Winter Park, CO
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Works fine. Instructions lousy.
4.0
    Pros
  • Fast Transfer
  • Lightweight
  • Long Cable
    Cons
  • Difficult Setup
  • Poor Interface
    Best Uses
  • Image Transfer
"It was easy to use once I figured it out. The written instructions weren't just unclear -- they were wrong. "
Feb 4 2009
Conchita
Deerfield, IL
I am:
Reviewed at:
Works as expected
4.0
    Pros
  • Fast Transfer
  • Reliable
    Cons
  • None
    Best Uses
  • Image Transfer
"I use this to transfer images fron flash media cards to my laptop to select and view in Photoshop. "
Jun 1 2009
Tricky[*]
Lindenhurst, IL
I am:
  • Professional
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
