TRENDnet TEW-423PI 54Mbps 802.11g Wireless PCI Adapter
#286
3.6
based on 138 reviews
Ratings Distribution
5 star
63
4 star
20
3 star
14
2 star
15
1 star
26
Category Average
3.9
Low Price:
$19.94 at J&R Electronics
 Trusted:
$19.95 at B&H Photo Video
Find it at Amazon
$19.94 - $34.99
from 11 stores
More Images
Pros
  • Easy setup (1)
See less See more
Cons
  • Unreliable connection (1)
Best Uses
  • Home network (1)
Provided by MAGo Enterprise
MODEL- TEW-423PI VENDOR- TRENDNET FEATURES- 54Mbps 802.11g Wireless PCI AdapterTRENDnet's TEW-423PI 54Mbps Wireless PCI Card cuts the wires to your desktop and provides 54Mbps speed to handle bandwidth-intensive applications. It complies with the IEEE 802.11g standard making it backward compatible with 802.11b networks for assured compatibility. Advanced 128-bit WEP encryption is supported to provide secure access for your data. Cut the wires and move your desktop where you need it with TRENDnet s 802.11g wireless PCI Card. Includes TEW-423PI Utility & Driver CD-ROM Multi-Language Quick Installation Guide. * Wi-Fi Compliant with IEEE 802.11g and IEEE 802.11b Standards * Uses 2.4 GHz Frequency Band which Complies with Worldwide Requirements * Supports Ad-Hoc (Peer-to-Peer) Mode or Infrastructure (AP-Client) Mode * Dynamic Data Rate Scaling at 54 48 36 24 18 12 9 and 6Mbps for802.11g. * Dynamic Data Rate Scaling at 11 5.5 2 and 1Mbps for 802.11b * Maximum Reliability Throughput and Connectivity with Automatic Data RateSwitching. * Compatible with Windows 98(SE)/ME/2000/XP * Supports 64/128-bit WEP WPA/WPA2 and WPA-PSK/WPA2-PSK * Detachable 2dBi Dipole Antenna with Reverse SMA Connector * Low Interference and High Susceptibility Guarantee Reliable Performance * Range of 35-100 meters indoor 100-300 meters outdoor (depends on theenvironment). * Simple User Setup & Diagnostics Utilities -- SPECIFICATIONs ----------------------------------- INTERFACE/BUS- 32-bit PCI 2.2 Bus Master STANDARDS- IEEE 802.11b and IEEE 802.11g ANTENNA - (1) 2dBi Detachable Dipole Antenna INDICATORS - LEDs for Link POWER CONSUMPTION-Receive Mode: 240mA Transmit Mode: 530 mA TRANSMISSION RATE-802.11b: CCK (11 and 5.5Mbps) DQPSK (2Mbps) DBPSK (1Mbps) 802.11g: OFDM FREQUENCY- 2.412 to 2.484 GHz (Industrial Scientific Medical Band) MEDIA ACCESS PROTOCOL-CSMA/CA with ACK DATA RATE- (auto fallback) 802.11b: 11Mbps 5.5Mbps 2Mbps and 1Mbps 802.11g: 54Mbps 48Mbps 36Mbps 24Mbps 18Mbps 12Mbps9Mbps and 6Mbps TRANSMIT POWER-15dBm (typical) @ 802.11b 12dBm (typical) @ 802.11g RECEIVE SENSITIVITY-54Mbps 10% PER @ -73 dBm (typical) 11Mbps 8% PER @ -85 dBm (typical) SECURITY - WPA/WPA2 (TKIP)WPA-PSK/WPA2-PSK (AES/TKIP)64/128-Bit WEP (Hex or ASCII) CHANNELS - 1 to 14 Channels (Universal Domain Support) O/S SUPPORT - Windows 98SE ME 2000 XP APPROVALS- FCC CE DIMENSIONS - 4.8w x 0.85h x 5.2dWT.- 2.2 oz. (with antenna) (w/o metal bracket)
Specification Description
Model TEW-423PI, TEW423PI
UPC 710931502510
Interface PCI
Network Type Wireless 802.11b / 802.11g
Wireless Technology Wi-Fi - IEEE 802.11b/g
Wireless Transmission Speed 18Mbps
TRENDnet TEW-423PI 54Mbps 802.11g Wireless PCI Adapter Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 24, 2009
TRENDnet TEW-423PI 54Mbps 802.11g Wireless PCI Adapter Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
5.0
TEW-423PI Wireless PCI Adapter
"Pros Ordered two cards. Very easy to install, XP picked right up on it. My computer, a Dell Dimension E310, runs at over 9Mb. Cons Tried both cards on a Dimension 4400, the best I could get was 2.5Mb, it runs at over 8Mb on ethernet cable. The TEW-423PI Wireless PCI Adapter and the Dell 4400 don't seem to be very compatible. Additional Thoughts I put a low end router in a closet. I still get excellent recep..." Read Full Review »
Apr 10, 2007 by scottb
See more positive TRENDnet TEW-423PI 54Mbps 802.11g Wireless PCI Adapter reviews
2.0
I installed this card the ...
"I installed this card the other day. While it boasts 54.00 mbps, it says currently it's giving me 11 - 18. I don't know what that's about. But here's the real problem: the software it tells you you 'must' install. I play online games pretty often, and in the middle of the game, the internet connection would cut off, and my CPU usage would spike between 0 and 100 every 5 seconds, and no matter what programs I end..." Read Full Review »
Aug 21, 2009 by Nilbert
See more negative TRENDnet TEW-423PI 54Mbps 802.11g Wireless PCI Adapter reviews
Displaying 1 - 5 of 138 Reviews
Show
Sort by
5.0
"Pros
Cons
Tried both cards on a Dimension 4400, the best I could get was 2.5Mb, it runs at over 8Mb on ethernet cable. The TEW-423PI Wireless PCI Adapter and the Dell 4400 don' …"  Read Full Review »
Was this Wireless Networking review on the TRENDnet TEW-423PI 54Mbps 802.11g Wireless PCI Adapter helpful to you?
 Report Abuse  (3)  (0)  0 comments
Apr 10 2007
scottb
Kentucky
Reviewed at:
Price: $26.99
2.0
"I installed this card the other day. While it boasts 54.00 mbps, it says currently it's giving me 11 - 18. I don't know what that's about. But here's the real problem: the software it tells you you 'must' install. I play online games pretty often, and in the middle of the game, the internet connecti …"  Read Full Review »
Aug 21 2009
Nilbert
Undisclosed
I had a old Dlink PCI ...
5.0
"I had a old Dlink PCI wireless card, and I was having problems with it since I installed Service Pack 3 for XP. It would not longer connect using WPA2. It would only connect WPA-AES, not WWPA-TKIP or WPA2.
I found this card for $14.99 at Compusa and gave it a try since I wasn't risking much at this …"  Read Full Review »
Jul 31 2008
Bob in Flo
Undisclosed
This device sounded great ...
3.0
"This device sounded great at first. then the i found that there was a problem within minutes of the install. after researching the problem, it comes down to bad programming in the firmware. what happens is that the card looses connectivity. it will still show that has a good connection but the card …"  Read Full Review »
Oct 24 2009
WHITEY
Undisclosed
I bought this product for ...
2.0
"I bought this product for the purpose of gaming online. When I first got it I thought wow! This adapter is great! 80% from in the garage, and the router is above the adjacent indoor room.
However, my review plummets after I play games. For some reason, this adapter ALWAYS cuts out after about 5 min …"  Read Full Review »
Oct 4 2009
Mordiven
Undisclosed
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
