TRENDnet 2-Port USB KVM Switch
#54
4.1
based on 77 reviews
from $14.99 - $29.99
Ratings Distribution
5 star
37
4 star
26
3 star
6
2 star
4
1 star
4
Category Average
4.1
Pros
  • Easy setup (25)
  • Compact (7)
  • Reliable connection (7)
  • Fast connection speed (6)
  • Highly compatible (6)
  • Smart features (5)
  • Small (4)
  • Fast (3)
  • Reliable (2)
  • Secure connection (2)
See less See more
Cons
  • Unreliable (4)
  • Unreliable connection (2)
  • Cables are short (1)
  • Flimsy (1)
  • I like everything (1)
  • Incompatible (1)
  • Lousy exeperience (1)
  • Screen resolution changes (1)
  • Slow (1)
Best Uses
  • Home network (11)
  • Desktop (6)
  • Home (6)
  • Home networks (5)
  • Small offices (4)
  • Small networks (2)
  • A windows pc and linux pc (1)
  • Computer repair (1)
  • Expected better of rs (1)
  • Large networks (1)
Provided by Beach Audio
MODEL- TK-207K VENDOR- TRENDNET
FEATURES- 2-Port USB KVM Switch
The 2-Port USB KVM Switch lets you manage two PC's with just one set
of keyboard, monitor, and mouse. Switch between two PC's with a
simple press of a button! Separate sets of KVM cables are included
with the KVM Switch, so users can start controlling 2 PC's
instantly. The KVM cables also provide power to the KVM Switch,
eliminating the need for a power adapter. Hot Key operations
provide immediate access to features such as computer switching,
and auto-scanning. With its Hot-Plug, and Audible Feedback, the
2-Port USB KVM Switch is the perfect choice for managing multiple
PC's.
Includes KVM switch and two Sets of 1.2M (4 ft.) KVM Cables.
* Use one keyboard, monitor, and mouse to control two computers
* USB Keyboard/Mouse emulation with 2-set of detachable KVM Cables
* Supports Microsoft Intellimouse, Optical Mouse, Logitech Net Mouse and
more.
* Supports super High Video Quality, up to 2048 x 1536 VGA resolution
* Supports Windows 98/98SE/ME/2000/XP/2003 Server, Linux, and Mac OS
* Multi-Platform support for PCs, Macintosh G3/G4, iMac and Mac Mini
* Hot-Plug pluggable. Adds PC or removes the connected PCs for maintenance
without powering down the KVM Switch or other PC's.
* Switches PC by hot-keys, push button or windows-base client switch
software.
* Auto-Scan & LED display for easy status monitoring
* User definable hot-key (Windows Only)
* USB Interface Power method
-- SPECIFICATIONs -----------------------------------
CONNECTORS - Computer : (2) USB 1.1 ports
Console : (2) USB Keyboard/Mouse: (Type A)
(1) VGA/SVGA 15-pin HDB
CABLE INTERFACE - To Console: (1) VGA/SVGA HDB 15-pin (male)
To PC : (1) USB (Type A)
(1) VGA/SVGA HDB 15-Pin (male)
PORT SELECTION - Push Button, Hot-Key Commands or Windows-Based Client
Switching Software.
AUTO-SCAN INTERVAL- 10 seconds
KEYBOARD STATE - Saved and Restored
APPROVALS - CE, FCC
POWER SOURCE - USB Interface Power
DIMENSIONS - 3.86" x 2.76" x 1.1" WT.- 3.4 oz.
www.trendnet.com
Specification Description
Model 2500259, TK-207K, TK207K
UPC 710931304237
Accessory Indicator Yes
Benefits Use one keyboard, monitor and mouse to control two computersMulti-platform support for PCs, Macintosh G3/G4, iMac and Mac Mini
Capacity UOM mAh
Country Of Origin China
Description Header Be in control.
Display Catalog Number 25-259
Features Supports super high video quality, up to 2048x1536 VGA resolutionHot-plug pluggableAuto-scan & LED display for easy status m
Humidity Range Operating 0-90%
Included in the Box 2-Port USB KVM SwitchKVM cable set (2)
Inputs 2 x USB(USB)
Manufacturer Labor Warranty 2
Manufacturer Parts Warranty 2
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
New Date Tue Sep 04 00:00:00 CDT 2007
Operating Temperature UOM ° F
Outputs 1 x VGA(VGA)
Product Type KVM
Supported Languages English
TRENDnet 2-Port USB KVM Switch Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 16, 2009
TRENDnet 2-Port USB KVM Switch Reviews
Most helpful positive review
Most helpful negative review
4.0
Small and functional
"Simple and small, this KVM does what it needs to. No problems setting up: just plug everything in! The unit comes with cables and they seem to be working well. It works well too: I've had no problems switching between my two computers. This has made my desk much more tidy and saves me the effort of constant wire switching. Note that it's very simple and offers only USB connections (no PS/2), VGA only for vi..." Read Full Review »
Apr 15, 2009 by Ben
See more positive TRENDnet 2-Port USB KVM Switch reviews
2.0
Ok...at first
"My first recommendation is buying the extended warranty! I had this KVM switch for 9 months when it conked out on me. It started to become a little shaky at first, so I would disconnect and then reconnect all the cables, but then one day it just didn't work anymore. Since I purchased the warranty for $5 I wasn't too upset. All in all this KVM switch is easy to set up and easy to use and well suited for a home of..." Read Full Review »
Oct 22, 2009 by Jeebs
See more negative TRENDnet 2-Port USB KVM Switch reviews
Displaying 1 - 5 of 77 Reviews
Show
Sort by
Ok...at first
2.0
    Pros
  • Easy To Setup
    Cons
    Best Uses
  • Home network
"My first recommendation is buying the extended warranty! I had this KVM switch for 9 months when it conked out on me. It started to become a little shaky at first, so I would disconnect and then reconnect all the cables, but then one day it just didn't work anymore. Since I purchased the warranty fo …"  Read Full Review »
Was this Wired Networking review on the TRENDnet 2-Port USB KVM Switch helpful to you?
Oct 22 2009
Jeebs
New York, NY
I am:
  • high bandwidth user
eh
2.0
    Pros
  • Small
    Cons
  • Unreliable
    Best Uses
  • Desktop
  • Home
"I had one connected between my work laptop docking station and my home PC to facilitate dicking around while working at home. It seems to do the job ok, but VGA is becoming a dead connection type. You probably want DVI-D, the digital standard. In any case, that is not one of this product's shortf …"  Read Full Review »
Mar 25 2009
Joey the Snitch
Grayslake, IL
I am:
  • High bandwidth user
Works a majority of the time
3.0
    Pros
  • Easy To Setup
  • Fast Connection Speed
    Cons
    Best Uses
  • Home network
"I love this product, it mostly does what I need it to. When switching my KVM from one computer to the other, just double tap "Scroll Lock" - works great.
Occassionally it changes the monitor but not the keyboard and mouse. This usually requires a shut down of both PCs (to eliminate power to t …"  Read Full Review »
Apr 15 2009
wayno
Universal City, TX
I am:
4.0
    Pros
  • Easy To Setup
    Cons
  • None
    Best Uses
  • Home network
"Simple and small, this KVM does what it needs to. No problems setting up: just plug everything in! The unit comes with cables and they seem to be working well. It works well too: I've had no problems switching between my two computers. This has made my desk much more tidy and saves me the effort …"  Read Full Review »
Apr 15 2009
Ben
Falls Church, VA
I am:
It has limitations!
4.0
    Pros
  • Easy To Set Up
    Cons
  • Incompatible
    Best Uses
  • Desktop
  • Home
"Software portion of product is not compatable with Windows power save Sleep mode.
Box isn't heavy enough to corral cables, and TRENDnet hasn't provided any mounting hardware to help with the multitude of cables that constantly tug on the box. I have devised my own.
Because of the Sleep mode comp …"  Read Full Review »
Feb 22 2009
Ed
T-Town, OK
I am:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
