TRAVEL SPEAKER ULTRA THIN DESIGN
3.2
based on 14 reviews
Ratings Distribution
5 star
3
4 star
5
3 star
1
2 star
2
1 star
3
Category Average
4.0
$39.95 at Brookstone
Find it at Amazon
Find it at Ebay
$39.95
from 1 store
Pros
  • Attractive design (8)
  • Easy to connect (5)
  • Great sound quality (3)
  • Compact (2)
  • Crisp sound (2)
  • Easy setup (2)
  • High quality (2)
  • Lightweight (2)
  • Powerful (2)
  • Extremely convenient (1)
See less See more
Cons
  • Poor sound quality (7)
  • Not very powerful (3)
Best Uses
  • Smaller rooms (5)
  • Anytime (1)
  • Basic systems (1)
  • Intimate situations (1)
  • Lacks audible sound (1)
  • On the road or on my desk (1)
  • Outdoors (1)
  • Short presentations (1)
  • Travel (1)
  • Travel netbooks (1)
Provided by Brookstone
The Ultra-Thin Travel Speaker works with your MP3 player, laptop and more. Now it's easy to get great sound from your MP3 Player, laptop or DVD player anywhere you go. This compact speaker not only sounds terrific, it folds flat to save space in your luggage. Featuring NXT� flat panel speaker technology it disperses sound evenly and delivers a rich, full sound. It connects easily to your MP3 player, laptop, or DVD player via the included 3.5mm cable. Use 3 AAA batteries (not included).
Portable?take your music anywhere.
Now you don't have to sacrifice great tunes just because you're on the road. Lightweight, compact and sounds so good?this speaker makes the perfect traveling companion. The speaker and stand fold flat to pack away neatly and protect the speaker at the same time. The Ultra-Thin Travel Speaker Connects to any MP3 player, laptop, or DVD player and other media devices via 3.5mm cable included.
NXT� flat panel technology delivers rich, full sound.
Traditional cone speakers have relatively narrow sound dispersion and you'd have to stand in a tiny area to experience the "sweet spot." The Ultra-Thin Travel Speaker uses NXT� technology to make use of the entire speaker panel, both in front and in back, to fill any room with fuller, more lifelike sound.
Ultra-Thin Travel Speaker folds flat?perfect for traveling.
The stand fits snugly against the panel and it measures only 5" x 6" x 0.75" when folded, so it won't take up valuable space in your bag. When it?s folded, the stand also protects the speaker panels from being damaged. Designed to give you the best of both worlds?sound and portability.
The more you hear about our Ultra-Thin Travel speaker, the better it sounds. Order today!
NXT is a registered trademark of New Transducers, Limited.
  • 100% agreed the sizing feels true to size
TRAVEL SPEAKER ULTRA THIN DESIGN Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 22, 2009
TRAVEL SPEAKER ULTRA THIN DESIGN Reviews
Most helpful positive review
[1 of 4 customers found this review helpful]
Most helpful negative review
[3 of 3 customers found this review helpful]
5.0
Use it for netbook
"I was looking for something to replace my netbook speakers because they are very low etc and i found this at the brookstone store and decided to try it there the ipod didn't workj well at first but since i have a blackberry decided to add it on and all i heard was heavy metal play in high quality and said oh crud i have to get this really do like it so far battery havn;t died and the thing i have in mind is gett..." Read Full Review »
May 03, 2009 by Phantom Zero
See more positive TRAVEL SPEAKER ULTRA THIN DESIGN reviews
1.0
bad investment
"I use this product on my nana ipod, connecting it was fairly easy. But the sound quality was very poor on some of my music selections compared what I heard at the store. I could barely hear the vocals on some selections, very poor vocals. Only heard the instruments as the vocals were muffed in the background. I should have brought me a real portable sound system, at least the vocal would have been better. Poor d..." Read Full Review »
Jul 05, 2009 by unsatisfied user
See more negative TRAVEL SPEAKER ULTRA THIN DESIGN reviews
Displaying 1 - 5 of 14 Reviews
Show
Sort by
bad investment
1.0
    Pros
  • Attractive Design
    Cons
  • Distorted Sound
  • Not Very Powerful
  • Poor Sound Quality
    Best Uses
"I use this product on my nana ipod, connecting it was fairly easy. But the sound quality was very poor on some of my music selections compared what I heard at the store. I could barely hear the vocals on some selections, very poor vocals. Only heard the instruments as the vocals were muffed in the b …"  Read Full Review »
Was this Home Audio & Electronics review on the TRAVEL SPEAKER ULTRA THIN DESIGN helpful to you?
 Report Abuse  (3)  (0)  0 comments
Jul 5 2009
unsatisfied user
atascadero, ca
I am:
  • Audiophile
Reviewed at:
Price: $39.95
Use it for netbook
5.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Great Sound Quality
  • Powerful
    Cons
  • None so far
    Best Uses
  • Travel Netbooks
"I was looking for something to replace my netbook speakers because they are very low etc and i found this at the brookstone store and decided to try it there the ipod didn't workj well at first but since i have a blackberry decided to add it on and all i heard was heavy metal play in high quality an …"  Read Full Review »
 Report Abuse  (1)  (3)  0 comments
May 3 2009
Phantom Zero
Tampa Florida
I am:
  • Audiophile
  • Musically Inclined
  • Professional
  • Tech Savvy
Reviewed at:
Price: $39.95
Big Bang in Small Package
4.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Extremely Convenient
  • Good Sound Quality
    Cons
  • Not Very Powerful
    Best Uses
  • Basic Systems
  • Intimate Situations
  • Smaller Rooms
"The size, weight and portability are really terrific qualities. The speaker itself lacks the UMPHHH to make really good sounds (low and high tones are weak). But, it is what it is - a lightweight, portable speaker to be used in small intimate places and situations. It was NOT intended to be a "bo …"  Read Full Review »
Mar 15 2009
Thomaseb
Brooksville, Florida
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Price: $39.95
I like it.
4.0
    Pros
  • Attractive Design
  • Compact
  • Easy To Set Up
  • Great travel
    Cons
  • Poor Sound
    Best Uses
  • Smaller Rooms
"This product is great to supplement poor speakers on laptops and slips easily into a briefcase. The sound can distort somewhat what but if you ajust the speaker drum it corrects. It is great for short audio prentations and clips. We bought four of them. "
Oct 22 2009
Wallace404
Atlanta
I am:
  • Professional
Reviewed at:
Price: $39.95
[2 of 2 customers found this review helpful]
fidelity is poor, especially with volume
1.0
    Pros
  • Attractive Design
  • Compact
  • Easy To Set Up
    Cons
  • Distorted Sound
  • Poor Sound
    Best Uses
  • Wouldn't
"Sound quality is poor. Brookstone associates laughed at me when I told them about poor sound quality. "What did you expect for the price?"
Rude. "
 Report Abuse  (2)  (0)  0 comments
Aug 4 2009
Rich
Stuart, FL
I am:
  • Professional
Reviewed at:
Price: $39.95
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
