Tram 1610-HC 5-FT VHF MARINE ANTENNA
#17
5.0
based on 3 reviews
from $19.95 - $29.99
Ratings Distribution
5 star
3
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
3.9
More Images
Pros
  • Clear signal (2)
  • Easy setup (2)
  • Compact (1)
  • Easy to install (1)
  • Great pick up (1)
  • Looks good on the boat (1)
See less See more
Best Uses
  • Any boat with radio (1)
  • Unskilled installer (1)
  • Used for gulf trip worked (1)
  • Vhfweather radio (1)
Provided by Shoppers Choice
COVERS ALL MARINE-BAND FREQUENCIES; HEAVY-DUTY FIBERGLASS CONSTRUCTION; GAIN: 3 DB; STAINLESS STEEL HARDWARE; NYLON RATCHET MOUNT FOR EASY LAY DOWN; 17-FT, RG58 A/U COAXIAL CABLE WITH PL-259 SUBCATEGORY2: MARINE RADIOS.
Specification Description
Model 1610-HC
UPC 727932000969
Accessory Indicator Yes
Antenna Type Marine
Benefits Covers all marine band frequenciesFiberglass constructionGain: 3DBStainless-steel hardware and nylon ratchet-mount
Capacity UOM mAh
Country Of Origin Taiwan
Description Header Covers all marine band frequencies.
Display Catalog Number 55026449
Manufacturer Labor Warranty 12
Manufacturer Part Number 1610-HC
Manufacturer Parts Warranty 12
MAP Price 0.0
Model 1610-HC
Operating Temperature UOM ° F
Product Dimensions UOM feet
Product Length 5
Product Type Marine
Supported Languages English
Tram 1610-HC 5-FT VHF MARINE ANTENNA Questions
Questions and Answers
Where to Buy
$29.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$19.95
$28.72
Product Reviews
Last update: Oct 27, 2009
Tram 1610-HC 5-FT VHF MARINE ANTENNA Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Great antenna. good reach
5.0
    Pros
  • Easy to install
  • Great pick up
    Cons
  • None
    Best Uses
  • VHFWeather radio
"easy to install and works great. the mount allows many installation options. be careful when installing to make sure your mounting holes are clear on the back side. "
Was this Radio review on the Tram 1610-HC 5-FT VHF MARINE ANTENNA helpful to you?
 Report Abuse  (1)  (0)  0 comments
Jul 4 2009
Michael
Greensboro NC
I am:
  • Tech Savvy
Reviewed at:
Price: $29.99
Woth the money
5.0
    Pros
  • Clear Signal
  • Compact
  • Easy To Set Up
    Cons
  • None
    Best Uses
"This is a quality antenna, easy to set up and to use. Would by it again if I needed another. "
Aug 11 2009
Country Preacher
Bennett, WI
I am:
  • Tech Savvy
Reviewed at:
Price: $29.99
5.0
    Pros
  • Clear Signal
  • Easy To Set Up
    Cons
  • None
    Best Uses
"worked fine provided good reception "
Oct 27 2009
mike
ga
I am:
  • Practical
Reviewed at:
Price: $29.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
