Toshiba SD-V296 VCR and DVD Player Combination
#8
4.0
based on 31 reviews
from $77.99 - $119.00
Ratings Distribution
5 star
17
4 star
7
3 star
0
2 star
3
1 star
4
Category Average
3.5
More Images
Pros
  • Easy to use (8)
  • Consistent performance (6)
  • Easy setup (6)
  • Great picture quality (6)
  • Attractive design (1)
  • Compact (1)
  • Difficult to set up (1)
  • Great auto-tracking (1)
  • Poor instructions (1)
See less See more
Cons
Best Uses
  • Home (8)
  • High volume usage (1)
  • Office (1)
Provided by HSN
If "early electronics" is not your idea of decor, welcome to the world of the Toshiba DVD/VCR Combo Player. This one-unit wonder combines the picture and sound advantages of a progressive scan DVD player with the convenient recording and playback options of a VCR. Its slick, slim chassis makes it a handsome and discreet companion to any decorating style. Toshiba DVD/VCR Combo Player Features: One Touch Recording for the VCR - simple and convenient ColorStream Pro Progressive Scan - for delivery of stunningly colorful images Simultaneous DVD playback and VHS Record - for watching a DVD while recording a TV program JPEG Viewer3 - display digital photographs on a television set in the JPEG digital format Key Specifications: Playable Disc Types: DVD-Video, DVD-R/RW, CD/CD-R/RW, VCD Formats: DVD, VHS Measures approx. 17.1"W x 3.7"H x 9.2"Deep Weighs approx. 6 lbs. Model #: SDV296 Power Source: Plug into any household outlet Color: Black Made in Thailand Additional DVD Specifications: Video D/A Converter: 108MHz/14-Bit Analog Converter: yes Stereo Audio Outputs: DTS digital, Dolby digital Remote Control: Yes Simulated Surround Sound: 3D Surround Sound Optical Digital Audio Outputs: Composite A/V, Coaxial Digital Audio, Component Video, ColorStream Pro Video (rear - DVD only),S-Video (rear - DVD only), RCA-Video (rear - both) Input Jacks: RCA-Video (front and rear), L-R Audio (front and rear) Languages: English, French and Spanish Child Lock: Yes Other Features: Digital Picture Zoom Fast Scan Slow Motion Multi-Camera Angle Select Multi-Language Select Multi-Subtitle Select CD Playback VCR Specifications: S-VHS Playback: Yes, SQPB (Super Video Home System Quasi Playback) Record Functions: Simultaneous Playback Functions: Hi-speed rewind Number of Heads: 4 Hi-Fi VHS Stereo Commercial Skip Accessories Included: DVD/VCR remote control User Guide
Specification Description
Model SD-V296, SDV296, TOSDR420
UPC 022265001844
Audio D/A Convertor 14-Bit/108MHz
Benefits One-touch recording for the VCR provides a simple and convenient way to make a recordingColorStream Pro® progressive scan compone
Body Material Metal
Capacity UOM mAh
Connections RCA component jacks (3)RCA composite A/V (3 sets)S-video (1)Audio in (1)Audio out (1)
Country Of Origin Thailand
Description Header Connectivity without clutter.
Display Catalog Number 55033489
DVD Media Type DVD-R/DVD-RW and CD-R/CD-RW discs
DVD Supported Digital Audio Standards Dolby® Digital and DTS® Compatible Output
DVD Type 1 disc
Enclosure Color Black
End Product Indicator Yes
Manufacturer Labor Warranty 12
Manufacturer Part Number SD-V296
Manufacturer Parts Warranty 12
MAP Price 0.0
Media Format DVD-R/DVD-RW and CD-
Model SD-V296
Operating Temperature UOM ° F
Picture Zoom Yes
Product Depth 9.2
Product Dimensions UOM inches
Product Disclaimer Dolby and Dolby Pro Logic are registered trademarks of Dolby Laboratories Licensing Corporation.
Product Height 3.7
Product Type DVD combos
Product Weight 7.7
Product Weight UOM pounds
Product Width 17.1
Search Speed Slow, FF
Supported Languages English
Video D/A Convertor 14-Bit/108MHz
Toshiba SD-V296 VCR and DVD Player Combination Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 17, 2009
Toshiba SD-V296 VCR and DVD Player Combination Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
4.0
This unit fits the bill
"This product was very easy to set up and use. Image quality is very good. I'll be using this in a school where it should get plenty of use by many different individuals. My other Toshiba products have held up well. Time will tell if this unit deserves 5 stars!..." Read Full Review »
Feb 05, 2009 by Jaquie the AV Lady
See more positive Toshiba SD-V296 VCR and DVD Player Combination reviews
2.0
Bad idea... don't do it
"In general, I love Toshiba products. However, I had to return this DVD/VCR unit because it seemed very cheaply made and I had a feeling that it would break within a few months. I was very surprised (not pleasantly) by the lack of quality; usually Toshiba is very good about this. This unit felt and handled like a plastic toy. It made strange noises when opening/closing the DVD door. In addition to these build iss..." Read Full Review »
Oct 21, 2009 by Nikki79
See more negative Toshiba SD-V296 VCR and DVD Player Combination reviews
Displaying 1 - 5 of 31 Reviews
Show
Sort by
4.0
    Pros
  • Consistent Performance
  • Easy To Set Up
  • Easy To Use
  • High Quality Picture
    Cons
  • None
    Best Uses
  • High Volume Usage
"This product was very easy to set up and use. Image quality is very good. I'll be using this in a school where it should get plenty of use by many different individuals. My other Toshiba products have held up well. Time will tell if this unit deserves 5 stars! "
Was this Combo DVD Player & Recorder review on the Toshiba SD-V296 VCR and DVD Player Combination helpful to you?
 Report Abuse  (2)  (0)  0 comments
Feb 5 2009
Jaquie the AV Lady
Rochester, NY
I am:
  • Power User
Reviewed at:
Price: $77.99
Quality name
4.0
    Pros
  • Easy To Set Up
  • Easy To Use
    Cons
  • None
    Best Uses
  • Home
"I like this combination player, I bought it because I already own one just like it and needed another. The only thing that would have made it better would be a better price. You can buy machines that perform the same function for less, but Toshiba makes a good product and I expect that the quality w …"  Read Full Review »
Oct 13 2009
Bubbleface
South Carolina
I am:
  • Casual User
Reviewed at:
Price: $77.99
[3 of 3 customers found this review helpful]
Excellent DVD/VCR player
5.0
    Pros
  • Easy To Set Up
  • Easy To Use
    Cons
  • None
    Best Uses
  • Home
"We have a traditional CRT Television that only had a video (RCA) in jack. This player had a SINGLE shared output between the DVD and VCR (Read ONE OUTPUT). No, it is not high def but the picture quality was still crisp with minimal cables. The player did have additional outputs but the single sha …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Dec 15 2008
Rod
Wisconsin
I am:
  • Enthusiast
Reviewed at:
Price: $79.00
2.0
"In general, I love Toshiba products. However, I had to return this DVD/VCR unit because it seemed very cheaply made and I had a feeling that it would break within a few months. I was very surprised (not pleasantly) by the lack of quality; usually Toshiba is very good about this. This unit felt and h …"  Read Full Review »
Oct 21 2009
Nikki79
Undisclosed
Reviewed at:
Price: $94.98
Did I really?
5.0
    Pros
  • Easy To Set Up
  • Easy To Use
    Cons
  • None
    Best Uses
  • Home
"Did I really just purchase a Toshiba DVD/VCR player for under [$]? It is an attractive looking piece of equipment, was easy for me to install (and I am electronically impaired!!) and was watching a movie in minutes. I found you through the Upromise program and have sent your link as a suggestion to …"  Read Full Review »
May 28 2009
KernieG
Nashville, Tn.
I am:
  • Casual User
Reviewed at:
Price: $86.00
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
